pepperami |
pepperami Super Spammer
Posted: 22:34 - 28 Oct 2021 Post subject: Non running puzzle? |
So Project Scrappy Hyosung 125 is still ongoing .
So the problem is to do with it not continuing to run after being started?
New valves, new guides, new cam-chains & guides/tensioners, new carb rubbers, new plugs , good compression, fuel, spark,etc.
The engine will start and sounds good (quiet & no unusual rattles).
It will run for about a minute or two and then just cuts out????
Any ideas oh mighty and wise BCF.
please ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
xX-Alex-Xx |
Kawasaki Jimbo |
pepperami |
pepperami |
pepperami |
Posted: 22:58 - 28 Oct 2021 Post subject: |
Fck fckity fcky !
I’ve just found one issue that might not be helping the situation!
The choke cable and choke handlebar lever are missing
The bike has no choke to start from cold.
This might not be the problem, but it might be a contributing factor. ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
WD Forte |
WD Forte World Chat Champion
Posted: 01:27 - 29 Oct 2021 Post subject: |
Sticking floats/needle valves? After it's conked out, try cracking the float bowl drains to see if there's fuel in them.
I had similar on a KLE500 and it turned out to be ethanol damage on the needles causing therm to go furry and stick in their seats. The float bowls were filling but only very slowly. Fixed by replacing them with modern viton tipped needles. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
blurredman |
Posted: 09:15 - 29 Oct 2021 Post subject: |
How many years have you been working on this bike? ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
Current: 1973 MZ ES250/2 - 17k. , 1979 Suzuki TS185ER - 9k, 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (295cc) - 38k, 1989 MZ ETZ251 - 49k |
bikenut |
bikenut World Chat Champion
pepperami |
pepperami |
Posted: 10:04 - 29 Oct 2021 Post subject: |
Robby |
Robby Dirty Old Man
blurredman |
Posted: 10:09 - 29 Oct 2021 Post subject: |
If it's running okay when cold but without the choke cable connected, then perhaps it's running rich? What do the sparkies look like? ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
pepperami |
MCN |
MCN Super Spammer
Jim Mc |
Jim Mc Nearly there...
Andy Perrett |
Andy Perrett Crazy Courier
Nobby the Bastard |
Andy Perrett |
Nobby the Bastard |
Posted: 16:23 - 04 Nov 2021 Post subject: |
Cable Tie wrote: | stinkwheel wrote: |
However he didn't read through the thread before posting.
pepperami wrote: | I did also suspect possibly maybe might be a cruddy manky fuel tap?
However it still does it even with a remote tank. |
Even a remote tank won't rule out a blocked filter in the carb fuel inlet, which many bikes have. Worth a check.
If not, then it will be the part of my post, you conveniently ignored
Quote: | Sounds like fuel starvation.
Pull the petrol line off the carb and check the flow. Is it a dribble or a flow?
If the fuel tap is vacuum operated (has a second thinner hose going to the carb or inlet manifold), take it off carb end and suck on it to create fuel flow.
Sounds like if left it fills the float bowl, then can’t refill it fast enough to meet demand. If tap flow to carb is good, probably time to take the carb float bowl off and clean out the carb. |
have you chosen an irrelevant point to pull apart and bitch about?
Cable Tie wrote: |
then pointless side comments are pulled apart and even lies are made up to bitch about and try to prove wrong.
____________________ trevor saxe-coburg-gotha:"Remember this simple rule - scooters are for men who like to feel the breeze on their huge, flapping cunt lips."
Sprint ST 1050 |
Andy Perrett |
Easy-X |
Easy-X Super Spammer
Posted: 21:06 - 04 Nov 2021 Post subject: |
Had some poor running on the Kwacker. Pulled the fuel lines and eyeballed the flow from the pipes. All looked good
In the end we dropped the bowls with the the carbs in place. One carb had a lot more flow pissing out than its partner and it turned out one of the T-pieces from the fuel pipe was blocked on one side. ____________________ Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
The last post was made 2 years, 173 days ago. Instead of replying here, would creating a new thread be more useful? |
