Posted: 11:27 - 10 Jun 2021 Post subject: In-tank fuel filters |
Fitting a pingel fuel tap to my big bullet. I had to use an adapter with it (they are American threaded).
Due to, frankly, inattention on my part I've torn the gauze filter that goes over the inlet as I fitted the adapter. These are apparently made of unobtanium. You can buy brass mesh to make your own but I can't find a ready supply of pre-made ones that are long enough. I'm not sure if my soldering is good enough to make a new one from scratch.
Now the question. Do I actually need a new one? The damage was right at the top of the filter, the gauze goes all the way up past the top of the reserve tube but the "pinched" part is damaged and there isn't enough mesh left to re-work it (and it looks like stainless mesh which would be a pig to solder).
I'm just thinking, there probably isn't all that much chance of bits of dirt and detritus getting in the top when it's on the main "on" setting. All the junk will be sitting in the bottom of the tank so the filter is probably only necessary when on reserve?
Just after thoughts really. I'd normally just remove the sock altogether and fit an inline filter. A few reasons not to. One of them is that this is a super-high flow tap which it would be a shame to restrict by fitting a filter, another is lack of space -it's a short run from tap to carb inlet-, the third is the tap itself is an expensive piece of kit, it feels like I should protect the tap too.
TL;DR Torn the gauze filter over the fuel tap. Would it be ok to just leave the top open rather than fabricating a new one? Or am I just being lazy and avoiding doing what is necessary? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Robby |
Robby Dirty Old Man
Easy-X |
Easy-X Super Spammer
Posted: 13:37 - 10 Jun 2021 Post subject: |
If you've got an inline filter between the tank and the carb then I suppose the tap could get clogged up I wouldn't worry too much.
BTW that looks like marine-grade stainless steel mesh rather than brass. Maybe make a little mesh "sock" to slip over the top? ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
WD Forte |
WD Forte World Chat Champion
MCN |
MCN Super Spammer
Hong Kong Phooey |
MCN |
MCN Super Spammer
MCN |
MCN Super Spammer
MCN |
MCN Super Spammer
GettinBetter |
GettinBetter Crazy Courier
weasley |
weasley World Chat Champion
Posted: 00:04 - 27 Jun 2021 Post subject: |
Ok, new skill aquired.
Brass mesh is relatively easy to solder with the correct equipment. It is a total pain in the arse to hold in place while you do it. It is very easy to cock it up at the last minute if you start to rush.
I found a piece of pipe with an OD the same as the required ID. I cut the mesh to be roughly 1mm over-wide so there was a very slight overlap when it is wrapped tightly round the pipe. Having wrapped it tightly round the pipe, I held the mesh in place with a couple of pieces of tightly twisted wire.
Then it's a case of sliding about 3cm of the mesh off the end of the pipe (so it keeps its shape and has the edges together), painting an acid flux along the seam then running solder along the seam. I used 0.75mm resin cored lead-tin solder and I used a hot air pyro-pen (the type with a catalytic element in that you'd normally screw a soldering head to, but without the soldering head. NOT the type with an actual flame, this just immediately overheated and oxidised the mesh). It takes remarkably little heat to flow the solder.
Once that bit is soldered, another bit can be advanced off the pipe and joined. You need to take care not to overheat everything and spring apart the previous joint. As soon as the solder starts to flow, you need to remove the heat.
This was not my first attempt!
https://lh3.googleusercontent.com/pw/AM-JKLVgx2cpsaqvle68lplASEQBZQfiBeZQODVRjARj3UNQbXtiAA5EDijVOruhnNsAeWRQNQMObRnIEGl1B_lQ8h0ocpKStlw-W0dsnvWL5wR7Hteiqp9fdrl0mmuaZrYSAGN_YpY2ef5bnka3_NRakJOe=w1576-h886-no ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Islander |
Islander World Chat Champion
Posted: 00:36 - 27 Jun 2021 Post subject: |
Low melting point lead/tin solder would probably be ideal for this sort of thing or LMP solder paste. |
The last post was made 2 years, 304 days ago. Instead of replying here, would creating a new thread be more useful? |
