DUCAUDI |
DUCAUDI World Chat Champion
Zen Dog |
Zen Dog World Chat Champion
MarJay |
MarJay But it's British!
DUCAUDI |
Posted: 13:59 - 01 Sep 2021 Post subject: |
I'm ashamed to say I pretty much left all the settings as standard from when it was new and never bothered to get the user manual out and fiddle with the settings to see what they all do (other than to change from modes A, B, C & D... I'd played with changing the different modes as that's pretty straight forward but each mode is able to be modified and customized in excruciating details so I lust left it on Mode B).
However I got the user manual out last night and familiarized myself with all the menu options. Now I know how the menu works I'm pretty sure I can't have put the suspension to its hardest setting by mistake. I've reset everything to factory settings and put it in mode D (least aggressive throttle, most traction control, softest suspension setting) and it's still a bone shaker.
Something changed half way back from Bristol. Don't forget the rear is sitting very low now and my headlight is dazzling everyone, I was getting flashed up constantly. I'm convinced it's broken. But no error messages or lights on the dashboard
I called the dealer today but they're closed (someone on divert to a mobile answered and told me to ring tomorrow). I'll probably just email them now...
Also does anyone know if the switchgear buttons are supposed to be illuminated? I thought I remembered reading/hearing in one of the MCN reviews that they were but mine are now. Wondering if a wire came loose when they installed the heated grips at the dealer before I picked the bike up ____________________ 2023 DucAudi Mehrstraße V4 Hechte Gipfel - "Objectively the best motorcycle ever produced" - "You can have any colour, as long as it's red"
2021 Honda CMX500 Rebel S |
sickpup |
sickpup Old Timer
DUCAUDI |
sickpup |
sickpup Old Timer
DUCAUDI |
Posted: 18:20 - 01 Sep 2021 Post subject: |
I have. Can't see much. No evidence of oil leaking. Not even sure if they're air shocks? Got to be honest I'm not sure I'd be able to tell the difference between a good shock and a collapsed one unless I had them on the bench side by side.
I'm fairly practical but by no means a mechanic ____________________ 2023 DucAudi Mehrstraße V4 Hechte Gipfel - "Objectively the best motorcycle ever produced" - "You can have any colour, as long as it's red"
sickpup |
sickpup Old Timer
DUCAUDI |
sickpup |
sickpup Old Timer
Posted: 19:31 - 01 Sep 2021 Post subject: |
Leaking oil or gas out of the damper wouldn't normally affect ride height, that's set by the spring. You'd just get a ride like a pogo-stick. Unless there is a remote ride-height adjustment that's crapped out?
So unless there is a crapped out remote ride height adjuster, something is physically broken. Either the spring, the shock mountings or part of the unitrak assembly.
I wouldn't ride it until you've found out what's wrong. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
DUCAUDI |
DUCAUDI |
sickpup |
sickpup Old Timer
Posted: 19:38 - 01 Sep 2021 Post subject: |
See this, its a shock on its lowest preload setting. Either it was adjusted or the lock rings are loose. Thats why you are blinding people.
https://i.ibb.co/X2X2WXf/20210901-191750.jpg
I didn't ask for details, you just didn't give any. |
DUCAUDI |
Posted: 19:39 - 01 Sep 2021 Post subject: |
sickpup |
sickpup Old Timer
Posted: 19:42 - 01 Sep 2021 Post subject: |
And thats the bit of information you should have given us instead of a run around where you don't even tell us what the bike is and start telling us about electronic adjustments. |
DUCAUDI |
DUCAUDI |
Posted: 19:43 - 01 Sep 2021 Post subject: |
sickpup wrote: |
Sorry. But to be fair the bike is in my signature. ____________________ 2023 DucAudi Mehrstraße V4 Hechte Gipfel - "Objectively the best motorcycle ever produced" - "You can have any colour, as long as it's red"
sickpup |
sickpup Old Timer
Ste |
Ste Not Work Safe
Posted: 20:03 - 01 Sep 2021 Post subject: |
Signatures?
Pfffft, BCF is hundreds of times better with signatures disabled. |
Nobby the Bastard |
Old Git Racing |
Old Git Racing World Chat Champion
Zen Dog |
Posted: 23:03 - 01 Sep 2021 Post subject: |
Old Git Racing wrote: | Set the spring so it sags 35mm when you sit on it and try again. |
Out of curiosity, see if the lock ring is loose enough to move at all by hand. If it is, it would indicate that a loose lock ring has caused the adjuster ring to slowly unscrew, lowering your preload and therefore rear ride height over time. I have no idea if it will be though, and it being more than hand tight probably doesn't prove it's tight enough.
As OGR says, you need to screw the adjuster ring down until the sag is about 35m, using a C spanner (I have no idea if you get one with an MT10), or very carefully with a blunt chisel and hammer. Then tighten the lock ring down to stop it moving (...again). You'll probably need an assistant to take the measurements while you're sat upright on the bike.
https://i.imgur.com/oOhsNtb.jpg ____________________ Current - '94 VFR750FR, '00 VFR800FI Previous - '10 Street Triple R, '92 MZ ETZ301, '05 TTR250, NSR125R, KMX125, "Honda" Win (chinese copy of an old Honda design with a C90 engine)
My bike trip around S.E. Asia 2010/2011 |
MCN |
MCN Super Spammer
The last post was made 2 years, 230 days ago. Instead of replying here, would creating a new thread be more useful? |
