| vivasheety125 |
 vivasheety125 L Plate Warrior
| Easy-X |
 Easy-X Super Spammer
 Posted: 10:29 - 02 Jun 2021 Post subject: |
~13.2V is okay but it's not great, ideally it should be ~14V with some revs. You say the replacements parts were used, I'd probably say they're a bit tired. Add to that a few lightly corroded connections and an underpowered battery I'd say your results are not totally unexpected
Just to cut to a cheap & quick solution may I suggest getting a trickle charger? ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| vivasheety125 |
| vivasheety125 |
 Posted: 17:40 - 02 Jun 2021 Post subject: |
Made some progress... I put a properly rated direct replacement battery on it and tested it. This time I'm seeing some improvements. Could it literally just have been the cheap under rated battery??
Idle:
https://i.postimg.cc/bYnm7Nn4/IMG-20210602-133821.jpg
Revving about qtr throttle:
https://i.postimg.cc/X7cQvHQ8/IMG-20210602-133916.jpg
Riding i get 14.71 flat and it doesn't move (i presume that's the regulator kicking in) when i tried revving it before i never got over 13.3v now it's 14v+
I see the idle voltage is still a little low but i do have the actual idle at a low setting it ticks over nicely but i could get away with a higher tick over so maybe i should do that to bump the voltage up while idling??
The manual for the battery states 13.7 at idle is optimal to avoid discharging. at the moment it is 13.2 - 13.4v. The instant you touch the throttle it climbs to over 14v so will it be ok now do you think?
Could the starter relay cause this issue do you think? I've got a new one so if it could cause this issue i may as well replace it. I'm confident at this point that the regular and stator are working ok so just exploring what other problems there could be. |
| Easy-X |
 Posted: 22:07 - 02 Jun 2021 Post subject: |
That sounds much better. Let's be honest here: scooters are just rag the thing on full throttle most of the time anyway, finesse is not an option In other words don't expect it to do a good job of charging the battery on idle, nothing on these things is built over-spec from my experience.
Does this model have a kickstarter?  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| vivasheety125 |
 Posted: 22:29 - 02 Jun 2021 Post subject: |
Tried a long 'ish ride and...
https://i.postimg.cc/q7yNCVcF/IMG-20210602-205517.jpg
That's with the bike idling too... It was charging earlier but now it not charging again. I only did 10 miles. I don't understand.
No, it doesn't i put a lever on it but theres no mechanism inside the case. also the lights are on constantly which drains the battery fast.
Driving me nuts, I can't understand this. |
| vivasheety125 |
| Nobby the Bastard |
| Robby |
 Robby Dirty Old Man
| vivasheety125 |
| Nobby the Bastard |
| vivasheety125 |
 Posted: 13:49 - 03 Jun 2021 Post subject: |
| Nobby the Bastard |
| Robby |
 Robby Dirty Old Man
The last post was made 5 years, 32 days ago. Instead of replying here, would creating a new thread be more useful? |
