Flueless gas fire - wall hung
PostPosted: 13:24 - 03 Dec 2021    Post subject: Flueless gas fire - wall hung Reply with quote
anyone got one?
are they any good?
Looking to (eventually) replace the 1970s gas fire front of my now decommissioned Baxi Bermuda.
PostPosted: 13:29 - 03 Dec 2021    Post subject: Reply with quote
PS @ HelKat - that's Wall Hung before you get all in a dither Rolling Eyes
PostPosted: 13:44 - 03 Dec 2021    Post subject: Reply with quote
Shocked
Oh
Wall....
panrider_uk
PostPosted: 01:15 - 07 Dec 2021    Post subject: Reply with quote
You mean a catalytic one?
Yep, got one.
Chucks out lots of heat, works well but you do need ventilation in the room as you do get water vapour as a by-product
Current bike: Honda ST1100
duhawkz
PostPosted: 01:41 - 07 Dec 2021    Post subject: Reply with quote
yeah had a couple, as above really
they look nice and chuck out a load of heat, as pan rider mentioned you need a vent
the last one I had needed a 100cm vent, only problem I found was that in winter the vent made the room cold, you also could hear people walking past chatting and it made a noise in strong winds. I believe you can get vents with baffles in that might reduce the noise some what
PostPosted: 11:14 - 07 Dec 2021    Post subject: Reply with quote
Thanks guys.. Yes I think they are all catalytic. I spotted a couple of SMEG branded ones on ebay but I think they are Focal Point rebrands.
I have a (2 brick!) vent already for the open flue Baxi Bermuda that is now decommissioned and yes the wind does howl through so it is currently taped up.
I read that some have oxy sensors that cut it out if there's not enough air supply which I doubt will be an issue on my case since there's no
door on the knock through kitchen/diner to the hall/stairs etc.. (30s design semi).
Condensation is a concern since there no flue for the products of combustion - you might think there'd be one to buy with a built-in condenser..
PostPosted: 11:18 - 07 Dec 2021    Post subject: Reply with quote
100cm2 right ? so about one brick..
For some reason there's vents everywhere n this house. Another 2 bricker in the bathroom and one in the small bedroom the latter is especially baffling.
duhawkz
PostPosted: 00:25 - 08 Dec 2021    Post subject: Reply with quote
yeah some thing like this
https://www.fireplacestoreonline.com/air-vent-100cm-free-area/
it will tell you in the instructions for the fire what you need
JackButler
PostPosted: 21:08 - 10 Dec 2021    Post subject: Reply with quote
Has Sir considered a bio ethanol burner???
They don't have to look out of place unless they in a $15million Manhattan bedsit, nor do they have to look like Al Pacino's cauldron in The Devils Advocate.
No flue required, totally smokeless & you don't notice any room aroma unless you walk into one from outside.
Butler Towers has a snug / reading area by a BIG window where we opened up the old fireplace but left the flue blocked, placed a purpose 1l built tank inside a cast iron grate & smothered that with the type of logs you find in gaslog fires.
Kicks out about 1kw of heat on the few occasions I light it & it's only purpose is to provide the ambience of a natural flame, which it does quite well.
I clean my guns with the tears of the snivelling, left wing scum.
to v or not to v
PostPosted: 12:37 - 11 Dec 2021    Post subject: Reply with quote
and how much does one of these cost to run?
JackButler
PostPosted: 13:20 - 11 Dec 2021    Post subject: Reply with quote
We only use it as a feature, not for heating.
I bought this winters fuel,12l for £30 (£2.50per litre). 1/2 litre in the tank lasts approx 2-2.5hrs, (tanks with ceramic wool/sponges may be better). Our tank fits inside a traditional cast grate & gives a 5" wide flickering flame, I'd imagine that the more 'designer' / wider tanks burn more in proportion. I reckon this setup kicks out 1kw of heat, not sure if that scales up to 2kw with 10" wide flame?
Think of the benefits, nothing is better than a real flickering flame, no ashes, no maintenance. The only downsides I can think of is it won't toast bread/marshmallows & you can't chuck any rubbish on (like Jack did the first time he met his mates Gaslog Smile ) The missus puts essential oils in a small pot & places it near the flame, she reckons this comes close to her personal heaven !
Don't get me wrong, I'd put in an open log burner grate or multi fuel stove in tomorrow if it didn't cost norf of £5grand to reopen the chimney & fit the flue . . . .
The last post was made 2 years, 135 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.17 - MySQL Queries: 17 - Page Size: 71.52 Kb
