FKX |
FKX Derestricted Danger
Posted: 14:52 - 24 Jan 2021 Post subject: Duke 2019 30 amp blowing |
Hello, I was wondering if I could get any advice as the shops closed today and the bikes not due for a service till Feb.
My main 30 amp fuse keeps blowing out, no other fuses have. So far it has had a new battery as the old one failed to hold its charge and had a dead sell. Fowler's Bristol said they spent 5 hours checking the electronics however I feel they are having me in since they said the new battery would resolve issues yet 24 hours later it's still going.
So it's blown with the bars turned and not turned, of which the bikes idle in N on the drive and I am just popping the throttle to 3k rpm.
I notice the revs drop below 1k after a lil pop then it dies (30amp) gone. I also noticed a clicking around the head, spark plug area.
Also it seems more so when the bike is wet and battery near full charge (before and after new battery) The wiring I can get to seems intact however I can't get under the fuel tank properly.
The TFT display also is allowing water and moisture in and the indicators sometimes do there own thing.
I think the voltage regulator could be the issue personally however if anyone can suggest options or things to try please help
It's a white 2019 125 still under warranty however fowler's Bristol have kinda given the impression they want to avoid warranty to charge me just because. |
FKX |
Posted: 14:53 - 24 Jan 2021 Post subject: |
Update: I powered the bike on after disconnecting a cable thats in the battery bay, could be to the voltage reg or from the alternator as the voltage sat at 11.8 and it seemed happy with me popping the throttle, mind yesterday when the bike was dry i manged with no issue to add 30 miles to the bike on a trip.
Anyway, cable disconnected, got the the shop and the voltage sat at 11.4, it did dip to 11.2. Went in the shop and came out, reconnected the cable and i got home okay with voltage stable at 13.2/3
I should add i have managed to disconnect the cable okay with the bike on turning over on the drive idle and reconnected it 3 times (power off and back on , disconnect, leave 2 mins, reconnect), 2 of which the main fuse blew
im trying all sorts to see what it could be.
I also have noticed one ground, on the spark ignition was rusted to shit so i have sanded it down for better contact - this was before my 30 mile trip. Overnight it frosted over so today the bike was wet, and the fuse 30 amp blew twice before my trip to the shop with the cable disconnected |
oilyrag |
oilyrag Nova Slayer
FKX |
Posted: 17:38 - 24 Jan 2021 Post subject: |
I have done some checks on the bike battery and they are as follows
Voltages are as follows
off - 12.20
on - 11.86, dropped to 11.84 (1 min ish)
on idle 12.68 on start - 1 min in 12.75-12.90 2 mins in ish 12.8-9 fluctuation between
on 5k - 13.16/13.20
could anyone advise what this particular cable is please?
https://ibb.co/3Bf7y06
Fowler's Bristol are refusing to do warranty, the bike has 7 months left however they are giving every excuse/attempt to avoid doing any work. I do not wish to keep going back and forth and having the work half done due to lazyness
They have refused to replace the indicator box, and the tft display of which the box is shorting out and the display fails at times when riding by going blank and letting water get inside. I wish i could speak to ktm uk directly to report these actions
I have the wire diagram here however its not too clear
https://www.fowlersparts.co.uk/parts/5966283/road-125cc-2017/wiring-harness
Image URL as it failed in preview
https://ibb.co/3Bf7y06 |
sickpup |
sickpup Old Timer
FKX |
sickpup |
sickpup Old Timer
FKX |
sickpup |
sickpup Old Timer
Nobby the Bastard |
There is a gap of 187 days between these two posts... |
FKX |
Islander |
Islander World Chat Champion
Nobby the Bastard |
Islander |
FKX |
Nobby the Bastard |
MarJay |
MarJay But it's British!
UncleFester |
FKX |
Islander |
xX-Alex-Xx |
Nobby the Bastard |
WD Forte |
WD Forte World Chat Champion
FKX |
Islander |
The last post was made 2 years, 237 days ago. Instead of replying here, would creating a new thread be more useful? |
