trevor saxe-coburg-gotha |
ThatDippyTwat |
Riejufixing |
MCN |
MCN Super Spammer
steve the grease |
doggone |
doggone World Chat Champion
WD Forte |
WD Forte World Chat Champion
steve the grease |
oilyrag |
oilyrag Nova Slayer
Hong Kong Phooey |
Posted: 11:21 - 17 Jan 2021 Post subject: |
A small tank compressor with a low power motor, e.g. 25L/1hp will be running at 100% duty cycle and even then you'd have to stop every few minutes while the tank refills. The nozzles on most paint guns won't like thick oil, it'll adjust a bit but unless you have the correct nozzle forget it. Gravity fed guns are better, but even these will make a considerable overspray.
Bigger compessors are expensive, I extended the tank on my setup by adding an old butane gas bottle to one of the outlets. Even ths won't work for large paint jobs, as even at 75 litres, the motor isn't 3hp, which would be the minimum I'd recommmend.
I recently refurbed the front room and bought a cheap HVLP setup from Machine Mart. Two coats of thin watery emulsion onto bare plaster and it gave a perfect finish, with hardly any paint used. Overspray was less than on a high pressure gun, but I still wouldn't risk using it to paint in a carpeted room.
https://www.machinemart.co.uk/p/clarke-apk900-hvlp-floor-based-electric-spray/
The HVLP setup is very sensitive to viscosity, you get a flow cup included in that setup, to help you judge the amount of 'thinners' to add. Once the flow is correct it works great, make sure you're filtering anything you put in the cup.
This particular rig might be a pain if you're doing a huge area, as the tank attached to the gun is only small, so you'd be refilling it a lot.
There's also this (cheaper) option, no experience of it though.
https://www.machinemart.co.uk/p/clarke-cas110-electric-spray-gun/
TLDR, compressor setup is expensive, HVLP all day. ____________________
Riejufixing |
Hong Kong Phooey |
Riejufixing |
MCN |
MCN Super Spammer
oilyrag |
oilyrag Nova Slayer
Riejufixing |
The last post was made 3 years, 97 days ago. Instead of replying here, would creating a new thread be more useful? |
