Tyres - mixing? And now an added bonus service question!
twooo
PostPosted: 07:13 - 11 May 2021    Post subject: Tyres - mixing? And now an added bonus service question! Reply with quote
I need a new rear tyre on my Street Triple, but my front tyre has about 5mm tread left on it.
Now that I am back at work, I am using it to commute into London everyday (80 mile round trip) which is a three-way split between rural country roads, 15 miles motorway/DC and inner city riding.
Currently it has Pirelli Diablo Rosso 3 tyres on it which have been excellent but am toying with getting it shod in something a little bit more hard wearing, like Pirelli's Angel GT or Metzeler's Roadtec 01.
Can I simply put one of these on and then replace the front with a matching tyre when it needs to, or do I need to buy a Rosso 3 rear and then replace the two together when they are both worn down?
Will my bike kill me at the first bend with un-matching tyres on it?
Thanks all
Cheers, 2
davebike
PostPosted: 07:19 - 11 May 2021    Post subject: Reply with quote
Rear less grippy than front is very seldom an issue
Me I don't care I mix tyre all the time makes versions new old "whatever"
Dave
NC750Xdct + others at work !
davebike1@gmail.com
twooo
PostPosted: 07:39 - 11 May 2021    Post subject: Reply with quote
Thanks
Cheers, 2
arry
PostPosted: 08:34 - 11 May 2021    Post subject: Reply with quote
On a commute, upright into London, I'd not worry about it.
Fizzer Thou
PostPosted: 20:30 - 11 May 2021    Post subject: Reply with quote
Rode 2600 miles around froggyland back in 2014 with a part worn Pirelli Diablo Corsa III on the front of the R1 and a new Michelin PR3 rear.It did not slip or slide under all of the different weather conditions that I encountered.Great fun Very Happy
Always have a 'Plan B'
twooo
PostPosted: 21:21 - 11 May 2021    Post subject: Reply with quote
Thanks. That's what I pretty much figured. Spoke to a Triumph dealer about getting it replaced along with it's 12k service and they wouldn't even entertain the idea of mixing tyres and would only fit a Diablo Rossi unless I fitted both tyres.
As an aside, the 12k major service. Proper Triumph dealer or will an independent but respected garage? Is the perceived prestige of that service stamp worth anything? I'd much rather give my money to an independent local firm if I can.
Cheers, 2
PostPosted: 10:36 - 12 May 2021    Post subject: Reply with quote
What year is your bike? Is it in warranty? If it's in warranty you kind of have to take it to a Triumph dealer. If not, then go for a trusted independent.
PostPosted: 12:52 - 12 May 2021    Post subject: Reply with quote
Are they implying that they will void the warranty if someone else fits a tyre plus also they are the only ones allowed to specify what brand?
Horse-shit. IMHO.
PS Don't mix radial and cross ply on the same axle Wink
twooo
PostPosted: 14:32 - 12 May 2021    Post subject: Reply with quote
2014 Street Triple. No warranty as I bought it privately last year.
Cheers, 2
recman
PostPosted: 14:40 - 12 May 2021    Post subject: Reply with quote
Personally I've never taken my bike to a Triumph dealer for a service.
Come to think of it, I've never taken it to any dealer for a service.
On the subject of tyres, I begrudgingly changed mine after an advisory from the previous MOT.
The rear I could understand but the front didn't warrant changing imo.
blurredman
PostPosted: 18:09 - 12 May 2021    Post subject: Reply with quote
I think it's a marketing technique that delves from the different ply design that car tyres used to commonly describe as not being mixable, as A100man says, on the same axle which isn't really a thing anymore (but different sized tyres on the same axle is still unprefered and an MOT fail- although contradictory space savers are okay...).
Anyway - I mix bike tyres constantly. When 1 wears to bone- it gets changed as an individual.
Current: 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (bored to 295cc) - 38k, 1990 MZ ETZ251 - 49k, 1979 Suzuki TS185ER - 9k, 1973 MZ ES250/2 - 17k.
PostPosted: 18:13 - 12 May 2021    Post subject: Reply with quote
Take it to an independent, fit a Angel ST on the rear and save £.
Pigeon
PostPosted: 00:40 - 18 May 2021    Post subject: Reply with quote
Sticky front, harder wearing rear is fairly normal. Just make sure things are warmed up before pushing on.
I've had Roadtec 01, Rosso 2, Roadsmart 3, Pilot Road 4, S22 on Striple
Would happily mix a Roadtec 01 rear with Rosso front if you wanted more miles off rear, but grip at front (in dry).
Roadsmart are more miles, but go a bit wooden after 4k. Still a decent rear option though for more miles.
Probably wouldn't mix a Pilot Road 4/5 rear with a Rosso front. Simply because the Pilot Roads can push straight off the bat, plus push really well in the wet (when the Rosso front is taking time to warm up and sucks on the wet).
But if you are patient with warm up and not looking to go crazy in the wet. Then a PR4 rear would mix with a Rosso Corsa front.
EDIT:
+1 Thumbs Up
12k service = plugs, filters, oil, coolant; replace. Wheel+linkage bearing, valves check + timing adjustment via cams.
The big thing being valve check + cam adjustment.
It's circa a £750 dealer job, or £350 local dude.
Obtaining proof of work done by either party requires you being there, or them taking timestamped / custard photos.
So what is your level of belief it will be done, vs how much is that stamp worth.
If its not stamped, its a £500 haggle and £250 reduction in likelihood.
I did my '13 valves a couple of times, and the first it was on limit of tight so I shimmed to the middle and adjusted the cams sprockets.
The second was 15k later and it hadn't moved.
So it seems, depending on where the engine was set (assuming reasonable oil + changes) is where it will stay for a long time.
At best, its probably a £500 haggle and wouldn't put people off.
I probably wouldn't believe the work had been done without evidence anyway, and would re-do it. In other words, to buyers, they'll use it to reduce price, but not much and will still buy anyway as long as mileage isn't crazy past schedule.
The last post was made 2 years, 334 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.6 - MySQL Queries: 17 - Page Size: 85.45 Kb
