Using a triple tree stand
SirFallalot
PostPosted: 08:27 - 15 Jun 2021    Post subject: Using a triple tree stand Reply with quote
As simple as this is I can't get the frigging bike on it.
If I have it on the rear paddock, it just slides backwards as soon as the front lifts.
If I have it on the centre stand, it'll go up, but as soon as i let go, it'll slip forward and potentially make the bike come off the centre stand.
Is there a trick to these stupid things? Ratchet strapping aside.
Lexmoto Valiant 125; 94 CB400; 96 CB750F2; 81 CB750 (restoring, lol not gonna happen); 2001 ZX9R(It's about to go :c); 2012 R1200R; 2015 R1200RS
PostPosted: 09:12 - 15 Jun 2021    Post subject: Reply with quote
They are dangerous bastirts.
I stopped using paddock stands years ago after getti g an Abba stand.
If one of the stands cannot roll then you will be fite-ing an hostile battle.
If you have the resolve to listen to this chap.
https://youtu.be/RpxJ6tUKJc0
Think about an Abba stand... Bit of an 'investment' but a joy to employ.
I never scratched paint on any bike using paddock stands and never had help. If you struggle doing it yourself then use another stand.
Sitting the side stand on a bit of 1/2" thick wood straightens the bike up a little leaving hands free.
Always keep a hold of the beast when using any stand.
I got a Sealey Hyd Bike bench years ago. I can use the Abba or my paddock stand on there too.
I hate taking a knee even if it's for a good cause.
https://abbastands.co.uk/
Giving a UK company a punt too.
Their Customer Service are proper helpful as well.
t121anf
PostPosted: 11:58 - 15 Jun 2021    Post subject: Reply with quote
Love my Abbastand, I started with their normal stand and superbike front wheel lift, which I've now binned off.
I now have the "Front Lift Arm", used in conjunction with "Moto Glide"
It's perfect in my opinion, easy, quick and secure/stable. Also makes moving my bike to one side of the garage simple.
stevo123
PostPosted: 14:17 - 15 Jun 2021    Post subject: Reply with quote
As you have already said, rear must be supported first. Are you using bobbins and hooks on the stand? If not and you are simply going under the swing arm I can imagine it would slide.
Best bet is either get some hooks and bobbins or an ABBA my friend. (I have had no issued using a headstock stand myself as of yet. Ah jinxed myself now)
Fat Angry Scotsman
PostPosted: 14:32 - 15 Jun 2021    Post subject: Reply with quote
anyone got experience with the side-lifting centre stand thingy's:
https://www.motea.com/en/central-stand-suzuki-gsx-s-1000-s-katana-19-21-paddock-stand-constands-power-evo-137333-0?gclid=5h0pp1n9-en&gclid=EAIaIQobChMI_c64iOCZ8QIVkuR3Ch2Z1QaZEAQYASABEgKcMfD_BwE
Tdibs
PostPosted: 15:19 - 15 Jun 2021    Post subject: Reply with quote
If you have a centre stand, use a car jack and a block of wood, gently jack against the header pipes to pivot the front wheel just off the ground. (if you are trying to remove the front end)
SirFallalot
PostPosted: 15:24 - 15 Jun 2021    Post subject: Reply with quote
Thanks for the suggestions Surprised
Yes these are dangerous bastards, the front one could easily knock the bike down on top of you if it slides too.
The rear one was sliding on the floor, not the swingarm, when I tried to push the front paddock down the rear paddock slid back, like cat and rat kinda thing.
I....just went with the ratched straps to the crash bars...
https://i.ibb.co/HF5WJdN/20210615-085135.jpg
PostPosted: 17:13 - 15 Jun 2021    Post subject: Reply with quote
Fat Angry Scotsman wrote:
That's a copy of an Abba Stand. Kind of. But single side lift.
I like my Abba stand as it hawds on to both sides of the swing arm pivot pit.
PostPosted: 18:28 - 15 Jun 2021    Post subject: Reply with quote
I have the same sort and I've never had an issue. You are holding the pin into the bottom of the yoke whene you try and put it on the stand aren't you?
P.
PostPosted: 22:15 - 15 Jun 2021    Post subject: Reply with quote
My GSXR is sat and has been sat on the same stand since March. I mount the front first because mounting the back compressed the front and was a cock to get the pin in without fouling the nosecone.
Fat Angry Scotsman
PostPosted: 23:05 - 15 Jun 2021    Post subject: Reply with quote
I just went on their website mate, that sky stand looks a nice bit of kit. Thinking that money will be eventually parted from me eventually. Laughing
PostPosted: 23:38 - 15 Jun 2021    Post subject: Reply with quote
Abba stand do a one similar but it jacks up using a foot pump and hyd. Cyl. Cool
ThatDippyTwat
PostPosted: 19:00 - 16 Jun 2021    Post subject: Reply with quote
Same here
Getting the stand set up for your bike is important. I had to piss around with the height of it. Now it's set up I'll happily sit my arse on the stand to piss with the front wheel, calipers etc. It's not going anywhere unless you deliberately ram it forwards with some decent force, and only because it'll come off the centre stand first.
Tdibs
PostPosted: 20:09 - 16 Jun 2021    Post subject: Reply with quote
I usually put a heavy toolbox sitting on the rear one just to make sure there is no movement too.
SirFallalot
PostPosted: 15:16 - 17 Jun 2021    Post subject: Reply with quote
So some of you never had a problem Confused hm.
The pin is inserted in the bottom of the yoke yes, then I just pus the stand down, the problem is once down it'll slip forwards, the straps worked fine or this case, but maybe I'm not using it right..
Mr Hammers
PostPosted: 20:55 - 17 Jun 2021    Post subject: Reply with quote
I got the Warrior spider type a few years ago: https://www.demon-tweeks.com/uk/warrior-spider-stand-motorcycle-lift-adaptor-kit-ubrstsmbrst-smi2092-pin-h-akn/
Don't think it was that much when i bought it, iirc i think it was about £80.
Anyway, fucking brilliant bit of kit, use it all the time.
A Guide To Powerbands
ThatDippyTwat
PostPosted: 05:18 - 18 Jun 2021    Post subject: Reply with quote
SirFallalot wrote:
...the problem is once down it'll slip forwards, the straps worked fine or this case, but maybe I'm not using it right..
Height is almost certainly wrong. I'll put mine up on the stand later today after work etc, if it's not lashing it down and video it.
Fat Angry Scotsman
PostPosted: 10:48 - 18 Jun 2021    Post subject: Reply with quote
Mate, I really like the look of the Abba Stands Sky Lift that MCN showed earlier in the convo, it looks amazing, as soon as I have a garage I am getting me one of them. I love the idea of it, I hate trying to lube and tension my chain off a paddock stand it's such a fucking faff.
ThatDippyTwat
PostPosted: 19:02 - 18 Jun 2021    Post subject: Reply with quote
Just home, and skies are distinctly grey. See what it's like tomorrow.
The last post was made 2 years, 303 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.17 - MySQL Queries: 17 - Page Size: 108.47 Kb
