Fes125 honda s-wing overheating problem
Bazzaboy09
PostPosted: 15:55 - 10 Sep 2021    Post subject: Fes125 honda s-wing overheating problem Reply with quote
My honda s-wing is overheating and water is coming out of the small hole on the expansion water tank cap and.because of this I am losing water. If I take the cap of the expansion tank and when the bike starts to over heat I am getting bubbling in the tank. Someone said this could be a head gasket issue.
slowasyoulike
PostPosted: 21:22 - 10 Sep 2021    Post subject: Reply with quote
Yep, sounds like head gasket failure to me.
jeffyjeff
PostPosted: 06:41 - 11 Sep 2021    Post subject: Reply with quote
Your symptoms suggest further diagnosis is in order.
It could be a head gasket failure; but it also could be that the coolant is boiling if your pressure cap has failed. Before jumping to conclusion, I would test the pressure cap, pressure test the cooling system, and test the thermostat. If the bubbles are apparent only when the engine is overheating, you might check the water pump for proper coolant circulation. Bubbles in the surge tank regardless of temperature suggest head gasket failure.
If the water pump and pressure cap are both working properly, a failed head gasket can allow coolant to leak into the combustion chamber when the engine is stopped, causing hydrostatic lock. Coolant in the engine oil (oil looks like a chocolate milkshake) is also an indicator of a failed head gasket.
The last post was made 4 years, 333 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.42 - MySQL Queries: 14 - Page Size: 35.39 Kb
