Strange issue with XR125L
roccoEE
PostPosted: 16:39 - 02 Apr 2021    Post subject: Strange issue with XR125L Reply with quote
Hi folks.
Have just started riding my xr125 with the nice weather and all and its all fine and dandy but if i stall the bike or turn off the ignition and turn it back on again the bike will be dead. No headlight or clock lights. It didn't do this before and it seems to have gotten progressively worse.
I don't think its the battery because it fixes itself after about 10 min. If i come back to it and turn the key on it will fire up straight away.
I have tried cleaning the engine ground it didn't make a difference.
And also unplugging kickstand sensor, break sensor and clutch sensor
Any suggestions open to trying
PostPosted: 17:08 - 02 Apr 2021    Post subject: Reply with quote
How long between starting initially a d stalling?
roccoEE
PostPosted: 17:10 - 02 Apr 2021    Post subject: Reply with quote
Can be literally 2 min after i have started it but it does not go off until i turn off the key. the bike will run fine all day long until i turn it off and on again
PostPosted: 17:24 - 02 Apr 2021    Post subject: Reply with quote
Its the ignition switch.
roccoEE
PostPosted: 23:00 - 11 Apr 2021    Post subject: Reply with quote
Doesn't seem to be the ignition switch. I unplugged it and tested it with a meter working fine.
The bike will start just fine but after a few seconds the battery will disconnect and the neutral light will flicker dimply while stilling running.
If I turn the bike off it will not come back on until I wait for a period of time. I'm guessing some kind of relay is getting stuck?
jaffa90
PostPosted: 00:16 - 12 Apr 2021    Post subject: Reply with quote
More info, how old? R,U, using kick or electric start?
If the battery is rejuvenating / regenerating itself what is killing it when riding? Any battery voltage readings at any / all stages?
Have you a voltage reading at the fuse/s box when dead ?
roccoEE
PostPosted: 18:00 - 13 Apr 2021    Post subject: Reply with quote
2003 Model year. Not sure where the fuse box is or even if there is a main fuse box. The battery will still disconnect while the battery charger is hooked up so its not a low voltage issue
jaffa90
PostPosted: 18:38 - 13 Apr 2021    Post subject: Reply with quote
"""The battery will still disconnect while the battery charger is hooked up so its not a low voltage issue""
So you are riding the bike with the charger hooked up?
You come on here for advice but not answer questions.
roccoEE
PostPosted: 20:35 - 14 Apr 2021    Post subject: Reply with quote
No im not riding the bike with the charger hooked up.
Its not a battery voltage issue. The battery seems to disconnect from the rest of the bike after startup and does not reconnect until after a short while
jaffa90
PostPosted: 22:06 - 14 Apr 2021    Post subject: Reply with quote
Has the battery got good connections to the bike (follow the leads)?
P.
PostPosted: 22:07 - 14 Apr 2021    Post subject: Reply with quote
remove the ignition switch and wire it together like a true criminal. Problem goes away... its probably the switch.
The last post was made 3 years, 10 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.68 - MySQL Queries: 17 - Page Size: 67.77 Kb
