Farmingstock |
Farmingstock Trackday Trickster
Posted: 19:25 - 01 Sep 2021 Post subject: |
Well, check it's running on all four first of all. Spot of oil on the headers and see if they burn off at the same time.
Do you have the airbox on? If not, you will probably need it.
If it's like my two VFR750's (3rd and 4th gen) the pump shouldn't be sat in fuel, it's an inline pump that's normally attached to the subframe. The pump is gravity fed from the tank then lifts the fuel to the carbs. It has points on it which spark, putting it anywhere near an open source of fuel is a recipe for a large fire. If you've put it in fuel, you'll need to strip it, clean out the fuel and clean the points with contact cleaner.
Mine runs badly and cuts out if the pump is playing up. that said, I'm not sure if fuel flows without the pump working. I'd expect gravity feed to work at least somewhat, it's not a particularly high pressure pump, more a lift pump because part of the tank is below the level of the carbs..
Of course it matters which order the coil wires are in. There are different firing orders and ignition systems on different models of VFR750. Some have a wasted spark and two pickups on the crank, some have a single spark and have pickups on both the crank and cam. I think you need a workshop manual! ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
Farmingstock |
ThatDippyTwat |
Farmingstock |
ThatDippyTwat |
Farmingstock |
The last post was made 2 years, 237 days ago. Instead of replying here, would creating a new thread be more useful? |
