trevor saxe-coburg-gotha |
Bhud |
Bhud World Chat Champion
blurredman |
Easy-X |
Easy-X Super Spammer
sickpup |
sickpup Old Timer
Bhud |
Posted: 19:42 - 27 Apr 2022 Post subject: |
Finally settled on a luggage solution that satisfies me. These high quality bags have enough space in them for a picnic.
The ammo tin was the coolest-looking storage method I tried. However, it was only big enough for use as a tool case. Plus the steel began to bend and the tin drooped after a while. The on-seat My Little Pony thing from Ebay had plenty of space, but the cheap nylon straps chafed and wore through.
I think it's going to be these bags now, and that's it. I've bolted a little bit of square-section steel behind each bag to prevent them reaching the wheel. However, I'll need to improve those, as they're sharp and pointy at their extremities, and will eventually damage these bags. Currently attached with zip ties, although that will change (to paracord).
https://i.ibb.co/R4rz0hP/saddlebags.jpg
Update: these should do.
https://i.ibb.co/S695syR/brackets.jpg |
The Shaggy D.A. |
The Shaggy D.A. Super Spammer
Posted: 17:30 - 28 Apr 2022 Post subject: |
Sold the ER5, now back down to the one bike. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
struan80 |
struan80 World Chat Champion
to v or not to v |
The Shaggy D.A. |
Posted: 20:17 - 28 Apr 2022 Post subject: |
struan80 wrote: | The Shaggy D.A. wrote: | Sold the ER5, now back down to the one bike. |
How do you find the Royal Enfield? Can it sit at motorway speeds? |
Haven't finished running it in yet so not given it the full beans, but everything bodes well with my fat arse on it. Sits OK at 60, with another 2k revs to go - it has a speed limiter at 72mph so will hit that first rather than the rev limiter. Most of the peeps in the owners groups are the types that avoid motorways, but there's a few who've swapped the air intake to a free breathing one and upped the front sprocket a tooth, to free a couple of ponies and make the cruising on motorways more relaxed. I may give that a go once I get a feel for what it can do unmolested.
Other than that, I have to say it's the most comfortable bike out of all that I've owned, and although the wet weight is only 2kg less than the ER5, it feels more like my old YBR Custom when wheeling around the drive and garage, and just goes where you point it when riding, and it's a lot smoother than any of my previous Enfields.
It's not going to win any races, but that's not what I got it for. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Easy-X |
Posted: 16:48 - 30 Apr 2022 Post subject: |
110% success by replacing the KZ1000 coils!
Recap: bike was a bit rough on idle even after warming up. Basically got to the point it'd stall under 2000rpm Tried carb clean and then found we weren't getting a good spark on the outer plugs. New coils + all new connectors and now the bike's running better than ever! Almost starts and runs with no choke (with the current clement weather.) The old fella's well happy
On the Triumph we were going to have a latching button for the hi/lo beam but the new one that's turned up is the wrong thread size. Fuck it, gonna stick with the current momentary button and back it up with a latching relay. The hi/lo beam will then work much the same as the "Harley-style" indicators. ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Kawasaki Jimbo |
redeem ouzzer |
Posted: 20:40 - 02 May 2022 Post subject: |
Jumped on the GK73A project bike over the weekend.
Picked up a set of powder coated metalwork for the back end last weekend (rear subframe and exhaust brackets). Got it all on and bolted up, had to make a plate to mount the rectifier using a real one as a pattern.
https://live.staticflickr.com/65535/52045766179_8484a15566_b.jpg
Fitted battery box and sorted out all the wiring in that area, then realised at some point a previous dickhead has routed the wiring harness the wrong way (should go outside the frame and clip to the airbox).
https://live.staticflickr.com/65535/52044473092_96288fabf7_b.jpg
Disconnected the loom from the front and pulled it back through the frame spar, i'll sort the routing out once the new grommets come.
Used the unwiring as an excuse to remove the rather tatty clocks and build a decent set with an MPH speedo off an RGV with new sponge and backplate. Much tidier.
https://live.staticflickr.com/65535/52045766109_65896ccfdc_b.jpg
Removed the GSX400F forks which it came with and fitted a reasonable set of standard forks (new seals and oil).
https://live.staticflickr.com/65535/52045767759_690953d838_b.jpg
Realised the battery it came with was as Li-Po so that will be going in the bin. I have no way of charging such a device and I don't trust the charging system on the bike to cope with it.
Carbs are away being done so I aim to get the cooling system, exhaust and wiring back on before they come back. At the same time I should received some spare wheels shod with new tyres. The risk with the project is I have no idea how good the engine is. I did the clearances last weekend and there were a few pitted cam lobes (usually a sign of crap oil or infrequent changes), but it looked clean and had good draw on all pots. Worse case scenario I freshen up one of my spare engines and chuck it in over winter. ____________________ Be a REAL MAN! |
blurredman |
Posted: 12:23 - 03 May 2022 Post subject: |
Easy-X wrote: | 110% success by replacing the KZ1000 coils!
Recap: bike was a bit rough on idle even after warming up. Basically got to the point it'd stall under 2000rpm Sad Tried carb clean and then found we weren't getting a good spark on the outer plugs. New coils + all new connectors and now the bike's running better than ever! Almost starts and runs with no choke (with the current clement weather.) The old fella's well happy |
I also have a similar problem I've been investigating with my Trophy. After a 110 mile ride last month (had been 700 miles trouble free until then after bike build up/engine re-build), the bike would mis-fire at low RPM and buck as ignition kicked in and out at low speed. Would backfire after cutting out sometimes. Seems like definitely ignition. Been tracing voltage leaks at fuse box and charging system etc too for possible charging issues (thought it might have been too much battery discharge at first).
However: typical symptoms point to coil or condenser. Perfectly happy and idles fine enough when cold, but over period of riding, bike mis-fires slightly at idle and sometimes stalls. Eventually bike will not idle at all, and have to keep the RPM @ about 2k to stop bike from stalling.
Have spare condenser/capacitor that I can nick off other bikes (I know that they work after all and the different systems both use 250v 0.22uF capacitors so very standard), which I will change first, but don't have spare 6v coil if this turns out not to be the fault. Resistences check out warm or cold on the coil but that doesn't necessarily mean anything when it comes to coils. But I could try 12v coil (it may or may not work) if condenser change doesn't fix anything. (worth noting I don't have a capacitence tester, so replacement is best diagnosis for me).
I also think the condenser (I hope- they're cheaper), would be the fix to the above but additionally, at high gear/low RPM applications the bike (always did this even after rebuild) does bog out a bit (more in like a mis-fire way as opposed to air/fuel way). So hoping that was just another symptom of the above too. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 17k. , 1979 Suzuki TS185ER - 9k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 38k, 1989 MZ ETZ251 - 49k
Easy-X |
Posted: 19:16 - 03 May 2022 Post subject: |
Does sound like strangely similar symptoms especially the "keeping above 2000 rpm"
FWIW we tested the coil resistances (cold) and they were all within spec. With regards to replacing them you just need something that a) fits and b) has similar primary and secondary resistances, the expected voltage is largely irrelevant. (Condensers/capacitors do have a maximum working voltage so be careful there.)
If it's similarly wired as our T140 then the lucas coils get a 12V feed (check if it's less - hints at poor wiring or corroded connectors) and the points would switch to ground when spark is required. I mention this as you might want to turn over the engine by hand and see what the resistance is between the coil negative and frame. ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Bhud |
Posted: 23:25 - 03 May 2022 Post subject: |
On ignition coils, I will say, stick to the OEM/manufacturer's parts. I've had my share of ignition coil troubles where I've tried to go cheap, in the past. Just isn't worth it. On a 40 year old Kawasaki, I would rather go for a 40 year old Kawasaki original ignition coil, than a Chinese surrogate. If good 40 year old coils are unavailable, I'd switch to a complete replacement electronic ignition system, e.g. Dyna S (there are a couple of other companies that do them, too). As for the points and condenser - replace them anyway as a set because they cost peanuts and it's a no-brainer. Stress-inducing misfires happen when the points are on the way out because of a bad condenser, and it's hard to see pitting or burning on the points, so just replace them if in the slightest doubt. I know you know guys know about electrical stuff and I'm not trying to teach you to suck eggs. That's all I've got to say. |
blurredman |
Posted: 08:31 - 04 May 2022 Post subject: |
Yep, I got to work yesterday despite the misfiring, but barely got home. Indeed a few times complete engine stop (whilst riding). Which are symptoms of coil that weren't there before in the same way a mere few days ago.
Either way, as soon as I got home did coil resistence checks (perfect, and not physically hot) I swapped condensers between the bike and another one to rule them out. The Trophy was exactly the same. Misfire, splutter, backfire. The other bike with the suspected condeser was fine- I later used that to go to the shops to test, but also came to work on it to-day and it was perfectly fine... So not condenser.
So now I have to find a nice miniature tube type 6v coil.
I was hoping it would be the condenser, as I have those spare, I also have a few 12v coils spare- but no 6v. So I have to actually spend money on this one.. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 17k. , 1979 Suzuki TS185ER - 9k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 38k, 1989 MZ ETZ251 - 49k |
Easy-X |
Posted: 12:35 - 04 May 2022 Post subject: |
Easy-X |
blurredman |
Posted: 15:29 - 04 May 2022 Post subject: |
I dunno really, because when you think about it 6v was used until relatively recently esspecially on small Jap bikes..
This bike manufacture date is 1972 so still a period of time when either system is perfectly acceptable to the populous. 6v totally DC system. But isn't Japanese, German.
Anyway, got a coil lined up to be picked up on the next club meet on Sunday.. Woop woop.
You can get these things quite cheaply, and I am one to buy cheaply and twice. But, in this case it's handy having the same dimension coil for standard fitting as opposed to getting creative. ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Islander |
Islander World Chat Champion
Posted: 19:48 - 08 May 2022 Post subject: |
Finally sorted an intermittent electrical issue on the ignition sub loom on the M750 and fitted a pair of high output coils to improve starting.
Replacement timing belts on order and once they're fitted and it's MOTd, it'll be good to go for the summer |
to v or not to v |
Posted: 20:24 - 08 May 2022 Post subject: |
started the thing up for the first time since October and gave it its annual wash. all seems well
need to book it in for an MOT now. ____________________ current bike Yamaha Thunderace.
its old and fat, but its a damned good ride. the bikes not bad either. |
ThunderGuts |
gt alex |
gt alex Two Stroke Sniffer
Easy-X |
Posted: 09:14 - 10 May 2022 Post subject: |
Working out the wiring on the ol' Triumph, headlight bucket's the usual rat's nest:
https://i.imgur.com/4DhSQr3.jpg?1
And the handlebar switches:
https://i.imgur.com/lY3BuT2.jpg?1
Just in loosely for now until I've fully tested everything. ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
The last post was made 1 year, 351 days ago. Instead of replying here, would creating a new thread be more useful? |
