Easy-X |
Easy-X Super Spammer
Posted: 17:57 - 07 Oct 2022 Post subject: |
New coils on the T140!
Didn't fix the problem, still only firing on one cylinder
Has spark? Yup, and brighter with the new coils. Has compression? 150 both sides. Has fuel? Spark plug has petrol on it for the non-functional cylinder. Timing? Done with a strobe gun, spot on. Even went as far as checking the valve clearances
I was explaining how it didn't really need choke to a friend who turned up to see what we were doing when my subconscious started screaming at me. I checked the linkage between the two carbs and the right one was on a little bit. Disconnected the linkage and it started first kick and sounded lovely
So it turned out to be too much fuel on one side... ffs! So now we can get back to the fettling but it's just a totally different bike. Old fella's very happy. ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
The Shaggy D.A. |
The Shaggy D.A. Super Spammer
Posted: 00:00 - 09 Oct 2022 Post subject: |
Finally fitted the DNA air filter cover, keeping the standard filter. After a 10 minute idle, took the bike for a 75 mile bimble to Melton Mowbray and back along one of my favourite roads, the B6047. This road is about 20 miles of gentle hills and twisties, perfect for the Meteor.
Most of the time it's a 3rd & 4th gear ride, with the new cover it's a 4th and 5th gear jobby.
Quite impressed, it's got to be the most simple, cost effective mod with the biggest bang for your buck return. No faster, but each gear gives more, and 5th is now a useable gear, rather than only being an overdrive when on the flat. Looking forward to seeing what it does to the consumption - might be worse because it could bring on hooligan tendencies
Can't really tell if the bike is any louder since I always wear earplugs, but it does seem to be more growly, in a pleasing way.
It's what the bike should be like from the factory. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Easy-X |
The Shaggy D.A. |
Easy-X |
Posted: 11:14 - 09 Oct 2022 Post subject: |
Not sure how 10 mins makes a difference Something like the lambda sensor needs time to warm up but everyone goes with an integrated heating element to speed up the process these days.
I'm always a bit suspicious of lambda/air-temp/air-pressure sensor mods as they're at best band-aids and a worst outright scams like the "ECU remap plug" ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
The Shaggy D.A. |
xX-Alex-Xx |
DJP |
DJP Crazy Courier
Posted: 18:23 - 09 Oct 2022 Post subject: |
I agree. I'm currently chasing down an apparent fuelling issue on my bike. I rode 150 odd miles in standard trim and the next time a similar distance with an O2 sensor eliminator. The fuel consumption was practically identical either way, so whatever the O2 sensor is doing, it ain't much. ____________________ Suzuki Bandit 1250
https://deejayp999.atwebpages.com/index.html
That's http not https |
hellkat |
hellkat Super Spammer
Posted: 22:25 - 09 Oct 2022 Post subject: |
I pushed it home
Had a storming day, bombed it round to the Mucky Duck and home again, but literally as I came up the sliproad for my home ... it cut out on me and would not restart again. Luckily only four blocks to push it.
I reckon its an electrical/ignition problem.
Pfft it was good while it lasted LOL ____________________ Not nearly as interesting in real life. |
Easy-X |
hellkat |
Posted: 19:32 - 12 Oct 2022 Post subject: |
I started the fucker up, the wanker, LOL
A little split second of starter-button tantrum but then it started straight up.
Whereas on Sunday evening I had no back/brake light, no indicators, a weak horn and no starter button.
I had phoned the mechanic to say I would bring it back in for them to have a look at the ignition/back light, if I could get it started (otherwise they would have to pick it up again).
But then it started to rain so I thought perhaps not today
If it starts tomorrow, hopefully I can find the time to ride it over there.
I've been thinking about its history of ignition/electrical glitches and there are enough instances of "weird stuff happening" almost right from the start, for me to assume its an historical ignition thing, maybe just a bulb in the back light, not sure.
I'll let them have a look.
Electrics are not a good thing for me to start practising my own spannering. ____________________ Not nearly as interesting in real life.
Nobby the Bastard |
Easy-X |
Posted: 19:55 - 18 Oct 2022 Post subject: |
I was a good boy today and checked the tyre pressures before heading out (conscious as I was of the Triumph fiasco.)
27psi on the front (spec 33) 33 on the back (spec 36)
Oh well, 5 mins with the foot pump. ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
JonE |
JonE Scooby Slapper
grr666 |
grr666 Super Spammer
Posted: 20:40 - 22 Oct 2022 Post subject: |
Swapped Oberon bar end mirrors to stock mirrors, removed phone mount, removed front and rear paddock stand
bobbins, all put in a box ready for transfer to the MT10, I'm pretty sure they will all fit straight onto that. I hear we are to
expect a warm start to November, I might even get a few miles in on the new steed before I put her to bed until the spring. It
would be awesome if I could manage to do the 600 miles required to get to first service before the year is out. ____________________ Currently enjoying products from Ford, Mazda and Yamaha
Easy-X |
Bhud |
Bhud World Chat Champion
virus |
virus World Chat Champion
Posted: 18:59 - 24 Oct 2022 Post subject: |
Passed its MOT with the 2 advisories I knew it would get (low rear tyre tread, rear disk thickness) Much to the annoyance of another customer at the test centre, namely a grumpy prick that said my bag of shit ratbike will never pass MOT, whilst his cosmetically perfect golf GTI failed on low brake pads, low tyres all around, some bulbs out, headlamp aim out and emissions control failure.
Oh how I laughed as I rode away on my heap of scrap that cost me less to build than the repair cost to get his car to pass MOT. ____________________ own: 81 xs1100g...
hellkat |
Posted: 20:56 - 24 Oct 2022 Post subject: |
I finally received its V5 from the DVLA.
trevor saxe-coburg-gotha |
Bhud |
A100man |
A100man World Chat Champion
Nobby the Bastard |
grr666 |
Posted: 17:29 - 25 Oct 2022 Post subject: |
Although I didn't do it, stock exhaust back on the Spacker now. Good job I didn't try and do it, two header nuts needed
the blowtorch treatment, two days left and the old girls gone. Managed to get away with reusing the old crush washers
too which was a bonus. Charged me 1.75 hours labour plus vat. Came in a whisker over £100. Totally worth it in my book.
Riding it home it didn't sound like my bike anymore ____________________ Currently enjoying products from Ford, Mazda and Yamaha
Easy-X |
Posted: 16:44 - 30 Oct 2022 Post subject: |
I'm resolved now to keep the XSR long-term. It's small enough to hustle through city traffic yet capable of handling long trips like Cornwall.
I did the typical "de-cat" exhaust swap a while back (probably catching corroded exhaust studs and nuts at just the right time) and as I've often stated the bike is now almost musical in tone I'm now onto step 2: I've posted the ECU away for a remap
I'll also be doing the typical Stage 1 air box mod (basically removing the restrictive snorkel intake.) Maybe I'll get a few more BHP, don't care. This is more about refinement - smoothing out the rough edges - mostly the throttle response. ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
The last post was made 1 year, 175 days ago. Instead of replying here, would creating a new thread be more useful? |
