Posted: 19:45 - 22 Oct 2021 Post subject: Radiusing/polishing piston crowns? *Now with added fail* |
Been having detonation issues on my bigbore, high compression enfield bullet. A long ride up a pretty steep hill on motorway on my recent Spanish trip was causing intermittant detonation and lead to a seizure which did free off quickly and continued running for about 1000 miles. I threw a sticking plaster at the issue at the time by adding some royal purple octane boost* to the fuel which pretty much stopped the detonating.
Going to do a teardown tomorrow to see if the piston is toast or not, check bore, ring gaps, land clearances, etc. Hopefully not marked the bore too much and can give it a hone and new rings
Obviously checking timing and mixture is the main event but I've seen it suggested that one issue with these accralite forged pistons is that they have pretty sharp edges around the valve cutaways which can make them both noisy and more prone to detonation and that radiusing off the edges can be beneficial.
https://lh3.googleusercontent.com/pw/AM-JKLWXcey8AYmu28N5QbKXZqF4lPx7KSoEKHAjFwcPyZlz_iq8-sll0HfNRxYQFZVCtVl3W244YyUqDDKttqZ5DBA_0XkrasEZNb9-rJJPXLp5FqKyof1FwIwCLxAA2wlGXtzzZoxfHQFuV-TW5WCsPwpg=w1182-h886-no
The question is how? Someone warned me off using emery cloth because abrasive particles can get embedded in the aluminium.
I was thinking I can rough it in with needle files (going in at 90 degrees to the "point" then at 90 degrees to the two new points in the same way you'd round a square by going square, octagon, round), then polishing out the file marks with increasing grades of abrasive.
Would using a rotary tool be a stupid idea?
In terms of abrasive, wet and dry? Abrasive stone? Grinding compound? Polish on wire wool?
Obviously it'll get a damned good clean in the ultrasonic, soapy water then solvent afterwards to remove any residues.
*I took some with me in case I couldn't get super unleaded locally. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
MCN |
MCN Super Spammer
Easy-X |
Easy-X Super Spammer
Posted: 16:58 - 23 Oct 2021 Post subject: |
Well. Piston is toast. There are some marks on the bore but having run a hone down there, while still visible, I can't feel any of them with a fingernail, they're no deeper than the honing marks.
Here's the damage...
https://lh3.googleusercontent.com/pw/AM-JKLXLII3xc43v-Gh6k1B8WYPXG6LOj1hTIouUgfd77bzFWMk8puRlOmw2Wwak9d3KwJkS0AeFWxkkvlamtdLaJRIZI1n5BeqxDs8rQbND4oWjHz4-FGkbzYClZButiOrpE11DajC7p5TfbqBLn2m2xG0w=w1576-h886-no
As well as the seizure you'll notice the piston has cracked through the gudgeon pin boss.
https://lh3.googleusercontent.com/pw/AM-JKLWwlFNpy4uAsr4UN2MylKHLxhuu4AnA3jgvt5UJ2QNTaph5lo8syLx76MycHsVrVTyFGheUw48YVZvxPENafPFU2XmVu1BN8PhfoIxJmp24PhnR_F3B9O4plA_f2R0KfDAzjk-I2h88V2uDrzfxDhUy=w1576-h886-no
Interestingly, when you look at the underside, none of the heat from the seizure has transferred across the crack. This suggests to me that it seized because of the crack springing the piston skirt out rather than cracking because it seized. The crack must have been there before the seizure occurred or there would be scorching both sides of the crack?
https://lh3.googleusercontent.com/pw/AM-JKLVmi4gd9KYcL0ABdEbtmjy5CMAXasqpwiqoa4qVR1jZKNEDQL08_zUYkE6lFZ5wzBPN73OZNlogY75wK4vOtIJ4jlqaDMCVIh9tIJdAYE1L-y2vmInJI9droj3XqgVKzVZUxFay6jApKFZY8Z_oFD4V=w1576-h886-no
There are also two cracks in the ring land area between the two compression rings. Not sure what to make of these, cause or effect?
https://lh3.googleusercontent.com/pw/AM-JKLVUiaGhmMni6lQWhSU0BtoGeJw3ch21ogVoMTeiXpiDaQ_f6Afv7op0NYJNIJS15Ybc0pt6DsZkryEcKzgBPZq4-oNAR1wUBJAVLa5x21lKhwEqq-R-DwMGNvtwd6yRu5wqI4bzVYXdRemrwZ-vpvE2=w1576-h886-no
There is no evidence of nibbling/pitting on the piston crown like I'd expect with detonation.
I'm not sure but I wonder if one of the big backfires it was doing before I got the timing dialled in caused a crack to start and it's been slowly propogating until it finally let go in a bigger way.
I'm astounded it kept running for as long as it did. Look how much play there was on the piston! Miraculously, there doesn't seem to be any damage on the small end.
Link to short video ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
MCN |
MCN Super Spammer
Robby |
Robby Dirty Old Man
Robby |
Robby Dirty Old Man
Posted: 23:33 - 23 Oct 2021 Post subject: |
I'm thinking there may have been a single "event" that's at the root of this. Possibly dating back to however the hell it managed to bend the inlet pushrod a few months back. I'm leaning towards a particularly violent backfire on startup before I had the timing dialled in properly.
The compression isn't proper stupid, it's 10.3:1. The scrambles guys running on dope have them WAY higher than that.
I'm also now wondering if what I thought was detonating was actually the sound of the piston coming apart because the crown and inside of the head look fine, no pitting or hotspots. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
steve the grease |
Robby |
Robby Dirty Old Man
MCN |
MCN Super Spammer
Posted: 17:20 - 24 Oct 2021 Post subject: |
I'd buy two of those beauties and have one as a paperweight for the desk.
If you still use paper. ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
colink98 |
colink98 Could Be A Chat Bot
Posted: 16:04 - 26 Oct 2021 Post subject: |
Hmmm. Interesting. The used piston that just arrived has already been mostly radiused, just needs a clean up and light polish. That's saved me a good 3 or 4 hours!
Presumably it's from a development engine because I can't see why they'd have a stock of low mileage, used pistons otherwise. So given these pistons were manufactured for the company I bought it from, radiusing seems to be the way to go. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
bikenut |
bikenut World Chat Champion
Pete. |
Pete. Super Spammer
Pete. |
Pete. Super Spammer
The last post was made 2 years, 173 days ago. Instead of replying here, would creating a new thread be more useful? |
