Tech Question on 2005 Honda Innova
Philiom
PostPosted: 21:23 - 13 Sep 2021    Post subject: Tech Question on 2005 Honda Innova Reply with quote
I have a 2005 Honda 125 Innova, the lights suddenly stopped working, I have traced the problem back to the rectifier/regulator, have not got 12v on the terminal that connects the brown wire out of the rectifier/regulator when engine is running, apart from the obvious (rectifier/regulator faulty) is there any thing else that could cause it before I buy a new one, everything else works fine. I can get the lights to work by connecting a fused wire straight from the battery to the brown wire on the connector block on the rectifier/regulator, so the loom is OK.
Constructive comments welcome.
PostPosted: 22:49 - 13 Sep 2021    Post subject: Reply with quote
The wiring diagram I'm looking at for an innova doesn't have a brown wire on the reg/reg. In fact, it would be odd to have a brown wire there on a honda because they are usually pretty specific about which colour wire they use for what. A brown wire is usually a switched live. Not saying it's impossible but it's not hondas style.
There may be different setups on different models. Would the main headlamp normally work if the engine is off?
What colour wires are coming out of the reg/rec? The diagram I have has a red, yellow, red/yellow, white, green and white/red. If that's the case, the headlamp is on direct lighting so you'd need to test the output on volts AC NOT DC.
If you have the above colours, there should be a high and fluctuating AC voltage between the white and green wires and a stable AC voltage between the yellow and green with the engine running. There should be coil resistance (engine off) between the white and green.
PostPosted: 22:59 - 13 Sep 2021    Post subject: Reply with quote
Constructive comments eh?
What. no burn it send it to hell type stuff?
Philiom
PostPosted: 11:31 - 14 Sep 2021    Post subject: Rectifier issues Reply with quote
Sometimes I feel like burning things!!
Philiom
PostPosted: 11:54 - 14 Sep 2021    Post subject: Re: Tech Question on 2005 Honda Innova Reply with quote
Thanks for the reply, The wiring diagram you have maybe the later model, mine is the early model. Going to investigate more, apparantly there is no test for the rectifier. I tried to add the wiring diagram in attachments but no luck.
PostPosted: 12:14 - 14 Sep 2021    Post subject: Reply with quote
If you've got the correct wiring diagram, that would be great, should then be able to be more specifically helpful.
There's an 8MB limit on images in attachments but a 32MB limit on .zip files so if it's a big one, attach it as a compressed folder. I think you need to have posted a few times before you're allowed to attach files, your karma blob has gone green now so worth another try.
You're correct in that there's no good way to test the reg/rec with conventional testing equipment but you can test all the other bits associated with the lighting system and if they're all ok, it has to be the rectifier at fault.
Philiom
PostPosted: 21:31 - 14 Sep 2021    Post subject: Reply with quote
Problem solved! there was nothing coming from the stator to the rectifier, the block connector which has the green and white wires from the stator had become disconnected, sorted, all working, thanks again for your help.
About the attachment , I wondered why the it would not go through!
Phil
The last post was made 2 years, 224 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.68 - MySQL Queries: 17 - Page Size: 54.28 Kb
