1st Bike (Honda CBF 600)
Abaaba
PostPosted: 09:55 - 02 Jan 2022    Post subject: 1st Bike (Honda CBF 600) Reply with quote
I finally pulled the trigger, after getting my A licence in November I didnt want to leave it too long to get a bike so I finally got a Honda CBF600 Fuel injection with ABS.
The 40 mile ride to take her home was scary but also exciting (even a frikking car overtook me at one point Embarassed I shall return the favor soon Smile )
question:
other than changing oil and oil filter, what else do I need to sort to begin with? Is there "how to" tutorials section for this bike in the forum?
Thanks
colink98
PostPosted: 10:37 - 02 Jan 2022    Post subject: Reply with quote
get yourself a Haynes manual for your model of bike.
it will give you clear instructions on what items to service/check and at which intervals.
plus its always handy to have a reference to check before doing any work.
PCX125 (stolen) - CBF600 (current)
Ride it like you stole it.
ride sensible and not like an idiot and you wont get 6 points in one week.
trevor saxe-coburg-gotha
PostPosted: 11:46 - 02 Jan 2022    Post subject: Re: 1st Bike (Honda CBF 600) Reply with quote
question:
Thanks
clean, tension and oil chain (easy to go too tight esp. if you're not feeling the movement with someone sat on it cos that increases wheel base length slightly, therefore takes a bit of slack out of chain), check tyres (wear and PSI). Got any paperwork? What's bike's mileage? Does it need and has it had first valve check?
Other than that, not a lot. It's a modern Japanese bike, after all.
xX-Alex-Xx
PostPosted: 13:15 - 02 Jan 2022    Post subject: Reply with quote
Just take a look in the owners manual as it'll have the scheduling for each bit of servicing. I'd do oil/brake fluid/coolant regardless cos I like knowing everything is done (and it's a good way to get to know the new bike and give it a good look over at the same time for any potential issues). Other than that there's not a lot you need to do other than the stuff already mentioned.
DILLIGAF
PostPosted: 13:37 - 02 Jan 2022    Post subject: Reply with quote
Years of experience has taught me to do, or at least inspect everything involved in a major service when I buy a second hand bike because there is absolutely no garauntee it has been done by the previous owner. Regardless of what they say has been done. Even if they are a motorcycle dealer and it has a fully stampoed up service log.
At a minuimum, I'd change all the fluids and filters, inspect all the moving parts (in detail) and lube/replace as necessary, check all the electrics are working. have a good look at the battery, how it's connected, how old it is. Check the tyres, look at the date code, check the brake pad and sprocket wear.
Diggs
PostPosted: 14:07 - 02 Jan 2022    Post subject: Reply with quote
...or (and at risk of loosing man-points), have a look at its service history, and if it is due one, take it in and have it done. That will leave you with thousands of miles to learn how to look after it yourself.
Now - Speed Triple, old ratty GS550, GSXR750M
Gone (in order of ownership) - Raleigh Runabout, AP50, KH125, GP125, KH250, CBX550, Z400, CB750FII, 250LC, GS550, ZXR750H1, Guzzi Targa, GSX750F, KH250 x2, Bimota SB6R and counting...
Fullers1845
PostPosted: 10:13 - 03 Jan 2022    Post subject: Reply with quote
Very true, my CB125F came with a fully stamped Honda dealer service book, the chain and sprockets were shot, headlight beam too low, fork yokes misaligned and the valve clearances were the wrong way round
struan80
PostPosted: 11:08 - 03 Jan 2022    Post subject: Reply with quote
Congratulations on your new bike mate. Do you have any photos?
Tdibs
PostPosted: 18:17 - 03 Jan 2022    Post subject: Reply with quote
Congrats and good pick for a first bike!
Ontop of what others have said, some ACF50 to keep it shiny Thumbs Up
Abaaba
PostPosted: 23:26 - 03 Jan 2022    Post subject: Reply with quote
I have but somehow it is not letting me upload it.
Abaaba
PostPosted: 23:42 - 03 Jan 2022    Post subject: Reply with quote
At a minimum, I'd change all the fluids and filters, inspect all the moving parts (in detail) and lube/replace as necessary, check all the electrics are working. have a good look at the battery, how it's connected, how old it is. Check the tyres, look at the date code, check the brake pad and sprocket wear.
I can probably manage changing the fluids but for the rest, I will get the Haynes manual before I touch them
I am comfortable fixing (DIY) cars but never touched a bike, but this being my first baby, I don't want to wreck it whilst tinkering with it - priority is to ride the thing this spring/summer and put some miles on it - I might even get a nonrunner bike just to practice taking it apart and put it together Smile
Abaaba
PostPosted: 23:45 - 03 Jan 2022    Post subject: Reply with quote
This is something I also considered - The bike wont be used much till spring so not in a rush at the moment.
would you recommend taking to Honda dealers or any motorbike/mot garage?
struan80
PostPosted: 00:03 - 04 Jan 2022    Post subject: Reply with quote
Personally I am too lazy and inadequate to spend time fiddling with bikes, just like to ride them. Find a trusted confident mechanic. Getting your hands dirty just messes up your grips.
ThunderGuts
PostPosted: 09:15 - 04 Jan 2022    Post subject: Reply with quote
Bikes are far easier to work on than cars. Everything is generally more accessible and for the most part relatively simple. You might find the service manual online for free with a bit of googling; I found the one for my old ER5 when I had it for free and it covered pretty much everything you could ever need to do, plus useful info like torque values for the bolts etc..
TG.
Diggs
PostPosted: 09:22 - 04 Jan 2022    Post subject: Reply with quote
I'd ask around to see where local people go. Main Dealer servicing is usually very expensive and the preserve of those wanting to maintain a fully stamped service book. I'd find a local bike shop that comes recommended, and ask that they detail all work done on your receipt. That way you know where you stand...
Tdibs
PostPosted: 01:49 - 05 Jan 2022    Post subject: Reply with quote
Buy a haynes manual and start slow. Read the parts for adjust the chain tension, tyre pressures etc. From there you can gradually progress to doing more and more of the servicing yourself and learn how it all works.
Jay1000RR
PostPosted: 09:39 - 05 Jan 2022    Post subject: Reply with quote
Great choice of first bike, now go and enjoy it.
ride in all conditions as this will make you understand your bike more and make you a better rider.
But be safe.
SUBMARINERS DO IT DEEPER
Bhud
PostPosted: 14:38 - 05 Jan 2022    Post subject: Reply with quote
Gotta be said, that is a great choice of first bike. Better than starting off with a GSXR you keep in the garage all the time, and thinking you're Valentino Rossi, in the hope of impressing neighbourhood kids. The choice of first bike says a lot about someone. That's the sort of bike you choose with your brain.
Just to add, if you're going to be servicing your bike, get all the information and tools you need first, before touching it. Torque specs especially. The last thing you want to do is try to change your oil and then strip the threads in an oil drainage hole because you overtightened the bolt. Service jobs are very simple but you still have to be careful.
PotatoHead202...
PostPosted: 17:18 - 05 Jan 2022    Post subject: Reply with quote
Buy a reasonable quality torque wrench and a haynes manual before attempting any DIY - especially an oil change. Check the Facebook group for that model as well as IIRC they have some of the service manual uploaded there.
Honda VFR1200F, Honda CBF500 ABS, CZ125 now CZ175
to v or not to v
PostPosted: 10:02 - 06 Jan 2022    Post subject: Reply with quote
watch how to videos on youtube. things are a lot easier after youve seen someone else do it. you can often pick up some good tips too.
Abaaba
PostPosted: 10:24 - 06 Jan 2022    Post subject: Reply with quote
I know some people say it is boring/dull but that is exactly why I chose it lol - I wanted something that is forgiving for newcomer so I can learn my roadcraft, something that doesn't scare the living day out of me, easy to ride and comfy...........This bike ticked all of that boxes.
There will be plenty of time to own and try every motorbike possible but it is not now, remember the saying"pick your battles" Smile
The last post was made 2 years, 110 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.59 - MySQL Queries: 17 - Page Size: 116.92 Kb
