Won't start
sherm
PostPosted: 01:27 - 15 Jan 2021    Post subject: Won't start Reply with quote
Totally dead. Been working fine. Rode it yesterday. This afternoon, turn key on, no lights anywhere. Acts like blown main fuse. Checked all fuses, they look good. Batter has plenty of voltage. Run switch on. Kickstand up. Just totally dead. Any ideas?
Sherm 541 217 9590
Sherm
steve the grease
PostPosted: 01:30 - 15 Jan 2021    Post subject: Reply with quote
Bad connection on either end of the earth lead from the battery or main battery+ lead. Clean all the connectins with sand paper and put a small amount of grease on when you dothem back up Different metals - Lead battery connection onto brass terminal onto copper wire/ brass terminal onto steel frame= Corrosion and zero current .
Are you really in Oregon?
sherm
PostPosted: 01:47 - 15 Jan 2021    Post subject: Reply with quote
I live in Arizona. Still use Oregon cell phone. I'm pretty bike savvy, but it's hard to trace wires with all the plastic.
Sherm
jaffa90
PostPosted: 11:00 - 15 Jan 2021    Post subject: Reply with quote
Has it got any voltage at the main fuse and fuse box?
PostPosted: 12:07 - 15 Jan 2021    Post subject: Reply with quote
Multimeter and work your way round from the battery.
If it is utterly and totally dead and fuses ok, how about ignition switch?
Triumph Trophy Launch Edition
oilyrag
PostPosted: 13:12 - 16 Jan 2021    Post subject: Reply with quote
What bike is it? Year and model. Does it have an alarm/immobiliser? I'd be thinking like the others battery, ignition switch and connector. Connection at the starter relay too. On a lot of bike the power for everything comes through the connections at the starter relay. If it has an alarm/immobiliser that could have died.
The last post was made 3 years, 100 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.67 - MySQL Queries: 17 - Page Size: 47.66 Kb
