zx9r c2 intermittent starting problem
trevor saxe-coburg-gotha
PostPosted: 07:29 - 13 Jul 2021    Post subject: zx9r c2 intermittent starting problem Reply with quote
Eh up everyone -
My bike's a C2 with 85k on it and runs and rides very well. But for the last couple of years it's developed a fault when starting. This happens hot and cold, but ironically does seem somewhat less prone in winter (!).
Symptoms are: key in barrel, turn key, thumb starter, cranks but yet I know - I just can tell - it's not going to fire up. My usual cure is simply to turn the key back to off, and then back to start, and this one simple thing is 90% of the time enough to correct the starter system and the bike fires up as it should do - almost instantly.
This problem arises on or off choke.
Lately the problem's increased in regularity and developed a couple of new twists. Firstly, it'll do it four or five times in a row before it "corrects" itself with the key-back-to-off 'trick'. Secondly, it's starting to sound like the battery is shagged when it fails to start.
Now you're going to ask me how old the battery is. I can't tell you for sure. What I can say is I've owned the bike for - what - let's say 4 years. I haven't fitted a battery - I don't think there's a receipt for one in the stuff from the previous owner. Bike had 18k on it when I bought it - which to me suggests it HAS stood underused - which in turn implies it will have had a battery unless it's been Optimated. So I don't know is the short answer. It could be the original though. Me, I run the bike couple hundred miles a week on average, throughout the year.
note - despite not being EFI, this bike has a CPS, it's conjectured that KAwasaki were going to make the switch to injection but delayed it for whatever reason - but regardless, could some sort of CPS problem give the symptoms I'm experiencing?
Last edited by trevor saxe-coburg-gotha on 06:42 - 14 Jul 2021; edited 2 times in total
jaffa90
PostPosted: 09:26 - 13 Jul 2021    Post subject: Reply with quote
I would be checking if the fuel pump is activated when switching on .
to v or not to v
PostPosted: 09:49 - 13 Jul 2021    Post subject: Reply with quote
putting new plugs and plug caps in mine greatly improved the cold starting.
Moto Guzzi V7.
Irezumi
PostPosted: 21:14 - 13 Jul 2021    Post subject: Reply with quote
Are the key and lock/barrel set original. Sounds stupid but could it be worn and moving from on to off slightly?
Long shot but not unheard of.
Kawasaki Jimbo
PostPosted: 18:06 - 14 Jul 2021    Post subject: Reply with quote
I was thinking the same since the lock on my similar vintage, 66k miles 6R is noticeably worn and I can pull the key out in the ON position. However I don’t have any running problems, and would a worn barrel allow the starter motor to work but not the ignition?
Copycat73
PostPosted: 08:46 - 15 Jul 2021    Post subject: Reply with quote
I've had bikes spin with the kill switch off.
caveat emptor
UncleFester
PostPosted: 13:22 - 15 Jul 2021    Post subject: Reply with quote
If wiggling the key is what sorts it then i'd be looking at ignition barrel / wiring and also cleaning the kill switch / starter with dielectric white grease.
That said, 'her' CB400SF will spin over all day long on a half charged battery but will start every time without fail on a fully charged one. It was even more iffy before new plugs. So now it has new plugs and lives on an Optimate and has given no more trouble.
2017 Z1000SX
PostPosted: 18:39 - 15 Jul 2021    Post subject: Reply with quote
tbf i've probably got 85k on these plugs
jaffa90
PostPosted: 22:48 - 15 Jul 2021    Post subject: Reply with quote
tbf you should be shot for not servicing your bike!
Also i don`t think that`s the problem.
PostPosted: 07:33 - 16 Jul 2021    Post subject: Reply with quote
triggered tae fuck Laughing
it gets oil / filter every 6k, plugs checked annually (replaced every 12), suspension linkage gets greased, swing arm bushings ditto, and N/S peg (essential for the C and C2); fork internals glopped out and new oil this year; full suspension set up (Alpha, Leeds); refurbed 4 pot Nissin front callipers fitted to replaced oem tokico 6 pots last week;
it wouldn't even run on 85k plugs
xX-Alex-Xx
PostPosted: 08:21 - 16 Jul 2021    Post subject: Reply with quote
Liar
DILLIGAF
PostPosted: 09:49 - 16 Jul 2021    Post subject: Reply with quote
i wonder how it actually would run on 85k plugs though
xX-Alex-Xx
PostPosted: 12:29 - 16 Jul 2021    Post subject: Reply with quote
Spark would probably be as bright and coherent as the PM.
DILLIGAF
PostPosted: 15:51 - 16 Jul 2021    Post subject: Reply with quote
https://media1.tenor.com/images/de3f46ffff16213a116b4cdd0be97e96/tenor.gif?itemid=17599743
Robby
Dirty Old Man
PostPosted: 09:39 - 17 Jul 2021    Post subject: Reply with quote
My first thought was a sticking relay, but I don't know if there are any relays that would cause this problem in your system.
It runs carbs, so any fuel pump stuff is not a factor in initial start. The float bowls will have fuel in, so it has fuel.
The engine is spinning over, so the bulk of the electrics are behaving.
This means that something is intermittently interrupting the spark, and only on startup, not when running. A sticking relay is the neatest problem, could also be a corroded connection giving high resistance and not enough power to create a spark while also running the starter motor.
Wiring diagram, look for anything that can interrupt the spark from the ignition barrel down.
PostPosted: 04:42 - 18 Jul 2021    Post subject: Reply with quote
Thanks Robby.
The last post was made 4 years, 248 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.43 - MySQL Queries: 14 - Page Size: 90.36 Kb
