| -Savage- |
 -Savage- World Chat Champion
 Posted: 23:50 - 15 Feb 2025 Post subject: Out building "central heating" |
Hi guys, just a quick ponder. If I ask this kind of thing on a plumbing forum they would reply with something like "if you have to ask don't do it", but as we all know, I'm going to do it anyway, so any advice is much appreciated.
So....
I have a building at the bottom of my garden, about 100 yards away, so a fair distance.
I have a decked area out the front where I have a old gas bottle made into a wood stove, with a chimney and all.
What I would like to do is, spool copper pipe around the stove/chimney, and run it to a radiator inside the outbuilding so that I can fire up the stove outside, and have heat inside.
I plan to do this by using a central heating pump to circulate the water, and have a header tank (another gas bottle) at a high point in the system to allow for expansion/steam release. This header tank will be open so it can't become pressurized and can be easily topped up with water.
What are our thoughts on this? ____________________ My Bikes - - - Royal Enfield 500 with sidecar, VFR800, CBR600FX,
Peugeot Speedfight 100, Kymco Hipster 125, GSXR750K5, Jawa TS 350 |
| stinkwheel |
 Posted: 00:29 - 16 Feb 2025 Post subject: |
My main worry would be how long the copper pipe will last. I wonder if you'd be better looking on your local freecycle/gumtree for someone getting rid of a back boiler setup. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| hellkat |
 hellkat Super Spammer
 Posted: 02:12 - 16 Feb 2025 Post subject: |
This discussion makes me think of the word "lagging".
But I have a conundrum.
Y'know when someone says "He was proper lagging!" - how did it end up being called that?
It's got nothing to do with insulation of pipes, copper or otherwise.
 ____________________ Not nearly as interesting in real life. |
| jeremyr62 |
 jeremyr62 Nova Slayer
| doggone |
 doggone World Chat Champion
| Polarbear |
 Polarbear Super Spammer
| virus |
 virus World Chat Champion
| Freddyfruitba... |
 Freddyfruitba... World Chat Champion
| hellkat |
| hellkat |
 Posted: 01:56 - 17 Feb 2025 Post subject: |
*might just be a cockney fing...
| A100man |
 A100man World Chat Champion
 Posted: 15:18 - 17 Feb 2025 Post subject: Re: Out building "central heating" |
| -Savage- wrote: | Hi guys, just a quick ponder. If I ask this kind of thing on a plumbing forum they would reply with something like "if you have to ask don't do it", but as we all know, I'm going to do it anyway, so any advice is much appreciated.
So....
What are our thoughts on this? |
Would you need a pump or would it 'syphon' around like the old rayburn/water-bathrom arrangements. Give it a try what's the worst that can happen gotta be more fun than a bought in solution.
PS 10mm microbore for bending around the gas bottle burner I'd think.
PPS whas the objection to a wood burner inside? ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| -Savage- |
 Posted: 20:49 - 18 Feb 2025 Post subject: |
The main reason for wanting to do it the way I had described, is that I already have a wood burner out the front of the building, and I have an old radiator inside on the wall for decoration lol.
I don't know that a wood burner inside is a good idea, as its totally timber built and carpeted with soft furnishings etc, so I'd always be afraid of the fire risk.
Potentially the diesel heater idea might be good. I could run an exhaust out through the wall easily enough.
Thanks for the input guys. ____________________ My Bikes - - - Royal Enfield 500 with sidecar, VFR800, CBR600FX,
| RhynoCZ |
 RhynoCZ Super Spammer
| WD Forte |
 WD Forte World Chat Champion
| doggone |
 Posted: 11:49 - 20 Feb 2025 Post subject: |
If it's reasonably well ventilated you can get away with running the diesel heater inside for limited periods obviously ideally the exhaust should go outside but sometimes it's easier said than done.
With mine you get a hint of fumes as it starts and stops otherwise there is very little to worry about if you just have teh heat directed where you are working.
Bear in mind there are much more serious diesel heaters don't worry about exhausts at all but they are intended for large open sheds etc.
So you could try one without committing to major alterations.
https://jcb-tools.co.uk/jcb-70-000btu-20kw-diesel-space-heater-496m-coverage-kerosene-or-diesel-thermostat-jcb-sh70d/ |
| sickpup |
 sickpup Old Timer
The last post was made 1 year, 249 days ago. Instead of replying here, would creating a new thread be more useful? |
