Has anyone had confirmed E10 woes?
SirFallalot
PostPosted: 19:57 - 22 Nov 2021    Post subject: Has anyone had confirmed E10 woes? Reply with quote
Was having the usual discussion with a friend about "how it leads to problems on older bikes as materials get corroded/worn/generally fecked" vs "E10s always existed, always put it into my non compatible bike, it still runs great and will forever".
Has anyone had any Confirmed "E10 ate my hamster" problems?
I've used it a couple times where E5 was unavailable, don't remember noticing a diff except it was cheaper Laughing I use it because Kawasaki advises to, but would rather pay less
Lexmoto Valiant 125; 94 CB400; 96 CB750F2; 81 CB750 (restoring, lol not gonna happen); 2001 ZX9R(It's about to go :c); 2012 R1200R; 2015 R1200RS
PostPosted: 20:01 - 22 Nov 2021    Post subject: Reply with quote
Had the needle valves on a 1996 KLE500 fur up to the point they stuck open, flooded the airbox and set the bike on fire while I was riding it (thankfully self-extinguished).
I'm blaming E5 in fairness, it was the classic damage that kind of thing causes and the carbs had been cleaned out about 3 months previously when there was no sign of any corrosion in that area. Replaced the valves with ethanol compliant ones.
SirFallalot
PostPosted: 20:04 - 22 Nov 2021    Post subject: Reply with quote
I just got an epic image from that, thanks Laughing
Kawasaki Jimbo
PostPosted: 20:41 - 22 Nov 2021    Post subject: Reply with quote
I’ve been running E10 in my ‘99 ZX6R, which was fine until there was a slight chill in the air, then it had some starting problems. In fairness it’s overdue for a valve clearances check so it could be that. I’ve taken it off the road with the intention of doing the job, but I did wonder what the starting qualities of E10 are like. There’s some speculation on the internet that it might affect cold-starting, but little hard evidence.
tatters
Exxon Valdez
PostPosted: 21:14 - 22 Nov 2021    Post subject: Reply with quote
Canada had had E10 for years, It seems to gum up carbs with corrosion a lot faster when they are left sitting with the E10 fuel in them for a few months. The worst is always the small engines such as my pressure washer with a small carb with tiny orfices.
I either make sure l add a fuel stabilizer additive and/or fill up with premium fuel that has no ethanol.
Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650 Present:G650XC,C12,KZ750,1190ADV
doggone
PostPosted: 22:52 - 22 Nov 2021    Post subject: Reply with quote
I've used a couple of tankfuls, it seems to give about 10% lower mpg but as always it's hard to be directly compare.
That's not going to reduce emissions much.
jaffa90
PostPosted: 23:02 - 22 Nov 2021    Post subject: Reply with quote
E10? E5 is bad enough because where i live it`s all E5 now.
As posted before i had to chuck all my "suitable for unleaded fuel" pipes because they go slimy inside with E5.
I have also noticed that when leaving E5 fuel overnight in a container (pot noodle cup) it has water in the bottom through absorbing moisture.
Also carbs will not varnish up as years ago they will go rusty.
xX-Alex-Xx
PostPosted: 23:23 - 22 Nov 2021    Post subject: Reply with quote
I've had the FI light come on randomly when turning on the ignition from cold that coincided with first tank of E10. It's only happened a couple of times but timing of it was a bit weird. Not actually been arsed to lift the seat and put it into dealer mode as ignition off/on has sorted it.
DILLIGAF
PostPosted: 12:14 - 23 Nov 2021    Post subject: Reply with quote
As I mostly work from home now I've only just done my first full tank of E10 and noticed absolutely nothing. Modern EFI bike though.
Freddyfruitba...
PostPosted: 12:35 - 23 Nov 2021    Post subject: Reply with quote
No problems using it here, but I feel that any issues are likely to be medium-long term so people are unlikely to be reporting them yet.
There is concern in some quarters over the likelihood that E10 will absorb significant amounts of water if left for longish periods, which is clearly a Bad Thing in fuel tanks etc. I've just taken the precaution of filling up with premium petrol this month, as my miles ridden per month falls off a cliff during the winter months.
Islander
PostPosted: 12:56 - 23 Nov 2021    Post subject: Reply with quote
I'm grateful for the fact that I'm in one of the E10 exempt areas of the UK.
If we ever got it here, I'm not sure any of the petrol stations would have the capacity to run an E5 pump or two and that would be a headache for a lot of people running small engines let alone the vintage crowd.
blurredman
PostPosted: 13:27 - 23 Nov 2021    Post subject: Reply with quote
No confirmation of anything in that regard for me yet.
But using on all my bikes (signature), and my 1980 Buick LeSabre, and my '91 Peugeot 205 1.1l (carb).
No problems regarding running at least.
Current: 1981 Honda CX500B - 91k, 1987 MZ ETZ250 (bored to 295cc) - 38k, 1990 MZ ETZ251 - 49k, 1979 Suzuki TS185ER - 9k, 1973 MZ ES250/2 - 17k.
doggone
PostPosted: 14:06 - 23 Nov 2021    Post subject: Reply with quote
I'm struggling to see how E5 still being made for relatively small areas (and why)
Islander
PostPosted: 14:16 - 23 Nov 2021    Post subject: Reply with quote
We hold a decent reserve of fuel (IIRC about 4 months worth) in bulk tanks from which the wholesaler supplies the fuel distributor. It also comes in by sea and both of those things mean E10 isn't likely to arrive here.
weasley
PostPosted: 14:45 - 23 Nov 2021    Post subject: Reply with quote
By what mechanism does this happen? What you appear to be saying is that the E5 fuel has absorbed water (presumably from humidity in the atmosphere) and then desorbed (dumped) it back as free water.
Just eyeballing the chemistry, the Pot Noodle cup has a relatively small surface area and even at 100% humidity there's not a lot of water available at a typical room temperature. The fuel is only up to 5% ethanol and the other 95% is a hydrophobic hydrocarbon. Also, once water is bound to ethanol it is quite reluctant to let go.
I don't know the timescale of your experiment but if it happened over a few hours or days then we'd be best served leaving Pot Noodle cups of fuel about the place as dehumidifiers to control any damp issues.
doggone
PostPosted: 14:55 - 23 Nov 2021    Post subject: Reply with quote
You would think that keeping the tank full would minimis the amount of air in contact - advisable anyway to avoid condensation.
Obviously the tank isn't 100% airtight but not much exchanging going on.
xX-Alex-Xx
PostPosted: 14:59 - 23 Nov 2021    Post subject: Reply with quote
It's not dumping it back as free water. The water binds to the ethanol and sinks to the bottom, leaving the petrol on top.
You can use this method to extract the ethanol out of fuel, literally mix water in with petrol, leave it overnight, and you'll have a bottom layer of water/ethanold mix you can drain off. People are already doing this for lawnmowers etc which would get fecked by E10.
DILLIGAF
BTTD
PostPosted: 15:38 - 23 Nov 2021    Post subject: Reply with quote
This, there are some interesting vids out there where people are doing this, and others where they've left stuff in E10, E5 and full fat fuel for months to what (if anything) happens.
TL:dr I think there's going to be a lot of unaware people with fucked lawnmowers next spring.
For those that are aware, there are some premium unleaded fuels that contain little to no ethanol.
PostPosted: 16:17 - 23 Nov 2021    Post subject: Reply with quote
Meh, mine's electric.
PostPosted: 17:44 - 23 Nov 2021    Post subject: Reply with quote
xX-Alex-Xx wrote:
You can use this method to extract the ethanol out of fuel, literally mix water in with petrol, leave it overnight, and you'll have a bottom layer of water/ethanole mix you can drain off. People are already doing this for lawnmowers etc which would get fecked by E10.
But don't do it for your bike because if it's 10% ethanol (which is 116 octane) and started as 95 octane, once the ethanol is removed, the remaining fuel will be 93 octane. Probably wouldn't bother a lawnmower but holes in motorcycle pistons often offend.
PostPosted: 20:00 - 23 Nov 2021    Post subject: Reply with quote
Could probably "tune out" that problem with an EFI bike. Looking at it the other way I'd like to see a YouTuber dyno a bike on E5 & E10 Thinking
Kawasaki Jimbo
PostPosted: 20:37 - 23 Nov 2021    Post subject: Reply with quote
I could be wrong but I think that happens more in the absence of ethanol. Petrol and water don’t mix but add ethanol and it allows water to disperse throughout the tank (-reduced metal surface contact compared to settling). When the water load saturates the ethanol the water will then fall to the bottom but until that point the ethanol is actually helping the tank corrosion situation. I’m more worried by ethanol’s ability to soften and break unsuitable hoses, and its uncertain influence on cold-starting.
I believe weasley works in the petro-chemicals industry so may be able to advise with some expertise.
Islander
PostPosted: 20:39 - 23 Nov 2021    Post subject: Reply with quote
You could add an octane booster...
rpsmith79
PostPosted: 08:14 - 24 Nov 2021    Post subject: Reply with quote
..... which typically contain ethanol Laughing
kgm
PostPosted: 10:15 - 24 Nov 2021    Post subject: Reply with quote
Shortly after switching to E10 my 2019 CRF250L had a little trouble starting after a two week layup. Not too bad but it cut out when I throttled up leaving my street, then kangarooed a bit after restart. Quickly cleared. No issues since but it's been in more regular use since then.
The last post was made 2 years, 146 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.53 - MySQL Queries: 17 - Page Size: 138.57 Kb
