Running rich, help me diagnose
Deropke
PostPosted: 02:58 - 09 Jun 2021    Post subject: Running rich, help me diagnose Reply with quote
The bike
: Derbi Terra 125cc
Symptoms:
    Running rich (black sparkplug)
    Hesitates initially on throttle often leading to a stall
    Sometimes doesnt start at all, not even bump start. (Now fixed, was ripped manifold intake hose)
    Severly poor performance below 4k rpm
    Poor performance above 7k (redline is @10k, but it struggles to reach it)
    Sometimes idles at higher rpm with no hesitations saddly everytime this has happened the bike was in pieces unable to ride to test performance.
Other notes
    Bike equiped with automatic choke
    Carb only comes with 1 screw to adjust mixture which is slightly rounded, you can screw it, but cant unscrew, seems like it's fully screwed as despite having grip clockwise I wasnt able to move it, but then shouldnt bike not able to start at all if it's fully in
jaffa90
PostPosted: 10:05 - 09 Jun 2021    Post subject: Reply with quote
Sounds like the carb needs servicing and check that the exhaust system as well.
Hong Kong Phooey
PostPosted: 10:19 - 09 Jun 2021    Post subject: Reply with quote
https://www.fowlersparts.co.uk/parts/5701280/terra-terra-terra-e3-terra-adventure-e3-2007-2009-terra-e3-terra-adventure-e3-all/carburettor
Carb is still available, some individual parts too, but I'm guessing the pilot screw is not available as an individual part. If that's been butchered then maybe the float height is also wrong.
You might be able to get a Chinese knock off, not sure how good it'll be but at £181 for the full carb, versus parts and labour on fixing there's probably not much in it if you split the difference.
PostPosted: 11:09 - 09 Jun 2021    Post subject: Reply with quote
Mice in the airbox Wink
Robby
Dirty Old Man
PostPosted: 14:26 - 09 Jun 2021    Post subject: Reply with quote
The mixture screw only affects idle really, so that is not the source of your problems. The fact that the screw is chewed up, and that the bike is a 125, tells us what someone has fiddled with the carb before to try and make it go faster.
So, carb out, strip and clean, make sure the float height, needle height and jetting are the same as what the factory manual says they should be. Work on getting the mixture screw out and replace it, and make sure that the choke flap isn't just closed all the time.
Deropke
PostPosted: 21:01 - 09 Jun 2021    Post subject: Reply with quote
Yeah, bike is a mess. also perhaps any of you know where "13" hose would go to. It has been sealed by previous owner, could be potentially culprit ?https://www.fowlersparts.co.uk/parts/view/863212
It seems like this bike had air problems as airbox been drilled and I just fixed the vacuum leak (the manifold intake hose was ripped, but this only fixed bike not able to start.
PostPosted: 23:25 - 09 Jun 2021    Post subject: Reply with quote
I'd guess the '13' pipe is a breather pipe - a vent from the engine/gearbox/crank (depending where it's attached) not something that should be blocked off as vents excess pressure. It'll likely consist of oil soaked air so either vent straight to atmosphere (and kill all the asthmatic kittens) or any old rubber hose that will fit and route it back to the airbox as it should be. Any leftover hydrocarbons can then be reburnt in the engine.
That being said do you mean the breather has what looks like a little pod filter to vent through rather than actually blocked? It's one of those typical, pointless mods ppl do.
Robby
Dirty Old Man
PostPosted: 12:51 - 10 Jun 2021    Post subject: Reply with quote
Looks like Easy is right. Typically there is a vent hose from the crankcase (often on top of the gearbox, behind the cylinder) into the airbox. This serves to even out crankcase pressure, and to direct air out of the crankcases into the engine to be burnt. This air contains a bit of exhaust that has blow past the piston, and bit of oil vapour, so you shouldn't be venting it to atmosphere.
I'm assuming the hose is still connected to the airbox and blocked off, but not connected to the engine. Find the stub on the engine that it connects to and plug it back in.
If the airbox was drilled and the inlet manifold stub was broken, then this bike has the textbook signifiers of someone trying to "tune" it. Carb needs to come out for a proper inspection, but also inspect any hoses or rubbers that it connects to, they may also be torn and need replacing.
Chances are that it has the wrong size main jet in. That's the go-to option for children that know nothing about tuning engines. If you can find someone that sells a carb rebuild kit, it may be worth just buying one and replacing all the bits.
Other hint that the person doing it didn't know anything - they tend to try to increase fuel flow in the hope that will make a difference. With most mixture screws, you screw it in for less fuel and out for more fuel. Standard setting is usually around 1.5-2 turns out.
PostPosted: 18:37 - 10 Jun 2021    Post subject: Reply with quote
Air filter plugged (mouses).
Carbonaterorer worn. Needles/Jets.
Mixture setting too rich.
The last post was made 2 years, 311 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.34 - MySQL Queries: 17 - Page Size: 63.44 Kb
