hollowgod89 |
hollowgod89 Two Stroke Sniffer
jaffa90 |
jaffa90 World Chat Champion
Easy-X |
Easy-X Super Spammer
hollowgod89 |
Tdibs |
Tdibs Traffic Copper
hollowgod89 |
WD Forte |
WD Forte World Chat Champion
Posted: 17:58 - 23 Dec 2021 Post subject: |
WD Forte wrote: |
Seems straightforward enough, if money's no object we can start tomorrow |
It is straightforward enough. There's nothing special about the ignition lock, it's just a switch like any other. There is a chip in the key and an RFID antenna mounted round the outside of the ignition lock.
The simplest way to do this would be to get a pattern ignition lock, fit it and swap the chip from the original key. OR buy a pattern ignition lock, dismantle it and rearrange the wafers so the original key fits.
You could also fit a new ignition lock, have a chipped key cut for it then register the new chip to your HISS system, a procedure which is relatively straightforward and requires two flying leads with a croc clip on one end and a terminal on the other and a 100k resistor. The procedure is well documented and simple. I did it so we had spare keys for Mrs stinkwheels CBR6.
But the OP does not want to replace the ignition barrel, he wants to bodge the wiring. Hence my suggestion of simply bodging a pattern ignition switch in without actually fitting it to the dash, then it'll just connect to the block connectors and when he decides to stop being so lazy, he can fit it properly.
It'll still need the original key in the original ignition to activate the RFID but the original ignition switch will be disconnected.
Incidentally, I'm pretty sure the actual ignition switch has three wires a red, a black on red and a yellow on blue. They are literally connected together when the ignition is on with the red being the unswitched live. So you could have any old 2-position switch with the red on one side and the other two wires on the other and it would do the same as the ignition switch. You'd still need the original key in the ignition lock so the HISS works, I'd suggest turning it on so the key can't come out if you go over a bump.
Or more fun would be to relocate the HISS antenna somewhere else and put the chip in something random. Then you can have a bike where you can turn the ignition on with a toggle switch but which won't run without it's teddy bear on the pillion seat. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 2 years, 118 days ago. Instead of replying here, would creating a new thread be more useful? |
