MG#43 |
MG#43 Nova Slayer
Posted: 12:44 - 03 Mar 2021 Post subject: Engine locking then unlocking, then locking...etc... |
Hi all, hope everyone is all good and looking forward to spring!
Got a weird one...weird to me anyways...
My engine and cams are out of my bike.
On turning the crank by hand it locks up after about 20 secs of sitting still. I then need apply alot more pressure using a wrench and it turns happily for as long as i wish to sit and turn it for. But if i stop it locks up again but oddly only after about 20 secs... After 1-20 secs it seems ok, but after this it's locked. It's like something is slowly returning to a position after these seconds where it gets stuck.
It did the same thing with the transmission removed so to me seems clear bottom end is damaged somehow but i can't explain why it will free up then lock again... As mentioned cams removed so timing and valves are not at fault in terms of the engine turning (my view).
Anyone dealt with something similar...?
Thanks!! |
Polarbear |
Polarbear Super Spammer
Weisse Schlange |
Weisse Schlange Spanner Monkey
MG#43 |
MG#43 Nova Slayer
Nobby the Bastard |
MG#43 |
MG#43 Nova Slayer
steve the grease |
Posted: 14:15 - 03 Mar 2021 Post subject: |
Was this bike running , or is it a project. It sounds to me like you need to do a bit more stripping down , the barrels off at least, if its not just going tight because of ' sticktion' you need to find out exactly what is causing the problem , maybe the bore needs a quick hone, maybe one of the rings is gummed , maybe one of the bearings is jamming . Without a more thorough stripdown you will never know. ____________________ All the above is my personal opinion, you can see my lips move, but I'm talking out of my arse.
I've been riding, and fixing , bikes for 50 years, in that time the more I learn, the less I am absolutely sure of..... |
MG#43 |
MG#43 Nova Slayer
Posted: 14:26 - 03 Mar 2021 Post subject: |
steve the grease wrote: | Was this bike running , or is it a project. It sounds to me like you need to do a bit more stripping down , the barrels off at least, if its not just going tight because of ' sticktion' you need to find out exactly what is causing the problem , maybe the bore needs a quick hone, maybe one of the rings is gummed , maybe one of the bearings is jamming . Without a more thorough stripdown you will never know. |
i hear you steve, but I'm in new territory here, thats my next step as for now i consider it pretty shagged.
The engine was fine before, only a gear selection issue was present. The only thing that makes sense to me is the cam chain slipped while it was being worked on upside down, when it was all put back together the auto adjuster had come out to take the extra slack, then when the engine rotated created a tight cam chain which then when rotating further created a ring or conrod bend. Still doesn't account for the fact you push past this and it seems ok until you leave it again... |
MarJay |
MarJay But it's British!
MG#43 |
MG#43 Nova Slayer
Posted: 14:52 - 03 Mar 2021 Post subject: |
MarJay wrote: | Sounds like it could be hydraulic lock. Maybe there is liquid petrol building up on the inlet valves, and turning the crank allows the petrol in, and then it seeps past the rings allowing you to turn it again? That's my first thought, could be nonsense, but it was nevertheless what popped into my head.
Sounds bad to me anyway. |
thanks, I've read about this, but i think once it frees up it should spit out what ever was above the pistons out via (in general) the spark plugs holes from where it was put in, anti-cease liquid, fuel, wd40 etc... but I think you're onto something with the way it takes a bit of time to lock again, but now the cams are removed there's no real compression as you would expect, so although the valves are in situ they are not opening and closing.... so you rotate it the 'liquid' moves around, when it's left to settle it seeps down then creates another hydro lock...? |
sickpup |
sickpup Old Timer
MG#43 |
MG#43 Nova Slayer
sickpup |
sickpup Old Timer
MG#43 |
MG#43 Nova Slayer
A100man |
A100man World Chat Champion
Posted: 17:36 - 03 Mar 2021 Post subject: |
with no tension on the cam chain it 'could' be getting snagged up
I'd have that out too.. they're cheap enough to replace, then the head off.. then the barrels.. process of elimination it has to be right? ____________________ Now: A100, GT250A, XJ598, FZ750
MG#43 |
MG#43 Nova Slayer
steve the grease |
Posted: 19:29 - 03 Mar 2021 Post subject: |
About the worst it could be is a roller bearing where one of the rollers has a flat on it and jams rather than turning, once turning it will carry on turning , yeah , it's unlikely , but it does happen.
You mention that it's pretty ' shagged', I think its likely that once the top end is off you will have a free running bottom end , if you don't and it's still stiff you've got problems.
My best bet is a plantpot shaped bore ( the classic wear pattern) and a jammed, broken or gummed ring(s). If that's the case don't use caustic ( oven cleaner aerosol) on aluminium it eats it. Boil the piston in a pan to free the rings off , then scrape all the crap off with scrapers , scissors, scrubber dubber pads, sharpened electrical screwdriver etc etc. Let us know how you get on. ____________________ All the above is my personal opinion, you can see my lips move, but I'm talking out of my arse.
Lone-Wolf |
Lone-Wolf World Chat Champion
A100man |
Posted: 12:19 - 04 Mar 2021 Post subject: |
steve the grease |
pepperami |
pepperami Super Spammer
mentalboy |
mentalboy World Chat Champion
MG#43 |
MG#43 Nova Slayer
The last post was made 3 years, 49 days ago. Instead of replying here, would creating a new thread be more useful? |
