Nyilka |
Nyilka Derestricted Danger
xX-Alex-Xx |
Islander |
Islander World Chat Champion
Nyilka |
Nyilka |
MCN |
MCN Super Spammer
WD Forte |
WD Forte World Chat Champion
Nyilka |
Kawasaki Jimbo |
Nyilka |
arry |
arry Super Spammer
xX-Alex-Xx |
Nyilka |
Nyilka |
Nyilka |
Nyilka |
Robby |
Robby Dirty Old Man
Nyilka |
Posted: 15:58 - 25 May 2021 Post subject: |
Robby wrote: | CBR125s use a 6Ah battery as standard, so I'm not surprised you broke them with a 4A charger. Smart battery chargers for bike batteries tend to top out at 0.8A, and can charge at a lower rate than that.
That said, I would still expect a new battery to have enough juice to start the bike without needing a jump start. There could well be more wrong here than the battery.
Personally I would get a smart charger on the battery you have. Green lights good, red lights bad. If you have green lights on the charger and the bike isn't starting, we need to know the symptoms - are the dash lights coming on, is it making a rapid clicking noise, is the engine turning over but just not catching?
If it will start, but the battery is flat the next day, it means you either have something drawing power (like an alarm) and/or the charging system isn't working.
Bike charging system are surprisingly bad in general. The sort of problems that might come up once 100k miles on a car may come up in 10k miles on a bike. Alarms and trackers are also a pain in the arse and easily flatten a battery in a fortnight or less. |
That'll be a good idea To, i'll order one .
When i Turn the Key With this battery , Or the earlier one after it got drained overnight , Nothing comes up , Any lights neither my starter works . If i push the bike in , and go for a 1-2 hour bikeride My turn signals are very poor , my lights too , and after i turn it on needs pushing again.
I recently observed that if I pull my front brakes my Lights and turn signals are flickering a little bit but they are very bright after i let go of the lever it starts to flicker faster until it goes very poor again , i am asuming that It has to use more power . And my Rpm counter is jumping between 0 and the Rpm that i am in . Sometimes repedatly sometimes its like a Brake compression tester. |
Kawasaki Jimbo |
Posted: 18:56 - 25 May 2021 Post subject: Re: Honda CBR 125 wont accept any Batteries |
Battery 1 was good until it swelled up after charging in September.
Killed by charger.
Battery 2 from a friend, not clear if it was used and later didn’t hold a charge, or whether it was used to somehow check against Battery 1, and showed Battery 1 wouldn’t hold a charge.
OP seems to charge batteries before use (a good thing if the charger is good) so let’s assume that happened.
Battery killed by charger?
Battery 3 from a friend again, worked for 2-3 weeks until for some reason it was charged. After reinstalling it needed a jump start but wouldn’t start of its own accord next day. Put on charge and it swelled up.
Killed by first charge. Swelled in second charge just to make it obvious.
Battery 4 bought brand new but wouldn’t work after installing.
Was this one charged before use too?
Killed by charger.
Attempts to jump start produced hella bad sparks.
Polarity issues?
New charger, new battery. Or find a local bike shop which will prep a new battery for you. |
MCN |
MCN Super Spammer
Posted: 14:34 - 26 May 2021 Post subject: |
If you had 'polarity' issues then there is a possibility the diode has been cooked in the charge system.
If you are uncertain, get it to a bike shop.
They 'should' fairly quickly find the fault and let you know.
Your looking at a bill for a couple of hours Labour.
Unless you can negotiate something....
But that might/should be less hassle and expense of fitting multiple batteries. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
The last post was made 2 years, 334 days ago. Instead of replying here, would creating a new thread be more useful? |
