| Author |
| YamMan22 |
 YamMan22 Derestricted Danger
| Back to top |
| WD Forte |
 WD Forte World Chat Champion
| Back to top |
| YamMan22 |
 Posted: 16:12 - 11 Jul 2021 Post subject: |
Thanks for the help WD Forte
Unfortunately on this YBR there is no EML on dash
Ok I have tried what you said to do and hope I did it right, assuming here that the Blue wire (V pin on connector) is Power in and the Yellow/Blue (T pin) is TPS signal out.
I'm getting 3.50 ohms (20k resistance setting on MM) between these 2 pins and the value is not changing when I open/close throttle.
Yes as you say you can't just buy the electronic sensors new, but can get one second-hand for about £30, so could be worth a gamble!
Definitely can't go for a genuine new one, too expensive!
Cheers for helping  |
| Back to top |
| WD Forte |
| Back to top |
| YamMan22 |
| Back to top |
| WD Forte |
| Back to top |
| YamMan22 |
 Posted: 18:54 - 11 Jul 2021 Post subject: |
Thank you very much WD Forte,
I will do what you suggest and will post back my results soon!
Thanks again for the help and knowledge  |
| Back to top |
| YamMan22 |
| Back to top |
| WD Forte |
| Back to top |
| YamMan22 |
| Back to top |
| WD Forte |
| Back to top |
| YamMan22 |
| Back to top |
| WD Forte |
| Back to top |
| YamMan22 |
| Back to top |
| YamMan22 |
 Posted: 19:22 - 17 Jul 2021 Post subject: |
I've tried running and revving the bike for 5 mins (in my garage) and still can't get any faults to show... In fact it didn't cut out at all at high revs, but I guess this would be different when riding it... I'll have to take it up the mountain again for a test
Actually maybe I should of put it in gear and try bringing up to speed (I will try this tomorrow).
Also ordered a used TPS sensor / throttle body module, one from a WR125, it looked exactly the same I guess they would use the same part from the same factory, worth a shot for £20.
Thanks again for the help WD Forte, will post back any updates |
| Back to top |
| YamMan22 |
 Posted: 12:56 - 20 Jul 2021 Post subject: |
Hi there,
Just an update, TPS module arrived today and I've tested it on throttle body...
And it does not work (not getting any resistance value changes).
So I guess either I have a duff part or the fault is on the other side of the resistor (magnet side - A). Is this possible?
I assume a magnet never breaks or loses its force and logic tells me I have a duff part but I'm not too sure.
And yes the magnet side is turning when you turn the cable mechanism.
Thanks for any help |
| Back to top |
| Nobby the Bastard |
| Back to top |
| WD Forte |
| Back to top |
| YamMan22 |
 Posted: 14:26 - 20 Jul 2021 Post subject: |
Hi,
Yes it has a magnet in it, ah I see not a VR then well I guess I can try the new sensor and check if voltages go up and down, will do that now
Thanks for all the help, will post back |
| Back to top |
| YamMan22 |
 Posted: 14:35 - 20 Jul 2021 Post subject: |
Ok replacement sensor is now fitted and getting up and down voltages on the yellow/blue wire (closed 0v to 4v open throttle)
So it's looking like this was the fault, but I will take it for a spin soon to confirm it, thanks again for helping  |
| Back to top |
| YamMan22 |
 Posted: 17:03 - 25 Jul 2021 Post subject: |
Hi guys, just an update...
Took it for a spin and same problem (cutting out).
With fault code 33 (Ignition coil) now showing.
So will now look at the coil/wiring.
Edit, checked the Ignition Coil:
Primary winding resistance
2007-on YBR models 2.16 to 2.64 ohms @ 20°C
Result - 0.06 Ohms
Secondary winding resistance (without plug cap)
2007-on YBR models 8.64 to 12.96 K-ohms @ 20°C
Result - 5.38 Ohms
Spark plug cap resistance approx 5 K-ohms @ 20°C
Result - 4.98 Ohms
So looks like a bad coil, I should of checked this before however given it is a brand new (aftermarket) coil it was the last thing I thought would break  |
| Back to top |
| YamMan22 |
 Posted: 20:35 - 31 Jul 2021 Post subject: |
Hi all, just an update,
I replaced the Ignition Coil and the bike is now running fault free.
But ignore previous post regarding testing the coils, I did the test wrong...
Both coils show similar resistance, so it's nothing to go by... I guess when the coil heats up that is when it malfunctions
I will try putting old coil back in to see if problem comes back just to fully confirm it.
Thanks again for all the help
And for the record... The bike does store the 'flashing' fault code after dieing, as long as you don't start the engine and just turn ignition on/off/on/off/on etc the fault will continue to show infinitely... After the engine starts the fault then deletes itself.... if that makes sense  |
| Back to top |
The last post was made 4 years, 236 days ago. Instead of replying here, would creating a new thread be more useful? |
