Alum ???
bikenut
PostPosted: 09:08 - 23 Nov 2021    Post subject: Alum ??? Reply with quote
Any chemical engineers out there...
Anyone used "alum" to eat away a steel screw sheared off in an aluminium hole ?
Anyone ?
nuts about bikes
PostPosted: 09:44 - 23 Nov 2021    Post subject: Reply with quote
I haven't but it does work. it needs to be strong alum and it needs to be hot and it takes a while.
You'd effectively need to be able to immerse the aluminium part in the stuff in a heated container like a cooking pan just off the boil. They use it a lot for extracting broken drill bits or taps from complex pneumatic valving.
Not going to be much use for say a snapped exhaust stud. While you could immerse the head in a big pan of the stuff, it would also eat the valve seats and any other permanantly affixed steel componants. It would do well at removing a seized in brake calliper bleed nipple or a sheared carb bolt once you have it fully stripped of all other non-aluminium componants.
PostPosted: 10:32 - 23 Nov 2021    Post subject: Reply with quote
This short video shows it working on a steel screw in brass
https://www.youtube.com/watch?v=JCADI0YSt8M
so we know it works
but as stinkers points out, there are practical issues to consider
plus time.
For exhaust studs etc I'd probably be looking at the
weld or drill/easy out/helicoil processes
PostPosted: 17:51 - 23 Nov 2021    Post subject: Reply with quote
In other chemistry, you can dissolve brass out of aluminium using concentrated nitric acid. Has to be concentrated, not dilute. Good luck getting hold if it though and probably not really something to be trifled with.
The last post was made 2 years, 154 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.4 - MySQL Queries: 17 - Page Size: 41.66 Kb
