Honda Rebel CMX250 Engine Kaput?
Honda Rebel Rider
PostPosted: 04:51 - 11 Jun 2021    Post subject: Honda Rebel CMX250 Engine Kaput? Reply with quote
Greetings forum, and Hello to you all!
I have an old Honda Rebel that has been my primary source of transportation for the past 2 years or so. The bike has been acting up recently, and unfortunately, I think I have had a catastrophic issue with the engine.
When I pulled the top end (just the valve cover) off my CMX250, I noticed quite a bit of play in the cam chain, even though there is a cam chain guide AND cam chain tensioner in the cylinder.
Would anyone have some expertise they can bestow upon me? I would be truly grateful!
Thank you.
PostPosted: 08:55 - 11 Jun 2021    Post subject: Reply with quote
Cam chains don't last forever. They are a wearable part.
Can chain tennsioners don't last forever. They are a wearable part.
Self-adjusting camchain tensioners do not always self adjust.
So.
I would measure the camchain to see if it's worn out. There is usually a measurement in the manual for the maximum distance between a specified number of pins. If it is over this measurement, the camchain needs to be replaced.
I would remove and inspect the camchain tensioner blade to check it is not worn out, damaged (or in extreme cases, missing).
I would them re-fire the camchain tensioner and ensure it is correctly tensioning the chain.
I would then check the timing has not slipped before reassembling the bike.
If there is a significant amount of wear/damage to the tensioner blade, I would change the oil and clean the oil filter screen.
I'm not familiar with the CMX engine but if they are similar to the older CB250 motors, the CCT is a sort of sprung, curved plastic blade. On the CB250, it was in theory self-adjusting but the spring wasn't strong enough so you had to periodically loosen the adjuster nut, push down on top of the CCT with a screwdriver and re-tighten the nut. I've seen old superdream camchains chainsaw their way out through the barrel.
PostPosted: 12:31 - 11 Jun 2021    Post subject: Reply with quote
you state 'catastrophic issue'.
Does it still run? or did it make a bad noise and then stop.
Stinker's advice is spot on - unless bad things happened prior.
The last post was made 2 years, 319 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.67 - MySQL Queries: 17 - Page Size: 37.61 Kb
