H4yburn |
H4yburn L Plate Warrior
Posted: 23:28 - 04 Jun 2021 Post subject: No power AJS Regal Raptor |
Hey all, first post on here, so go easy on me
I've recently acquired an AJS Regal Raptor DD125e-8. Its N/R currently but with it being my first bike after completing CBT, I figured why not get a bit of a project and teach myself the ropes around bikes. Lets face it, its always handy to know!
Working from a combination of Haynes manual, User manual and online resources to try and get this machine into a roadworthy bike.
Have an issue, similar to a post further down this forum where when the key is turned in the ignition I get nothing. No lights.
I do hear a very faint clicking from the throttle every half second, regardless whether the key is turned or not.
I replaced the battery & fuses first of all - no change. Next up i should check ECU & wiring trouble is I have no idea where the ECU is located - can anyone tell me where its located? I've picked up a digital multimeter for testing the wiring but I've no idea what I'm doing there. Youtube tutorials needed! Any tips?
I have spotted under the seat a green and a black&white wire and according to what i have, this is the negative & ignition wires. They're attached to nothing. One has a sleeve, one has the connector. It feels
like they shouldn't be open! again, any ideas?
Thanks for reading, appreciate any advice. |
Easy-X |
Easy-X Super Spammer
Posted: 10:26 - 05 Jun 2021 Post subject: |
I'd get used to comparing the wiring diagram to the loom Have you got a specific Haynes manual or just the "Chinese 125" generic one?
With regards to the loose wires normal practice is to connect like coloured wires together. BTW no one here will complain if you post up some photos ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
H4yburn |
WD Forte |
WD Forte World Chat Champion
to v or not to v |
Easy-X |
Posted: 01:31 - 06 Jun 2021 Post subject: |
I've seen B&W as a kill switch line and assuming Green is ground then the photo might me some unconnected cut-out like a kickstand switch
The background is more revealing though. Can we assume - and forgive the heavy technical term - that this bike has been "fucked with" ? ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
H4yburn |
WD Forte |
H4yburn |
Robby |
Robby Dirty Old Man
Easy-X |
Posted: 14:18 - 07 Jun 2021 Post subject: |
Total electric failure? I always start by looking at the neutral light. It's about the simplest circuit in the electrical system, possibly even over the horn given the way I've seen Triumph do it
I try and break things down into chains - one link broken then the whole lot fails - so for the neutral light on a simple 125:
Battery, fuse box, ignition switch, clock bulb, neutral switch, engine (i.e. frame ground) and obviously all the wiring in between.
So with a mutimeter black lead on the negative terminal of the battery check all the above points with the red lead for 12 volts. ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
H4yburn |
Robby |
Robby Dirty Old Man
H4yburn |
Posted: 07:44 - 08 Jun 2021 Post subject: |
Battery is brand new. Tested it and its gone to 11V (because I'd left the key in the ignition overnight on Saturday - doh) I'll trickle charge to the full 12.5v and see if that gets her going. Picking up spark plugs today, will replace them. also the spade connection (if thats what its even called )Also its about £15 for a starter relay so I think I'll replace that. Fair bit of corrosion on it when I had it off. |
Robby |
Robby Dirty Old Man
H4yburn |
H4yburn |
The last post was made 2 years, 294 days ago. Instead of replying here, would creating a new thread be more useful? |
