| Dan87 |
 Dan87 Renault 5 Driver
| stinkwheel |
 Posted: 17:48 - 21 Mar 2021 Post subject: |
You are right in what you are doing, push the clips in and pull up on the red part.
It's not just the fuse in there, there is a connector block too which is probably a bit corroded and stuck. The one on Mrs stinkwheels CBR6 was a bit on the tight side too. Soak it liberally with WD40, particularly trying to squirt it up under the cover and leave it to sit for a bit before trying again. Wiggling side to side and pulling while holding the tabs in seems best. If your fingers are getting sore, you could put a cable tie on the tabs to hold them in. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Dan87 |
 Posted: 19:20 - 21 Mar 2021 Post subject: |
Cheers fella, will give wd40 a bash tonight and come back tomorrow after I grabbed the fuse.
Thanks again  |
| jeffyjeff |
 jeffyjeff World Chat Champion
| stinkwheel |
| jeffyjeff |
| Kawasaki Jimbo |
 Kawasaki Jimbo World Chat Champion
| jaffa90 |
 jaffa90 World Chat Champion
| jeffyjeff |
| Kawasaki Jimbo |
 Posted: 09:39 - 23 Mar 2021 Post subject: |
I’m not saying go straight to full retard. Start with technique, then gentle persuasion, but I expect it won’t budge until you reach the last shit-or-bust stage. Then you’ll be thinking, “Shoulda gone straight there,” but the one time you do... Doh! |
| droog |
 droog Spanner Monkey
| steve the grease |
 steve the grease Crazy Courier
The last post was made 5 years, 96 days ago. Instead of replying here, would creating a new thread be more useful? |
