max b |
max b L Plate Warrior
jaffa90 |
jaffa90 World Chat Champion
Posted: 17:17 - 07 Oct 2021 Post subject: |
That looks like the starter solenoid / relay switch stuck in the on position and cannot be switched off with the ignition key, disconnecting the battery will do this. So you will need to find out why.
It looks expensive. |
Nobby the Bastard |
WD Forte |
WD Forte World Chat Champion
max b |
max b |
Irezumi |
Irezumi Nitrous Nuisance
MCN |
MCN Super Spammer
Posted: 17:11 - 08 Oct 2021 Post subject: |
Main Power Relay.
The ignition switch sends small power to the small wires on the relay, that creates a magnetic field which pulls two heavy contacts together and allows big power to surge through those big cables.
If it shorts/fuses/malfunctions in a bad way, the contacts xan weld together, then turning the key off won't have any effect as the machine is now in control of everything. (Skynet, we all knew that it was always only a matter of time.)
Might be expensive but might just cost a new relay.
Possibly ask an auto-electrical to have a shoofti at the bastirt for you. Before it goes up in smoke/ball of fire next time the battery sends power to the relay. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
Tdibs |
Tdibs Traffic Copper
The last post was made 2 years, 199 days ago. Instead of replying here, would creating a new thread be more useful? |
