stirlinggaz |
stirlinggaz World Chat Champion
jaffa90 |
jaffa90 World Chat Champion
jeffyjeff |
jeffyjeff World Chat Champion
stirlinggaz |
davebike |
davebike World Chat Champion
Posted: 08:04 - 13 Apr 2021 Post subject: |
Lots of penetrating oil and time soak fiddle soak rest soak fiddle and on
WD40 is OK but there are better penetrating oils ____________________ Dave
NC750Xdct + others at work !
davebike1@gmail.com |
jaffa90 |
Islander |
Islander World Chat Champion
ThatDippyTwat |
Posted: 12:42 - 13 Apr 2021 Post subject: |
I's soak it in a mix of paraffin and ATF as a penetrant. I'd probably put it in a jam jar full and leave it to sit.
Once it's moving freely, as Islander said, thoroughly de-grease then lube appropriately (silicone spray is good). Isopropyl alcohol would be a good de-greaser in this situation.
Another thing to consider is giving it a blast in an ultrasonic cleaner. Might rattle stuff loose.
I've seen some locks that have a small hole in the bottom you can get a fine punch into and tap the key out. Obviously this risks having both a key AND a snapped off punch stuck in your lock. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
MCN |
MCN Super Spammer
BigTim |
BigTim Trackday Trickster
stirlinggaz |
MCN |
MCN Super Spammer
Islander |
Islander |
MCN |
MCN Super Spammer
Posted: 01:37 - 17 Apr 2021 Post subject: |
Islander wrote: |
He's quite something. If you're interested in locksport then Bosnian Bill is worth a watch too. |
https://youtu.be/t2l4PVJkhzQ ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
stirlinggaz |
Posted: 02:09 - 27 Apr 2021 Post subject: |
Nope, definitely correct key(s).
I bought it about 20yrs ago but ended up not using it.
I put the key in the barrel so I didn't get it mixed up with all the other ignition locks I have.
The box is damaged & unreadable so might have got wet.
I don't think I bought a matching matching fuel cap or seat lock.
Anyway, its now working, finally.
After getting the key out, I left it soaking in atf/parrafin & finally got around to it over w/end.
It's now turning fine & steering locks working, which I think was the problem.
Cleaned it up with brake cleaner & it will now sit for another 20yrs beside all the other things that will "come in handy some day".
Thanks to all for the advice.
cheers,
GAZ
ps : lock picking lawyer is cool, seen loads of his vids. |
The last post was made 2 years, 364 days ago. Instead of replying here, would creating a new thread be more useful? |
