| scotto75 |
 scotto75 Renault 5 Driver
| Nobby the Bastard |
| xX-Alex-Xx |
 xX-Alex-Xx World Chat Champion
| oilrag |
 oilrag Derestricted Danger
| scotto75 |
| jeffyjeff |
 jeffyjeff World Chat Champion
| bikenut |
 bikenut World Chat Champion
 Posted: 16:12 - 10 Feb 2021 Post subject: T |
That's how it's supposed to be done.
If your not sure what above means, draw a sketch of the set up, you may need a compass, the drawing set type, and possibly a ruler.
See the difference ?
You can set up tension "loaded", then unload and make an "indicator " from some tin and mark for tension when loaded, then it's easier than sitting on bike etc.., or get an assistant to sit on the bike to load suspension etc., Etc. Etc....
An over tight chain will ruin stuff like the chain, sprockets, cush drives, wheel bearings, swing arm bushes and yes, gearbox output shaft bearings.
See CMSNL exploded views for what's involved in replacing the "now possibly uncaged balls" in the bearing, etc. etc. etc.
It's gunna be a full strip down etc..
Enjoy... ____________________ nuts about bikes |
| jaffa90 |
 jaffa90 World Chat Champion
 Posted: 17:20 - 10 Feb 2021 Post subject: |
PostPosted: 01:38 - 10 Feb 2021 No Rating Post subject: Reply with quote
Due to the offset between the swingarm pivot and the countershaft, the chain slack tightens as the suspension is compressed. For this reason I check my chain tension while sitting on the bike (rear suspension full sag). This results in a chain slack that is a bit looser than spec, if checked when the suspension is unloaded. But by running the chain a bit on the loose side (still fully within spec when motoring down the road), I know the chain is not placing undue stress on the countershaft bearing. Just one man's opinion.
bikenut
Karma : Excellent Karma (Level 3)Excellent Karma (Level 3)Excellent Karma (Level 3)Excellent Karma (Level 3)
PostPosted: 16:12 - 10 Feb 2021 No Rating Post subject: T Reply with quote
Enjoy...
Been stating this for years, you need chain slack when fully loaded.
Some muppets on here state refer to handbook settings when on the side / centre stand. |
| redeem ouzzer |
 redeem ouzzer World Chat Champion
| bikenut |
| redeem ouzzer |
| Robby |
 Robby Dirty Old Man
The last post was made 5 years, 294 days ago. Instead of replying here, would creating a new thread be more useful? |
