WD Forte |
WD Forte World Chat Champion
Posted: 18:32 - 14 Mar 2021 Post subject: |
This may help
https://zonalimitatore.blogspot.com/2016/02/panasonic-na107vc4-e-il-problema-della.html
https://3.bp.blogspot.com/-4ihcSTiSPQ4/Vsw7oxTuutI/AAAAAAAAENE/os4WN7qDIbs/s640/IMG_20160104_110544.jpg
Translation:
I would like to share with you a problem I had with this washing machine model.
Since I had asked for various info for the web, without receiving an answer and given the hallucinating price of the new card (160 € for a circuit that costs maybe 30 €) I wanted to understand why the washing and spinning did not work.
In practice, the washing machine worked, but when it was time to give the consent to the motor to run, nothing happened, and after a few seconds it went into error with the word END and the buzzer.
I obviously checked if there was continuity on the brush / motor / board cables and everything was ok.
Since the problem did not always arise, I wanted to concentrate on the electronic board.
In fact, when it worked, the relay switched on and off normally. When it didn't work, there was no CLACK on the part of the relay.
Once I checked that the 4 relays were not blocked, I replaced the components circled in blue, and now, finally, it works as before !!!!!!! ____________________ bikers smell of wee |
Posted: 19:22 - 14 Mar 2021 Post subject: |
WD Forte wrote: | This may help
Translation:
Once I checked that the 4 relays were not blocked, I replaced the components circled in blue, and now, finally, it works as before !!!!!!! |
Well spank my arse and call me Charlie! That looks hell of a familiar.
It just occurred to me that the household power supply cut out last weekend. main breaker popped. I could see no reason for it at the time but it now occurrs that the washing machine hasn't worked properly since.
I have literally just been poking about at that relay because look at the board on the back of it.
https://lh3.googleusercontent.com/pw/ACtC-3f8qWiWeuSWixuY2eLMeXxLZ4ER9AJoQO2mKWx3oK17VvJyujWVbf-srLiQRM-bKyQGmVF7yGUuokJSOG1Bq0F5MjtlWnv2PA8vaaRN-_wiNVa275ADnnoKSCkAZjsEKslYKebh6TUIZQPlbrjZygjj=w1529-h860-no
Those melty bits are the main power feed to the board relay and the switched live from it. All still seem to have continuity. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Easy-X |
Easy-X Super Spammer
Posted: 19:41 - 14 Mar 2021 Post subject: |
At a glance it does look like enough heat damage to slightly reflow the solder
Might want to have a look through CPC Components, Farnell & RS for all the discrete components in that area and replace them en masse rather than trying to figure out the specific one that's gone wonky. ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Islander |
Islander World Chat Champion
Posted: 19:49 - 14 Mar 2021 Post subject: |
The diodes can be replaced with 1N4007 (higher reverse voltage than 1N4001), the resistor is 100 ohms 2 watt +/- 10% tolerance. The capacitors - just read off of the can.
It looks like a rectifier circuit - probably to run the relay coil. |
WD Forte |
Posted: 20:27 - 14 Mar 2021 Post subject: |
For the £1.50 or so it costs
I'd change that relay
Omron G5lA-1-VD24 ( not E! got comfused for a mo)
Even if you reflow it, the contacts may well have been arcing for years
and be in poor state
I've used lots of this type and heres how they work
Power in on A pad
Normally Closed to B pad and share track too so same potential/no arcing
Switches to Normally Open contact at C most prone to arc/heat
Blue dots show the relay actuator coil pads, low current little arcing
https://imgur.com/vWhc5bE.jpg ____________________ bikers smell of wee |
andym |
andym World Chat Champion
WD Forte |
Posted: 23:56 - 14 Mar 2021 Post subject: |
If i didn't already have it I'd want a circa 50W regulated iron with smallish tip and solder sucker similar to the ones in the pic.
plus resin cored lead/tin solder, fuck that lead free shite.
My usual practise is to tin the iron and add some fresh solder to the pads
as this usually helps me remove old solder before lifting components
off the board or reflowing.
I have a Weller gun type iron but that's used for big stuff not pcbs.
It could easily add to much heat and lift the track off the
board if you're not very careful.
https://www.hobbyrc.co.uk/content/images/thumbs/0006351_engineer-ss-02-solder-sucker.jpeg ____________________ bikers smell of wee |
Posted: 00:20 - 15 Mar 2021 Post subject: |
I've got a gas soldering iron too with some very pointy tips. i don't generally use it because it doesn't get hot enough to flow solder into a spade terminal before the insualtion starts to melt... Sounds like this may be the exact property I'm looking for? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Islander |
MCN |
MCN Super Spammer
Posted: 23:09 - 17 Mar 2021 Post subject: |
Not bothered my Arse to read the full thread.
Most modern washing machines use VFD motors as the speed control is more reliable (until it fails).
I don't know the test procedure for VFD motors differs too much from non-VFD motors.
I'd go for the control card as motors are really reliable as most are brushless.
Bearings failure would have been very evident before sudden failure.
I've had the same Bosch washer for 20 years. And dish washer. Fridge went on fire when I was out of the Cuntry. I never knew about it. It still worked fine but the freezer had a melted plate and heat discoloration. Found out years later that they had cases of houses burning down due to 'frost free' fridges catching fire.
The frost free thing is a little heating coil in the freezer. The top fridge part is cooled by Air blown around from the bottom part where the heater is. Sorry for the side track OP. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
Posted: 01:04 - 18 Mar 2021 Post subject: |
Parts are incoming. I had a slight Father Ted moment with my first order. Accidentally a 100uf capacitor instead of a 10uf. It was a bit "This capacitor is very small, that one is far away.".
I've had to order all sorts of shit I didn't need too because farnell stock all the stuff but you have to spend £17.50 +VAT to get free delivery and I'm not paying £6 delivery on a 45p bag of capacitors.
Every single seller of small volume electronic componants on ebay seems to be drop-shipping, quoting delivery times in excess of a week. I know farnell dispatch on the day of ordering.
I am now the proud owner of new secateurs, some spare hoover bags and a new pair of work trousers... 5 capacitors, a steel ruler and some new G-clamps should be arriving tomorrow. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
WD Forte |
A100man |
A100man World Chat Champion
Posted: 10:44 - 18 Mar 2021 Post subject: |
stinkwheel wrote: |
I am now the proud owner of new secateurs, some spare hoover bags and a new pair of work trousers... 5 capacitors, a steel ruler and some new G-clamps should be arriving tomorrow. |
____________________ Now: A100, GT250A, XJ598, FZ750
MCN |
MCN Super Spammer
Islander |
Posted: 13:51 - 18 Mar 2021 Post subject: |
All you've done is to reflow the pre-existing tinning on the PCB tracks.
When they assemble boards like this they pass them over a molten bath of solder at a predetermined height that corresponds with a mechanically generated standing wave. This solders the bare components in but will also tin any naked copper tracks. It'll also allow the tracks to carry a heavier current which may be why they've left them unvarnished to tin. By all means run a clean tinned soldering iron tip over them to reflow the duller stuff but it really isn't necessary. |
Islander |
Easy-X |
Posted: 14:14 - 18 Mar 2021 Post subject: |
It's gone shiny where the solder has reflowed but it doesn't look like any has spontaneously evaporated or dropped off. It's a symptom not an actual problem.
The main thing to look for is around the legs of components. If there's a bit of a valley or even a gap you could see daylight through, dab it with some fresh solder ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
WD Forte |
Posted: 22:27 - 19 Mar 2021 Post subject: |
I think this thing is fucked. I replaced the componants described above. I have them the right way round and they are making good contact. Nothing appeared to be fried. It is now bricked, nothing powering up or on at all.
That relay with the melted solder tracks actually powers the heating element. Nothing to do with the motor.
Power is coming into the PCB and getting through the switch but it's not getting to the low voltage side.
I have found something distinctly fishy though. This smoky bit, with the IC attached is reading over 700V AC. That can't be right?
https://lh3.googleusercontent.com/pw/ACtC-3c0omBJfYXai-TcCtstoIYZGLH4Pre3h1JFFkbYD5ugtKn7c9TqX8LcIamFWSUngfDxou1ovduR5zXimXtPKRglUB7ZcaDV91AmgGJRbU5FfCNN7L4a6S3kjpzrOawzZcM64fpLSQMr7JAwVUy9w_w2=w484-h860-no
I'm nearly ready to call this thing dead and order another one. I reckon it's cooked something that can't be easily fixed. I have however learned how to solder componants to a PCB and the whole exercise has cost me less than £20 in parts and less than £10 in new tools (which I still have).
I can't find any references to that chip E9217, what it is and what it does (which may explain why it has smoky stuff under it). I'm pretty sure it shouldn't have over 700VAC on the pins all down one side of it though. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Islander |
Posted: 22:48 - 19 Mar 2021 Post subject: |
I think that's a buck regulator (switched mode power supply) chip. The four pins would be the drain if it is. Have a look at this and compare the circuit arrangements on the board with the example circuit.
https://components101.com/ics/viper12a-smps-buck-regulator |
WD Forte |
Posted: 23:07 - 19 Mar 2021 Post subject: |
I looked that IC up a while back but didn't want to mention it
and maybe over complicate things.
I cant see the board or track clearly enough to work out what's what
and what's going where
(even if you can, fault finding an unknown board can still be a laborious process without a
circuit diagram)
but what with the resistor, diode, smoothing caps and transformer nearby
and the 4 commoned pins, I suspect it might be switching regulator
related of the Viper22A smps control IC
summary:
"The VIPER22A controller can convert AC voltage from 85V to 265V and convert it to regulated DC voltage"
pinout and more detailed info here :
https://components101.com/ics/viper22a-smps-controller
edit: ah, I see Islander is ahead of me ____________________ bikers smell of wee |
WD Forte |
Posted: 23:13 - 19 Mar 2021 Post subject: |
I spose now you'll be wanting a hot air rework set for the smds ____________________ bikers smell of wee |
The last post was made 3 years, 38 days ago. Instead of replying here, would creating a new thread be more useful? |
