A100man |
A100man World Chat Champion
Posted: 17:55 - 02 Jan 2021 Post subject: Wiring curiousity.. FZ750 |
Hi All
I'm trying to trace an electrical issue as pressing the start button on the FZ no longer turns the motor over.. It should short the relay input ( a blue/white wire) to gnd/earth completing the circuit and activating the relay. I've eliminated the relay by connecting the input to gnd directly. and the motor then spins
The switch/button appears to be Ok as on pressing it the OIL warning light comes on as it should.
The interesting bit is that the blue/white wire also appears to pass through a box of tricks called the ' Turn Signal Relay' which sure enough feed the indicators.
I can't for the life of me though, see why the starter signal should be needed for this 'relay'
My concern is that the starter signal is compromised as it passes through this part.
Any thoughts? ____________________ Now: A100, GT250A, XJ598, FZ750
Nobby the Bastard |
oilyrag |
oilyrag Nova Slayer
Nobby the Bastard |
A100man |
Posted: 19:03 - 02 Jan 2021 Post subject: |
Nobby the Bastard wrote: | Oh god, you're opening a box full of cats there.
In the speedo is a switch that measures changes to speed. It's on the wiring diagram and I think its called a reed switch. This, combined with the madness that is the indicator relay, was meant to make the indicators self cancelling to an extent.
It didn't really work and its a known issue with fzs failing to start. Look for corrosion on the connector block. |
Aha yes I see 'Reed Switch' as the green/white wire input also to the Turn Relay..
But why the Blue/White starter signal?
Wiring diagram is from Clymer.. Not much else out there. I'll have another go at cleaning the connector contacts . ____________________ Now: A100, GT250A, XJ598, FZ750
Nobby the Bastard |
Easy-X |
Easy-X Super Spammer
ThatDippyTwat |
Nobby the Bastard |
Easy-X |
Posted: 13:45 - 03 Jan 2021 Post subject: |
Are we talking an actual "reed switch?" As dippy says you'd need a magnet to affect it. Or is it a mercury tilt switch? That would make more sense for self-cancelling. Anyhoo, sounds like the sort of twattery only a Harley rider would need ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Nobby the Bastard |
A100man |
Posted: 19:20 - 03 Jan 2021 Post subject: |
Easy-X wrote: | I know this is a bit clichéd but it's not something like a sidestand, neutral or clutch switch? Looks like blue & white also goes into some clever* arrangement of diodes, if I'm looking at the right diagram...
*as in "it seemed like a good idea at the time" |
The diode allows the oil light to come on during the start phase presumably as a test of the oli warning bulb. ____________________ Now: A100, GT250A, XJ598, FZ750
ThatDippyTwat |
Nobby the Bastard |
ThatDippyTwat |
A100man |
Posted: 20:00 - 11 Jan 2021 Post subject: Re: Wiring curiousity.. FZ750 |
A100man wrote: |
Any thoughts? |
I found an explanation for the 41R-71 'Turn Signal Relay'..
turns out its a 'game of two halves, Terry'
https://yamaha-virago.blogspot.com/2018/10/relays.html ____________________ Now: A100, GT250A, XJ598, FZ750
The last post was made 3 years, 104 days ago. Instead of replying here, would creating a new thread be more useful? |
