Litwos7 |
Litwos7 L Plate Warrior
Posted: 00:27 - 06 Jan 2021 Post subject: Cagiva Mito Oil Spits |
Welcome. I have a problem with my mito because, in August, she got a new engine top and connecting rod, the squish is set correctly, the ignition is also good, the shaft seals are also good. The kit includes a mikuni tm 35 carburetor (which was used with this cylinder) italkit v force diaphragm valve and a turbokit carrera gp exhaust. The carburetor is factory set, I tried to adjust the mixture screw to zero effect, I reduced the main jet from 310 generations to 270 zero effect, it still spits oil on the back of the motorcycle and, worst of all, the tire and brake. Due to such a low degree of mixture I have rubbed the motorcycle ... I make the oil mixture myself 1:50 oils which were Motul 800 710 ipone samourai and castrol power 1 on each the same, pb95 fuel. I don't have enough strength anymore, does anyone know what the problem may be? Best regards and have a nice evening: D |
oilyrag |
oilyrag Nova Slayer
Litwos7 |
oilyrag |
oilyrag Nova Slayer
Litwos7 |
P. |
P. Red Rocket
Posted: 09:46 - 06 Jan 2021 Post subject: Re: Mito movies |
You can't ruin a 2 stroke video with music. That is heresy.
Have you considered using the original end can... |
Litwos7 |
Easy-X |
Easy-X Super Spammer
MarJay |
MarJay But it's British!
A100man |
A100man World Chat Champion
Posted: 13:04 - 06 Jan 2021 Post subject: |
MarJay wrote: | I...
*breathe*
I...
*Be polite Mark, be polite*
You are aware that two strokes rely on the shape of their exhaust to scavenge gases and to keep fuel inside the cylinder, right? The exact shape and volume of the exhaust is absolutely critical to the functioning of the engine? You also are aware that turboing a two stroke is fairly pointless because of the way the ports open and close, all you're doing is pressurising the crankcase rather than providing any extra compressed air into the cylinder. The movement of the piston is what opens the inlet and exhaust ports, and if you turbo the engine, all that will happen is the excess pressure will escape via the exhaust and transfer ports, pumping fresh charge out. You'll also probably blow the crank seals because of extra pressurised air going through the transfers.
You clearly have some technical ability, but absolutely no knowledge of two strokes. Two strokes spit out oil. That's why their exhausts tend to push gases and liquids away from the rear wheel. Modern 'GP' style exhausts are spectacularly inappropriate for engine performance and safety reasons. |
I think the OP is smarter than that. 'Turbokit' is just the name of his expansion chamber style exhaust..
https://moto125.pl/p/195/1500/sportowy-wydech-turbokit-gp-carrera-2t-125cm3-tuning-mechaniczny-cagiva-mito-sp525-125-cagiva.html
Lucky you exercised your restraint. ____________________ Now: A100, GT250A, XJ598, FZ750
A100man |
Posted: 13:06 - 06 Jan 2021 Post subject: |
Litwos7 wrote: | If I choose the original end cam I need to change all rear of the exhaust from the diffuser beacuse turbokit exhaust don't have any posibility to mount end can, wool in turbokit was also replaced but I got a question because in my book muffler is showed in different way than I done to my exhaust, I done it that way because it jus fitted into stinger with just some help. Is it good or not ? Pictures in attachment |
Which book is that please? ____________________ Now: A100, GT250A, XJ598, FZ750
MarJay |
Easy-X |
Posted: 15:12 - 06 Jan 2021 Post subject: |
Just to kick off a great Internet argument you can and should turbo a 2-stroke...
...if it's a snowmobile you're using at altitude to compensate for the lower air pressure ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Robby |
Robby Dirty Old Man
Litwos7 |
c_dug |
c_dug Super Spammer
A100man |
Posted: 11:54 - 07 Jan 2021 Post subject: |
Litwos7 wrote: | A100man wrote: |
Which book is that please? |
Two stroke performance tuning second edition A. Graham Bell. (pic in attachment)
Yes turbokit is name of exhaust I should write this firstly, on stock exhaust she still spits oil but only on back of lincense plate. I know that 2 strokes are spiting oil but this is dangerous because of oil on tire :/
Tommorow I'll take the exhaust to the welder and see what response I get. |
Thanks.
I wonder if the final tail-piece can be 'slash-cut' and the end cap modified to suit. ____________________ Now: A100, GT250A, XJ598, FZ750
Riejufixing |
Riejufixing |
GSTEEL32 |
GSTEEL32 Traffic Copper
Robby |
Robby Dirty Old Man
Litwos7 |
RhynoCZ |
RhynoCZ Super Spammer
Riejufixing |
Posted: 18:01 - 07 Jan 2021 Post subject: |
Litwos7 wrote: | Riejufixing wrote: | It looks as though the baffle cone/outlet could be cut through, the outlet rotated, then welded back, and the supporting lug repositioned. I do wonder, though, what (if any) advantage this system has over "stock". Maybe, maybe not. Measurement/trial is the only way to know. |
Well the welder said me the same thing : cut rotate weld and this we are going to do and see what it will change. |
It'll look a little different, though, depending on how much you rotate the outlet. It might not need much rotation for the spatter of grot to miss the back of your bike. Hard to say how much.
EDIT: Merely rotating the pipe should not affect anything. I notr that the supporting lug is not used!
Litwos7 wrote: | But guys I'll repeat my question about muffler, is it good how its done by myself or change to it what is showed in book (attachment) ? My regrats |
So you have continued the outlet (stinger) in perforated tube, and wrapped that in rockwool or something, rather than ofsetting the "silencer tube" from the exhaust end of the the outlet? I can't see that making much difference in real life. You use this machine on the road?
Edit again: Is this exhaust exactly as indicated by a previous poster, or something you've made up yourself, or have you modified a "bought" version (which, how)? |
Litwos7 |
The last post was made 3 years, 102 days ago. Instead of replying here, would creating a new thread be more useful? |
