osholt |
osholt L Plate Warrior
Posted: 18:36 - 17 Dec 2020 Post subject: CG125ES4 (2005) Clutch Problems (Pushrod?) |
Hi all,
I cam across this old thread and I thought my problem might be similar: https://www.bike-parts-honda.com/honda-motorcycle/125-MOTO/CG/2004/CG125ES4/Engine/CLUTCH/17KGA401/E__0600/1/3570
I am having problems actuating my clutch after taking the engine apart and reassembling. The clutch lever has very little resistance and is not actuating the clutch no matter where I adjust it to. The clutch worked perfectly before I disassembled it so I do not believe it is the cable or lever.
I have been following the Haynes manual instructions but they make no mention of the different push road arrangement in Brazialian bikes.
I have the pushrod style shown in this parts diagram (part 9): https://www.bike-parts-honda.com/honda-motorcycle/125-MOTO/CG/2004/CG125ES4/Engine/CLUTCH/17KGA401/E__0600/1/3570
I am confused how this is supposed to be installed to actuate the clutch. Is the shaft part of the pushrod supposed to be recessed into the mechanism in the right crank case cover and the flat disc pushing directly on the ball bearing inner race? This seems wrong but I can't really see how else it would go together unless I am missing another part. Based on the parts diagrams this does not appear to be the case. If the part is spun round as in the diagram (facing the other way with the shaft going through the bearing loosely), I cannot see how it would engages with the mechanism in the right cover.
Are the screws compressing the clutch springs supposed to be done up all the way? It seems when they are there is not enough travel on the pushrod when it is engages with the cover mechanism to push against the bearing.
The clutch lifter plate (8 in the diagram) does appear to be recessed further into the clutch centre than the Haynes manual shows when all the screws are done up.
Any suggestions? Am I missing a part or have I just installed it wrong?
If anyone has any better instructions or pictures that would also be great.
Thanks,
Oliver |
osholt |
bikenut |
bikenut World Chat Champion
bikenut |
osholt |
oilyrag |
oilyrag Nova Slayer
osholt |
bikenut |
osholt |
bikenut |
bikenut |
osholt |
bikenut |
Posted: 15:09 - 05 Jan 2021 Post subject: 7 |
Part 7, the o ring? No.
Part7, the alloy "pressure plate" let's call it, the bit with the 4 threaded towers that the 4 spring bolts go into, no.
Go and have a look at your pictures of the clutch drum/basket.
Look logically.
Do fish have fingers ? No.
What have fingers to do with a clutch ffs. May be "tangs" would be a better word.
Tangs are on files ffs, not clutches, arnt they?
Times crossword puzzle, criptic as hell and take me all day to do...
Have a good look at the clutch drum/basket, which is on the engine as seen in your pics?
See anything odd? Different somehow, wrong, not in the right place, compared to the others....there are enough of them....
It's better for you to see the mistake yourself, do you learn more so you don't make the same mistake again, rather than be told.
Just have a good look. ____________________ nuts about bikes
Robby |
Robby Dirty Old Man
bikenut |
osholt |
bikenut |
Robby |
Robby Dirty Old Man
The last post was made 3 years, 109 days ago. Instead of replying here, would creating a new thread be more useful? |
