BenR |
BenR World Chat Champion
oilyrag |
oilyrag Nova Slayer
bikenut |
bikenut World Chat Champion
Riejufixing |
BenR |
BenR |
bikenut |
Riejufixing |
Riejufixing |
BenR |
Riejufixing |
BenR |
Posted: 15:28 - 11 Jan 2021 Post subject: |
Doesn't really show much but here's a photo of the flywheel.
https://i.postimg.cc/25cFW9sy/20210110-134818-1.jpg
I've looked at other pullers & on some of them the bolt has a little nipple on the end which I'm assuming is to sit in the end of the crank? The one I bought doesn't have this it's just a normal bolt. Anyone got any ideas how can remove the flywheel now? Cheers. ____________________ Current bikes: suzuki RG125UN wolf. Yamaha MT-07 |
Riejufixing |
bikenut |
Easy-X |
Easy-X Super Spammer
Posted: 17:08 - 11 Jan 2021 Post subject: |
Much as I try and avoid tooting my own trumpet (back problems) if you scroll half way down pg11 of my DT thread I take the flywheel off - pics, explanations... standard stuff really.
https://www.bikechatforums.com/viewtopic.php?t=328912&start=225 ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
bikenut |
BenR |
Posted: 23:46 - 11 Jan 2021 Post subject: Re: Flywheel |
https://i.postimg.cc/YqT6fyqy/20210110-134831.jpg
bikenut wrote: | I assume the flywheel hub had a fine LEFT HAND THREAD ? |
Hi no it's a righthand thread.
bikenut wrote: | You did remove the washer/washers that where under the flywheel nut before you screwed in the extractor, similar to the one in riejufixing's picture ? |
Yep.
bikenut wrote: | Which way did you screw the puller in, clockwise ? |
Yep.
bikenut wrote: | By the way, why do you want to remove the flywheel ? |
So I can get to the bolts underneath the stator plate so I can get the cases apart. ____________________ Current bikes: suzuki RG125UN wolf. Yamaha MT-07 |
Riejufixing |
BenR |
Posted: 00:54 - 12 Jan 2021 Post subject: |
Hi thanks for the comment I think the flywheel is made of cheese personally, crappy Chinese metal? I'll try & find a twin prong puller when I next get paid give that a go. Thanks for the input everyone. ____________________ Current bikes: suzuki RG125UN wolf. Yamaha MT-07 |
bikenut |
Posted: 10:01 - 12 Jan 2021 Post subject: Stuck |
Hi Ben,
So your in the shit now, but how do you get out ?
Your pictures are opening today, and it looks as if the flywheel extractor was screwed into the flywheel deep enough....
The engine is out of the bike.
The starter ring gear is welded to the flywheel.
If you look thru the larger flywheel holes, how thick is the metal that makes the flywheel "outer", 6mm or so ?
A two leg puller is a no-no, so is a three, even six leg. Why ?
The flywheel is riveted to the flywheel hub, which has the internal thread for a puller.
The thinish flywheel "outer" is not designed to be "pulled", it will just distort especially on a stuburn "client".
Can the hub internal threads be cleaned up so the oe puller can be screwed in for an other go ?
The hubs can be stuburn sometimes being well and truelly "locked" on the taper.
If you can screw in the puller for an other go, think about warming up the hub so it expands slightly to help releasing the taper.
When the puller is in and loaded, a sharp tap on the bolt can help as well, but Remember that pushing the flywheel towards the engine will "load" the big end crank pin etc..
So, threads goosed, what to do ?
Get a spare pair of hands, maybe some levers, a soft thick pad for the engine to "fall onto", a brass drift of about 17mm and a selection of hammers, with about a 17mm face.
The spare pair of hands holds the engine above the thick pad by the flywheel. Kettle of hot water, pour over hub so no hot water goes onto stator.
With the engine raised above the protective pad held by the flywheel, just by the flywheel, only by the flywheel, flywheel held, brass drift in contact with crank, a sharp tap with hammer, and with a good prey, god will allow the taper to release.
Think about this for a while..
Brass drift and the right hammer, you want to shock the taper, not rivet over the end of the crank.
Heat expands hub a bit, shock and gravity act like a slide hammer ( think about that one ) , taper releases and engine drops 2 inches onto soft protective pad.
If it doesn't work first time, go have a pannad.
Try again.
May be a heavier hammer....start light.....
If it doesn't come off, go for a pannad and try again.
Let things ( including you )cool down.
Don't forget, a "please god......" Can only help. When it does come off, a thank you God is a good thing........
Don't rush, take your time. ____________________ nuts about bikes |
BenR |
bikenut |
Posted: 12:56 - 12 Jan 2021 Post subject: No |
Vice, slide hammer, no, no, no ,no, no ffs no !!!!!
Get someone to hold the engine up by the FLYWHEEL and use a brass, ally or even a hard hard wood drift ( brass best ) and hammer, heat hub then try hitting drift to shock locked taper free.
If it don't work, walk away and have a pannad ( cuppa ). Then when calm and cool, try again with a slightly heavier hammer.
Using this method you employ gravity, and if everything "in line" all the hammer kinetics go thru crank flywheel stub, a more efficient "hit".
If your scrapping flywheel and crank, your last last last option is a drastic drastic drastic one, get the grinder out.
Saying oh come off you zdcnyitasmd! Is defeatist. ____________________ nuts about bikes |
Riejufixing |
Riejufixing |
Posted: 13:20 - 12 Jan 2021 Post subject: Re: Stuck |
BenR wrote: | I'm thinking sticking the bottom end in a vice & see if I've got an attachment for my slide hammer that I could use as a drift. As previously stated I'm not too bothered about either the crank or the flywheel as these will be getting replaced with uprated aftermarket items but I don't want to damage the cases themselves. Cheers. |
If you're not too bothered about the flywheel, you could try geting some gas on it if it needs it while you have a puller attached and with some strain on it, and then give the puller centre bolt a sharp tap with a steel hammer to see if it parts.
The big problem with your slide hammer idea is where the force goes. When you have a strain on a puller, it's "contained" within the components (crank, flywheel); the puller outer or legs pulls on the rotor, and the puller centre bolt pushes on the crank nose, and that's it. If you attach a slide hammer to the rotor, yes, it will be applying force to the rotor, but that force is not contained locally - imagine that the crank and rotor are a solid one-piece component, which they effectively are right now - when your slide hammer is used, it will be trying to pull the whole crank out through the side of the cases, which if you care about your crankcase is not what you are wanting!
Have all the threads been pulled out of the rotor? |
bikenut |
The last post was made 3 years, 104 days ago. Instead of replying here, would creating a new thread be more useful? |
