Cbf600 no spark issue
Gizzy
PostPosted: 14:36 - 03 Oct 2021    Post subject: Cbf600 no spark issue Reply with quote
Totally new to this, but worth a shot.. Bought a nackered 2004 CBF600. Been piecing it together slowly and found that just as I try to run, it wont spark.
Fully charged battery, checked all possible kill switches, checked resistance in coils, pulse generator...
Power is getting to the coils but the ground isn't being switched on with ignition. Guessing this is what allows spark.
My only thoughts about what it could be is stator, pulse generator or CDI. I changed the ignition barrel to Chinese but I didn't think it has hiss.
Any help massively appreciated
PostPosted: 16:49 - 03 Oct 2021    Post subject: Reply with quote
Get a wiring diagram and test all the things in the ignition circuit. I'm assuming this is an early EFI bike in which case you can ignore the charging circuit side and just focus on safety cut out switches, crank position sensor, etc. but if the ECU fucked there's not much you can do about that.
<edit> soz, 2004 is carb Rolling Eyes At least you don't have to about the ECU Smile
PostPosted: 18:44 - 03 Oct 2021    Post subject: Reply with quote
Earth from the engine to the frame.
Hang on, your bike is HISS? It has an imobiliser.
Gizzy
PostPosted: 19:02 - 03 Oct 2021    Post subject: Reply with quote
It's carbed. Used wiring diagram to rewire most of it. Lights and starter motor work so surely the earth's are fine? It's turning just not sparking
Gizzy
PostPosted: 19:03 - 03 Oct 2021    Post subject: Reply with quote
Not sure if it's HISS but there's nothing to indicate that it is
colink98
PostPosted: 09:33 - 04 Oct 2021    Post subject: Reply with quote
these also have a cut off connected to the side stand ?
will that kill the spark ?
PCX125 (stolen) - CBF600 (current)
Ride it like you stole it.
ride sensible and not like an idiot and you wont get 6 points in one week.
sickpup
Old Timer
PostPosted: 10:30 - 04 Oct 2021    Post subject: Re: Cbf600 no spark issue Reply with quote
It probably does have HISS, it was fitted to bikes from about 2001.
The other possible issue is that the original ignition probably has a resistor in it to drop the CDI voltage input to 9volts, most Chinese ignitions don't have it. This is a Honda anti hotwire thing and is routinely missed.
sickpup
Old Timer
PostPosted: 10:38 - 04 Oct 2021    Post subject: Reply with quote
Just checked on Fowlers and the CBR600F 2004 UK model does have HISS.
The last post was made 2 years, 204 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.29 - MySQL Queries: 17 - Page Size: 56.14 Kb
