Yamaha yzf 125 error code
piazza
PostPosted: 17:40 - 20 Jan 2022    Post subject: Yamaha yzf 125 error code Reply with quote
I've got 2011 yzf with a flashing engine management light on and can't find a port to read it. Anyone got one or know where it is?
PostPosted: 17:42 - 20 Jan 2022    Post subject: Re: Yamaha yzf 125 error code Reply with quote
You need to count the number of flashes (and potentially if they are long or short) then look up that.
piazza
PostPosted: 17:57 - 20 Jan 2022    Post subject: Reply with quote
It's just a flash not a code the problem is finding the port reader that doesn't seem to exist. It says to 'disconnect the diagnostic wire and plug it into no 2'
PostPosted: 17:58 - 20 Jan 2022    Post subject: Reply with quote
FFS
https://www.r125forum.com/threads/error-code-list.8660/
piazza
PostPosted: 18:11 - 20 Jan 2022    Post subject: Reply with quote
Yes that's codes, it's not a code just a flash and if I can find out how to plug in and read it that'd be helpful Thumbs Up
Evil Hans
PostPosted: 18:15 - 20 Jan 2022    Post subject: Reply with quote
Just a single flash? Or a continuous flashing? Or does it flash a certain number of times then stop?
For example, as explained in the link above, 2 long flashes followed by 5 short ones would be code 25
FFS part deux....
'After the engine has been stopped, the lowest fault code number is indicated by the engine trouble warning light'
https://www.yam-r125.net/ecu_self_diagnostic_function-348.html
piazza
PostPosted: 18:19 - 20 Jan 2022    Post subject: Reply with quote
It's just a standard flash like an indicator. The location of the port is what were looking for.
Everything you've sent has been seen and read already Nobby.
PostPosted: 18:41 - 20 Jan 2022    Post subject: Reply with quote
But clearly not understood....
If you need a separate reader the light would come on a d stay on.
It's flashing. Its sending you a message in a code that you don't understamd....
PostPosted: 23:58 - 20 Jan 2022    Post subject: Reply with quote
Continuous flashing = bent sub frame, chain slack
The last post was made 2 years, 96 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.79 - MySQL Queries: 17 - Page Size: 65.7 Kb
