Beeza-Geeza |
Beeza-Geeza Derestricted Danger
Posted: 18:44 - 13 Jun 2021 Post subject: CM125C Starting problem |
Purchased a non runner CM125C over a year ago
Would just about start on full choke and full throttle
Fully stripped down once in lockdown, engine completely taken apart and put back together with new bearings, piston/rings, gaskets, seal etc
Both bores were in very good condition so did not need a rebore
Finally after stripping, welding, painting and polishing, it is back together again
Still will only start on full choke and throttle!!
Timing marks adhered to during rebuild, tappets adjusted correctly, new twin coil, leads and plugs fitted
Purchased a generic 125cc carburettor which is a clone of the fitted Keihin one and that also needs full choke and throttle.
Question
If the CDI or pickup were at fault do they just fail or can they be intermittent?
Spent more than I will ever recoup but it has been fun during lockdown, be nice to actually get it working
Any advise would be appreciated
Regards
Ade from Nottingham |
Nobby the Bastard |
Beeza-Geeza |
Nobby the Bastard |
Easy-X |
Easy-X Super Spammer
Beeza-Geeza |
Beeza-Geeza |
Beeza-Geeza |
Posted: 08:45 - 14 Jun 2021 Post subject: |
It the proper spec of the cap I'm having difficulty finding out (1,5or10k)
Ade |
jeffyjeff |
jeffyjeff World Chat Champion
Easy-X |
Posted: 10:11 - 14 Jun 2021 Post subject: |
You've been painting... Do you have a good earth connections? Paint doesn';t conduct very well. So between the frame and engine, coils and frame and the battery frame earths. You often need to scrape some of your nice paint off behind the relevant fittings. I often fit an earth strap between the engine and the frame. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
GettinBetter |
GettinBetter Crazy Courier
Robby |
Robby Dirty Old Man
Posted: 12:39 - 14 Jun 2021 Post subject: |
You've had the whole thing apart, so there is a big list of things to consider. You also haven't told us how it runs when it starts - is it full throttle just to tick over, or will only run at high revs and no hope at low revs?
There are a lot of things in the rebuild that would make me ask questions, like why both fitting new pistons? New rings I can understand, but why replace the Honda originals for what I assume are pattern replacements. Did you measure the old and new piston rings to be sure they needed replacing, and the new ones are any better?
There is also no mention of cleaning up and lapping in the valves, which is a standard part of a top end refresh.
That, combined with my naturally pessimistic attitude, makes me wonder if you committed the ultimate sin of the top end rebuild, and didn't get all of the gasket surfaces spotlessly clean.
Check compression, check valve timing. |
Beeza-Geeza |
Posted: 19:43 - 14 Jun 2021 Post subject: |
A few updates
Bore was good, pistons replaced because I damaged them, bar underneath them to remove the clutch put dents in the bottom (I know, should have used a wider plates)
Compression - I do not have anything to compare the results to but LHS 8 bar 116psi RHS 7.5 bar 109psi so a little different
Valves removed and were lapped in, medium then fine
Earthing - Battery to crankcase to frame with paint removed
It's got a lever choke and will start on full throttle on full choke, can get it to about half throttle but erratic then dies, not a beat with no choke
BUT, have found that the existing carb it came with which did look as old as the bike itself is not a Keihin, googling HL IC T W shows it is actually a Fujian Hualong Carburetor (never heard of it) and jetting is Main 90, Pilot 35 not the listed 98/38 (so probably never ever worked on this bike) "it was working, honest guv"
Replacement carb was listed for a CM125C 1982 (mine is a 1983) so wrongly assume it would have been jetted for the bike it was listed for, jets on that were main 90 and pilot unknown (can't find a thing on it)
So
Ordered the correct jets, not sure if 90 to 98 & 35 to 38 would cause sure a drastic failure but I'll soon find out
Thank you for all your comments and help
Ade |
bypass2 |
bypass2 Spanner Monkey
Beeza-Geeza |
GettinBetter |
Robby |
Robby Dirty Old Man
Beeza-Geeza |
Nobby the Bastard |
GettinBetter |
The last post was made 2 years, 308 days ago. Instead of replying here, would creating a new thread be more useful? |
