A100man |
A100man World Chat Champion
Hong Kong Phooey |
Posted: 16:43 - 09 Jun 2021 Post subject: |
On the other side of the coin, I sacked off the wireless, programmable, super-duper room-stat because it was an unreliable, unpredicatable piece of shit which seemed to randomly decide when and if the heatin g would be turned on regardless of how it was programmed and replaced it with a simple 5+2 day timer and electromechanical wall 'stat.
I did however have thermostatic valves fitted on all the radiators so the wall 'stat is really just an end-game cut off switch, most of the rads are off by the time the 'stat trips.
The best thing I did for heating efficiency was let the Mrs pay for the last two fills of 1,000 litres of heating oil. Amazing how much less frequently I come home to find the heating on and windows/doors open now. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
A100man |
Posted: 21:33 - 09 Jun 2021 Post subject: |
stinkwheel wrote: | On the other side of the coin, I sacked off the wireless, programmable, super-duper room-stat because it was an unreliable, unpredicatable piece of shit which seemed to randomly decide when and if the heatin g would be turned on regardless of how it was programmed and replaced it with a simple 5+2 day timer and electromechanical wall 'stat.
The best thing I did for heating efficiency was let the Mrs pay for the last two fills of 1,000 litres of heating oil. Amazing how much less frequently I come home to find the heating on and windows/doors open now. |
Yeah I'm not happy having tech foisted on me.. but yes you 'have' to have something.. to notionally improve efficiency, either: flue heat retrieval system or outside temp 'compensator' or fancy smart stat. I guess it's for the morons who open widows when it gets too hot in the house in winter. The outside temp thing looked cheap and easy as it apparently dictates the boiler burn rate dependent on in/out temperature differential... lower burn rate are more efficient on a condensor they tell me. ____________________ Now: A100, GT250A, XJ598, FZ750
Posted: 23:49 - 09 Jun 2021 Post subject: |
You could ask him which one is most easily removed within five mionutes of him walking out of the door?
They all sound like excellent ways of needlessly over-complicating something that is relatively simple and (should be) broadly reliable.
When I said have it. I was meaning in the same way I have a baffle for the exhaust on my bike. I know I have one, it's in a box in the workshop. If you can show you've bought one, is anyone checking it's been fitted?
In my experience, having a burner going less than flat-out is a good way to soot up the sensors. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Hong Kong Phooey |
Posted: 09:47 - 10 Jun 2021 Post subject: |
On the other hand, you could have gone smart thermostat and kept turning it to 7 degrees every time she adjusted it. Or if you don't value your marriage that much, just lock her out of the controls and not divulge the password. ____________________
MCN |
MCN Super Spammer
t121anf |
t121anf World Chat Champion
Robby |
Robby Dirty Old Man
MCN |
MCN Super Spammer
Posted: 14:21 - 11 Jun 2021 Post subject: |
All domestic CH boilers must be condensing type now. (Or of that type of efficiency.)
Madness to not fit that type as the economics speak for them self.
Only major deal is that a drain line for condensate must be fitted to drain to ground drains/gutter drains.
The other thing is I am not qualified to remove and install a new GCH Boiler at my gaff.
Though I am more than competent to do so.
Something about GasSafe training (Expensive training)
That makes it almost impossible to even buy a GCH boiler at retail and have sum kwalifyed kunt to install, test and certify.
Thats what puts me off replacing my 2006 GCH boiler.
It works perfectly fine but I know it could be 20% more efficient if I fitted a new boiler. But that would cost £1000+ to save what over the years?
I don't run all my rads in the house and trap as much heat as possible. And wear two pair of underkrackers.
I estimate £500 per year on gas as Im not here all the time. (Vague Guestimate.) ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
MCN |
MCN Super Spammer
A100man |
Posted: 21:50 - 11 Jun 2021 Post subject: |
MCN wrote: | All domestic CH boilers must be condensing type now. (Or of that type of efficiency.)
I estimate £500 per year on gas as Im not here all the time. (Vague Guestimate.) |
Yep.. My last house boiler install 20 yrs ago was condensing... but now you ALSO need one of these extra things.. The fitters (sorry, engineers) want whats easiest and with the most margin so that's a 'smart-arse' controller.
They really have you by the short hairs with this gas safe business. Between 500-1000 quid to install 1k boiler in less than a day.. ____________________ Now: A100, GT250A, XJ598, FZ750
Raffles |
Raffles World Chat Champion
MCN |
MCN Super Spammer
Raffles |
MCN |
MCN Super Spammer
Freddyfruitba... |
MCN |
MCN Super Spammer
Freddyfruitba... |
Posted: 17:17 - 13 Jun 2021 Post subject: |
Nor mine - I linked to the relevant law on my last post (I don't know what the above link is, but it's broken).
I made no judgement about unqualified people doing their own gas work (and I certainly don't condone it); I was merely stating the correct legal position on the subject. ____________________ KC100->CB100N->CB250RS--------->DL650AL2->R1200RS->R1250RS |
MCN |
MCN Super Spammer
Posted: 21:09 - 13 Jun 2021 Post subject: |
Freddyfruitbat wrote: |
I made no judgement about unqualified people doing their own gas work (and I certainly don't condone it); I was merely stating the correct legal position on the subject. |
U do U.
In the meantime, I have taken the opportunity to report your posts to the relevant authorities. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
The last post was made 2 years, 310 days ago. Instead of replying here, would creating a new thread be more useful? |
