honda dylan 2005 overheating
DualGlock
PostPosted: 22:16 - 15 Jun 2022    Post subject: honda dylan 2005 overheating Reply with quote
Hey guys, so I have a honda dylan 125cc from 2005 that I use to drive around private land as it has no paperwork or license plate. It used to run well until a month ago when I took it out after a few years of laying around and had to get the carb off to clean the jets. I also had to replace the coolant hose but I replace it with a water hose lying around. After a few hours of riding around, the temperature warning light was showing up on the dashboard. The coolant hose would eventually come off due to heating up and would spray hot coolant everywhere. After a few minutes of riding, the exhaust pipe would get very hot to the point where it would start smoking even with coolant filled to optimal level. Also, when the coolant sprayed out, It would be a green colour (originally pink)and have a smell similar to urine. My assumption is that the problem is the water hose that I used for coolant but I am not experienced in motorcycles. Also, I am in a different country so do not have access to the bike and will be back in around a month. Thanks
jaffa90
PostPosted: 00:10 - 16 Jun 2022    Post subject: Reply with quote
""""I replace it with a water hose lying around. """ Shocked
Is the top hose ,radiator and bottom hose getting hot?
Also what does the spark plug colour tell you?
Also how do you drive a bike / scooter? Laughing
sickpup
Old Timer
PostPosted: 00:00 - 18 Jun 2022    Post subject: Re: honda dylan 2005 overheating Reply with quote
So it's stolen then.
So the hose either didn't fit or you didn't fit a hose clip to hold it on.
SOunds like it overheated and you've pretty much killed it.
slowasyoulike
PostPosted: 14:26 - 18 Jun 2022    Post subject: Re: honda dylan 2005 overheating Reply with quote
So you've bodged the cooling system, overheated and fucked your scooter.
Was there supposed to be a question in there?
The last post was made 4 years, 128 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.29 - MySQL Queries: 14 - Page Size: 42.26 Kb
