WheelieKid |
WheelieKid Derestricted Danger
bikenut |
bikenut World Chat Champion
WheelieKid |
bikenut |
KiwiBob |
KiwiBob Borekit Bruiser
MCN |
MCN Super Spammer
Robby |
Robby Dirty Old Man
WheelieKid |
MCN |
MCN Super Spammer
Robby |
Robby Dirty Old Man
WheelieKid |
Easy-X |
Easy-X Super Spammer
Robby |
Robby Dirty Old Man
Posted: 23:00 - 11 Mar 2021 Post subject: |
A bit of water in the fuel tank happens from sitting, particularly if the tank is not full. Condensation from the air collects on the steel sides of the tank, and rolls down into the petrol and sits underneath it.
However, the amount of water you get from this is negligible. If the tank has sat long enough for water to be a problem to the bike running, the fuel has gone off and the tank has probably rusted quite a bit as well. Multiple years.
More typical, the rubber sealing ring under the fuel filler cap goes hard and stops making a good seal, combined with the bike living outside in the rain, without a cover. Leave a bike like that for a couple of months over winter and you'll have a pint of water in the bottom of the fuel tank.
Ethanol is a whole different bag of issues. On the one hand, it's hygroscopic so it absorbs water out of the air and eventually allows the water to separate out. On the other hand, it's hygroscopic so it will absorb small amounts of water without affecting its viability as fuel. For daily use, that means I prefer it - water doesn't get to accumulate at the bottom of my fuel tank, it gets absorbed and burnt with the petrol/ethanol mix. |
WheelieKid |
Easy-X |
Posted: 14:41 - 13 Mar 2021 Post subject: |
With a multimeter the basic checks are:
Voltage of battery (should be >12V, 13~14V ideal)
Voltage of battery when turning over (if it turns over) it'll drop a bit and dance around but give us a rough idea of what it does.
Voltage of battery while idling and with some revs (again, if you can even start it!) just to get an idea of what the charging system is pushing to it.
After that you can do things like checking fuses with the continuity check feature of the multimeter, use the voltage function to trace the path of the hot wire, e.g. "hmm, red wire goes from battery to ignition but I'm not seeing any voltage there..." and so on.
A whole world opens up! Just remember that the frame of the bike is used as a common earth (i.e. connected to the negative terminal of the battery.) ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Nobby the Bastard |
bypass2 |
bypass2 Spanner Monkey
WheelieKid |
WheelieKid |
Posted: 15:19 - 24 Apr 2021 Post subject: |
I still find that improbable, I'd have expected it to throw a pushrod first. They usually just bounce the valves if you over-rev them.
I think that must be some sort of record. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
WheelieKid |
WheelieKid |
Nobby the Bastard |
The last post was made 2 years, 364 days ago. Instead of replying here, would creating a new thread be more useful? |
