Nobby the Bastard |
Farmingstock |
Farmingstock Trackday Trickster
Nobby the Bastard |
Farmingstock |
Nobby the Bastard |
Farmingstock |
Mr Hammers |
Mr Hammers World Chat Champion
Posted: 22:09 - 02 Sep 2021 Post subject: |
At the risk of insulting your intelligence...and maybe i've just misunderstood...but you do know there's another gasket in the smaller circle..? With four tabs/circles sticking out? ____________________ A Guide To Powerbands |
Farmingstock |
Mr Hammers |
Posted: 22:23 - 02 Sep 2021 Post subject: |
Hi, yeah i saw but i only see one black outer gasket...one already in there, and one fucked one. I don't see the inner one with the four tab bits...? ____________________ A Guide To Powerbands |
Farmingstock |
Farmingstock |
Mr Hammers |
Posted: 22:33 - 02 Sep 2021 Post subject: |
Ah, i see, that makes sense. Yes, that is what i meant. Fair enough.
The only other thing i can think that it might be is the wrong torque setting. The 18Nm seems unusually low...is that what it says in the manual?
Edit: Also, you can buy just the inner ring (with the tabs) on its own...i'd go for a genuine Peugeot too, at least to eliminate the chance of that gasket being a cheapo one.
https://www.ebay.co.uk/itm/401582731923 ____________________ A Guide To Powerbands |
Farmingstock |
Mr Hammers |
Posted: 22:54 - 02 Sep 2021 Post subject: |
I wouldn't have thought so, tbh. How trustworthy is your torque wrench?
You mention that it's a 70cc upgrade, could it be that the gasket you've used is indeed a cheap one, and it just can't handle the extra capacity? ____________________ A Guide To Powerbands |
Farmingstock |
Mr Hammers |
Posted: 12:56 - 04 Sep 2021 Post subject: |
Sounds like the gasket blew and pressurised into the cooling system, blowing the coolant/exhaust fumes out. All i can suggest is try the new gaskets and see what happens. Good luck. ____________________ A Guide To Powerbands |
Farmingstock |
Easy-X |
Easy-X Super Spammer
Posted: 23:58 - 04 Sep 2021 Post subject: |
I have to say I admire your enthusiasm
20Nm sounds a bit low for head bolts, I'd check to see if that's correct
With regards to "reverse gear" probably there was some kickback when starting. 2-stroke motors have a symmetrical operation - they're entirely reversible - unlike 4-stroke that can't run backwards. (Whether they can run efficiently in reverse is a separate matter!)
Battery charging issue will most likely be the stator, magneto or whatever the bike has or the rectifier/regulation system.
You have no oil pump or the oil pump isn't being fed oil? Bear in mind that these little pumps aren't intended to run dry. 40-1 is perfectly fine for a normal engine but you might consider dropping to 32-1 or maybe 20-1 as it's a fresh head you're breaking in. ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
Farmingstock |
Mr Hammers |
Posted: 02:08 - 08 Sep 2021 Post subject: |
It sounds like the timing is too advanced. If the engines only just ticking over, and the ignition fires too early, it'll send the piston back down before it reaches TDC, causing it to run backwards.
Retarding the timing a bit should stop that. ____________________ A Guide To Powerbands |
Farmingstock |
Farmingstock |
Nobby the Bastard |
Farmingstock |
A100man |
A100man World Chat Champion
Posted: 18:22 - 10 Sep 2021 Post subject: |
Farmingstock wrote: | There is no indicator relay anywhere, would that be on the rectifier?
Can’t seam to find the diodes. |
It looks like the two diodes are they to 'drive' the indicator dash/instrument warning.
One from each indicator set. ____________________ Now: A100, GT250A, XJ598, FZ750
The last post was made 2 years, 228 days ago. Instead of replying here, would creating a new thread be more useful? |
