Max88 |
Max88 L Plate Warrior
Posted: 21:25 - 28 Jul 2021 Post subject: Yamaha virago 535 unknown problem (possible its electrical) |
Hello there. I own a yamaha virago 535 that has ben running grate for past cuple of years since I've owned it. But a month ago it died during my ride due to dead battery. I've had some issues with charging. Had to change my stator and regulator and still wouldn't charge with the new parts. I struggled finding the problem so i took my bike to a "friend" mechanic to take a closer look. He called me after a few hours and told me to come and pick up my bike, he fixed it by changing the regulator again. Supposedly i had a shorted battery and that killed my new regulator. He told me everything is ok and charging and that I can ride home so I did... Little did i know nothing was apparently fixed and my new battery drained and I was stranded on the highway. Long story short I got it home. Changed the battery and did some test to see if it's charging and it wasnt. Only 12.5v.. And discovered that my fuse box was getting hot. Figured it must be a bad connection so I went and bought a new fuse box and hooked it up. Tried again of it would charge the battery still nothing. After that i was a bit frustrated amd left it for the day. The nex day the bike wouldn't fire up. There is no spark on the spark plugs and my light flickers. Also im hearing the clicking nose from the front left compartment where are all of the relays and i think thats where the CDI is located. (i will put i google drive link of the video in the bottom) that clicking is is synced to my head light flashing. I have all of those relays and a new CDI as spares from my old 535 and thought it something must be fried from the bad battery so i switched it all and everything is still the same. I'm out of ideas. I would greatly appreciate all the help I can get.
P. S
I'm sorry for my bad English and the long text. Below I will link the Google drive link for the video.
https://drive.google.com/file/d/18GivBLoZ9pdVgUaJHlgpAN4UaXgCscbU/view?usp=drivesdk
https://drive.google.com/file/d/18GivBLoZ9pdVgUaJHlgpAN4UaXgCscbU/view?usp=drivesdk |
Pete. |
Pete. Super Spammer
Posted: 22:05 - 28 Jul 2021 Post subject: |
Un-plug the HID driver first thing, see if it cures the clicking.
The clicking sounds like the flasher relay and the fact that it affects the headlight points to a bad power connection. The fuse box getting hot isn't good but it does point to the fault not being anything to do with charging since the charging circuit is not fused.
First thoughts are - bad earth on the loom or on the engine.
If you have a good copy of the wiring diagram I'll take a look at it for you but I bloody hate Yamaha wiring. ____________________ a.k.a 'Geri'
Max88 |
Max88 |
WD Forte |
WD Forte World Chat Champion
WD Forte |
Max88 |
A100man |
A100man World Chat Champion
Posted: 10:33 - 29 Jul 2021 Post subject: |
The 'relay' in question is probably this tin of tricks, as found on several Yams inc my FZ750..
https://yamaha-virago.blogspot.com/2018/10/relays.html
.. it has several functions the most minor of which is flashing the indicators. ____________________ Now: A100, GT250A, XJ598, FZ750
Max88 |
A100man |
Posted: 13:00 - 29 Jul 2021 Post subject: |
Max88 wrote: | Followup, i have discovered that once I disconnect the fuel pump the relay stops clicking, still no spark. But at least I think that I narrowed it that maybe my fuel pump was shorted? Looking forward for your opinions. |
Unless you're out of fuel - it clicks forever then too. ____________________ Now: A100, GT250A, XJ598, FZ750
Max88 |
Posted: 20:31 - 29 Jul 2021 Post subject: |
Clicking is solved. The fuel pump was faulty. Still not charging the battery tho :/
I have installed the new stator and regulator/rectifier |
Pete. |
Pete. Super Spammer
Posted: 21:02 - 29 Jul 2021 Post subject: |
The battery is charged via the 20A fuse in the fuse box. Run the engine and put a volt meter on one side of the fuse then the other. If one side reads battery voltage and the other side reads charging voltage then the fuse is blown. ____________________ a.k.a 'Geri'
The last post was made 2 years, 271 days ago. Instead of replying here, would creating a new thread be more useful? |
