Replacement from stock exhaust advice - ER6n
kawakid
PostPosted: 21:33 - 01 Dec 2021    Post subject: Replacement from stock exhaust advice - ER6n Reply with quote
Hi All,
A bit of advice please and I am sure to many it will seem a bit daft.
I've had an ER6n since new its a 2008 and I use it to commute on.
I've gone through about 4 exhausts since new, I ride pretty much all year round apart from snow/ice etc. Each exhaust replacement has been with a stock exhaust i.e. Kawasaki code 18091/A .
I've had a look on ebay and I can't see a decent second hand one and a replacement new is about £600.
This is too much. A quick google search gives me options.
I've seen a Black Widow Exhaust , which is remarkably cheap.
Its obviously a different mount and I presume looking at the picture all the little mounting things etc, will hold it in place.
But I am concerned about connecting it to my downpipes and the oxygen sensor. Do I need some sort of oxygen sensor eliminator.
When i've changed the stock exhaust before , i've needed to buy a gasket muffler this being kawasaki code 18140 . Which now look difficult to get hold of. (but it simply a crush device, which creates a seal, so perhaps there is another alternative).
This is the exhaust I am interested in.
https://www.blackwidowexhausts.co.uk/ninja-er-6n-er-6f-er650-05-11-low-level-exhaust-silencer-300mm-oval-black-stainless-7158-p.asp
This is the schematics
https://www.kawasakioriginalparts.com/road-bikes.html?blockref=99912-1398.B-07&machineid=730&year=2007&model=ER650A7F&country=GB
Any advice greatly appreciated. Cool Very Happy
I've a twin and a 4.
cresad
PostPosted: 22:51 - 01 Dec 2021    Post subject: Reply with quote
Looking at the black widow set up it comes with the link pipe which has the socket for the oxygen sensor. It also looks like the joints are clamp fit so I would think a smear of exhaust paste should be enough around the pipe them clamp the pipe over it.
Adam
PostPosted: 00:47 - 02 Dec 2021    Post subject: Reply with quote
https://www.wemoto.com/bikes/kawasaki/er-6_n_b8f_(abs)/08/picture/seal_-_downpipe_to_silencer_%28graphite%29
Looks like they are out of stock, however, if you search by category, they have a lot of their exhaust gaskets listed by dimension if you have the time to trawl through them.
Otherwise, plumbers silicone for the win.
Or ask Black Widow if they can supply one?
xX-Alex-Xx
PostPosted: 09:29 - 02 Dec 2021    Post subject: Reply with quote
O2 eliminators are just a resistor in a "stock" connector. If you can't find one online (they're usually about 5-10 quid), you can use the connector off the stock O2 sensor and wire in a resistor of about 300 ohm (higher is ok too). Chances are you'll find someone selling them on ebay.
As mentioned though, it looks like it has the bung for the stock sensor on the pipe anyway.
DILLIGAF
Tdibs
PostPosted: 12:01 - 02 Dec 2021    Post subject: Reply with quote
Quite amazed the stock exhuasts are going that fast, the full system or just the silencer?
Delkevic also have fairly cheap silencer offerings.
https://delkevic.co.uk/s/Kawasaki/ER6N/2008?product_id=80285
kawakid
PostPosted: 13:52 - 03 Dec 2021    Post subject: Reply with quote
The downpipes went at 23 months and 3 weeks, which was fantastic as they were still under warranty.
But the muffler is now the fourth or fifth, the bike has done about 50K.
Sometimes the ends break (this is what happened last year and i've bodged it with an exhaust bandage), othertimes the stock exhaust has developed a tweeting noise and loss of power.
kawakid
PostPosted: 20:53 - 03 Dec 2021    Post subject: Reply with quote
Thanks for that Tdibs, I've bought that one and its coming Monday, I prefer it being stainless steel rather than black.
xX-Alex-Xx
PostPosted: 23:34 - 03 Dec 2021    Post subject: Reply with quote
Sounds like you need some ceramic coating on the pipes. And not riding across the Dead Sea to commute Laughing
DILLIGAF
kawakid
PostPosted: 23:48 - 03 Dec 2021    Post subject: Reply with quote
Shame i live on top of the highest hill in the pennines.
The last post was made 2 years, 143 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.27 - MySQL Queries: 17 - Page Size: 64.2 Kb
