Problems with brakes sticking
Eofer
PostPosted: 21:46 - 14 Dec 2021    Post subject: Problems with brakes sticking Reply with quote
MY bike (Yamaha MT09) has recently developed a problem with the brakes sticking on. After being left outside at work all day and after some heavy rain the bike was very difficult to wheel around around and brakes appeared to be seized up some how. Got it moved and going and was OK to ride and once got home was able to wheel around.
Following morning after being in garage brakes again stuck, got to work and bike again OK to wheel around. Come home time same thing and brakes stuck on.
Does any one have any advice on this and what do, something to do with rust forming after being left in rain? felt a bit odd that it keeps happing even and after being left in garage and was no rain today
PostPosted: 23:01 - 14 Dec 2021    Post subject: Reply with quote
Probably just rust on the disc. if it frees off after a very short distance, I wouldn't worry. Just because your garage is dry, doesn't mean it's low humidity. Condensation likes to form on cold metal so unless it's a heated garage, that's the most likely cause. Road salt will also tend to make them rust more readily by both attracting moisture and as an electrochemical effect.
If it doesn't free off, you could have a sticky piston(s) which at the simplest would mean pumping the pistons out past their current working position, giving them a damned good clean with brake cleaner and a toothbrush then pushing them back in again. At worst a full strip-down.
davebike
PostPosted: 07:41 - 15 Dec 2021    Post subject: Reply with quote
I would pull the callipers off and give them a good clean
I would also lubricate the pivots for both front and rear brake levers
Dave
NC750Xdct + others at work !
davebike1@gmail.com
droog
PostPosted: 17:30 - 15 Dec 2021    Post subject: Reply with quote
Agree with above comments - remove the pads, give the inside of the calipers a good clean, paying attention to the pistons, making sure they are all moving properly and are not sticking.
I used to coat the pistons in red rubber grease to keep them moving properly after a caliper overhaul.
(Tokico six pots on my ZX7R were prone to seizing like this).
Even more boring in real life . . .
Pete.
PostPosted: 17:34 - 15 Dec 2021    Post subject: Reply with quote
Dimount the calipers and leave tem hanging on the pipes.
Remove the pads
Put a piece of flat metal (or a spanner etc) in the gap between the pistons where the disc runs.
Pump the pistons out using the brake lever unti they are all touching the metal.
Clean the pistons with some brake cleaner/wd40 and a strip of cloth.
Once cleaned, push the pistons back in, re-fit the pads and re-mount the calipers
If you do it like that you can do all the pistons and no need to bleed the system.
a.k.a 'Geri'
PostPosted: 17:48 - 15 Dec 2021    Post subject: Reply with quote
Remove the pads
At best this is only ever a temporary fix. Do the job properly, pull the pistons, clean them and refit with new seals.
jaffa90
PostPosted: 02:04 - 16 Dec 2021    Post subject: Reply with quote
Buy a rain cover and if the same problem get the brakes serviced as mentioned before more expense occurs and of course your safety.
The last post was made 2 years, 131 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.22 - MySQL Queries: 17 - Page Size: 54.64 Kb
