GPZ500S throttle cable replacement - cables sticking
B5234FT
PostPosted: 20:59 - 28 Apr 2021    Post subject: GPZ500S throttle cable replacement - cables sticking Reply with quote
So I snapped the pull cable on my GPZ and went to replace it (new, genuine cable). On doing so I discovered the push cable was rusted through and had obviously been for some time, so replaced that too.
New cables were run alongside the old ones, so the routing should be correct, or at least the same as before. I connected the carb end first and I'm attempting to install them into the throttle housing on the handlebars.
I can install the pull cable alone and everything feels fine, but if I install both cables the throttle is sticky/slow to close when released. If I try pulling and releasing the pull cable with neither installed in the grip, they both run smoothly and snap back with the throttle spring.
I'm at a loss as to what is causing it, my guess is something binding in the throttle housing but nothing I can see.
Has anyone come across anything similar before?
Nobby the Bastard
Harley Gaydar
PostPosted: 21:46 - 28 Apr 2021    Post subject: Reply with quote
Have you adjusted the free play?
Triumph Sprint ST 1050
B5234FT
PostPosted: 12:27 - 29 Apr 2021    Post subject: Reply with quote
No, but the cables don't seen tight when installing them (although they could be too slack I guess). Worth looking at, cheers!
B5234FT
PostPosted: 20:50 - 01 Aug 2021    Post subject: Reply with quote
Finally dug this out again for another look after a few vehicles took priority. Removed the tank and slackened the cable ends on the carb and its MUCH better. The return cable was adjusted just tight enough that I could assemble everything on the bar and it would go together and bind.
Thanks a million for the pointer, I was tearing my hair out.
The last post was made 4 years, 289 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.04 - MySQL Queries: 14 - Page Size: 39.39 Kb
