NBR green mould on car door and window seals
PostPosted: 14:21 - 29 Mar 2022    Post subject: NBR green mould on car door and window seals Reply with quote
Currently giving the old galaxy a long overdue tart up
and see it has some mould/fungi on the door seals and rubber work
Googling give various tips but will ask here anyway
I have bleach, methylated spirits, white spirit, WD40
various valet aerosols
and various household cleaning materials plus a nylon brush and scraper thingys and rags
anyone have cunning wheezes for this job from the above stuff?
If it involves traipsing about buying shit forget it.
TIA
PostPosted: 14:47 - 29 Mar 2022    Post subject: Re: NBR green mould on car door and window seals Reply with quote
TIA
Surely Meguire's mould/fungi on the door seals and rubber work renovator is what you need - only 50 quid a bottle to Sir..
PostPosted: 15:31 - 29 Mar 2022    Post subject: Reply with quote
Hot soapy water works for most things.
Then a wipe down with aerospace 303 (like ACF50 for rubber and plastic).
ThunderGuts
PostPosted: 15:41 - 29 Mar 2022    Post subject: Reply with quote
With a stiff brush and car shampoo I got mossy stuff off my car window seals the other day. Thumbs Up I made sure it was good and frothy before I went at it though.
TG.
PostPosted: 16:08 - 29 Mar 2022    Post subject: Reply with quote
I got to the "ah fuck it" stage and used some diluted bleach and disinfectant with a stiff nylon brush and worked it into the mossy
nooks and crannies
Will take it to the car wash in a bit to rinse all the messy bits off
first wash in 2 years so its about time I spose
I did vac out the interior too
PostPosted: 17:06 - 29 Mar 2022    Post subject: Reply with quote
nooks and crannies
Don't take it to one of those slave hand places where they use bloody great jet washes, it'll fall apart. Laughing
Triumph Trophy Launch Edition
PostPosted: 17:49 - 29 Mar 2022    Post subject: Reply with quote
WD Forte wrote:
First wash in 2 years so its about time I spose
As I keep telling the wife, you'll just rot the sills out if you wash them too much.
pepperami
PostPosted: 18:57 - 29 Mar 2022    Post subject: Reply with quote
This +1
PostPosted: 20:19 - 29 Mar 2022    Post subject: Reply with quote
Cillit Bang (Mould Formula).
Works a treat.
blurredman
PostPosted: 12:53 - 30 Mar 2022    Post subject: Reply with quote
mmm, had this stuff growing on my left wing mirror for about 12 years... I can't disturb it after all this time.
But actually, smearing vasciline over the offending greenery can work. leave it on for a while then remove the plant, should come easily now that it is dying/dead.
PostPosted: 13:03 - 30 Mar 2022    Post subject: Reply with quote
So, Yesterday I'm worritin' over what chemicals to use and today whilst doing other jobs I find a spray bottle of Screwfix's No Nonsense Mould and Mildew cleaner which would probably have done the job just fine.
No matter, there are few other small spots yet to be done
and I'll try it on those
Ribenapigeon
PostPosted: 14:27 - 13 Apr 2022    Post subject: Reply with quote
Tldr but a copper sulphate solution works. I made some up to stop mossy slippery build up on my ramp into the shed the bike lives in and it works great. Ive inherited a small car which had tons of moss build up on door window rubbers and i cleaned it off with the copper sulphate last year with no ill effects. Alternatively you could string a copper wire around the roof . This was an old slating tip for preventing moss on roofs i learned from a slater i used to do labouring for when I was a student.
Ribenapigeon
PostPosted: 14:30 - 13 Apr 2022    Post subject: Reply with quote
The take away i get from your tip is you keep a tub of vasaline in your car. Thinking
PostPosted: 15:29 - 13 Apr 2022    Post subject: Reply with quote
Who the f'ck can afford copper wire these days?
Ribenapigeon
PostPosted: 16:08 - 13 Apr 2022    Post subject: Reply with quote
Deliver-Ho rent boys equipped with their own vasaline ? Laughing
steve the grease
PostPosted: 16:11 - 13 Apr 2022    Post subject: Reply with quote
nooks and crannies
I have a friend who I nicknamed Arthur Hooket because of his attitude to most things....
There is a gap of 1 year, 289 days between these two posts...
HottIsland
PostPosted: 22:01 - 27 Jan 2024    Post subject: Reply with quote
Mixing a bit of bleach with water (about 1:10 ratio) can work wonders. Apply it to the affected areas, scrub gently with your nylon brush, and then wipe it clean with a rag. Just be sure to rinse thoroughly afterward.
WD40 is also pretty handy for removing stubborn residues, but I'd suggest a test spot first to ensure it doesn't affect the rubber.
But hey, if you're ever unsure or if the mold issue seems more extensive, it might be wise to consider a professional mold inspector.
doggone
PostPosted: 09:29 - 28 Jan 2024    Post subject: Reply with quote
It might be due a wash again.
PostPosted: 14:44 - 28 Jan 2024    Post subject: Reply with quote
Ahh! That reminds me, I must get round to doing it soon
PostPosted: 15:03 - 28 Jan 2024    Post subject: Reply with quote
Can you not pause until the risk of frost and storm weather has passed?
No need to take a hasty approach to this impending issue.
PostPosted: 16:34 - 28 Jan 2024    Post subject: Reply with quote
Yes your're right, it isnt the sort of thing you want to be rushing into
is it?
Islander
PostPosted: 23:13 - 28 Jan 2024    Post subject: Reply with quote
My Cashcow (Qashqai) is a bastard for this. I found a dandelion growing in a panel seam this year. I get moss growing on rubber seals, around the edges of the rear window, green algae anywhere there's a bit of shelter for it. I usually pressure wash the shite off after a soak with hot soapy water but I'm thinking about trying some Wet and Forget on a discrete area (it's a surfactant and shouldn't do any damage but still...).
If it works then I'll soak all of the problem areas with it, leave it to dry overnight and then pressure wash it off. It should hopefully save a lot of effort...
doggone
PostPosted: 08:48 - 29 Jan 2024    Post subject: Reply with quote
One of my friends ( retired mechanic Laughing ) believes washing does more harm than good - so he never does it even though he parks under trees so it is often covered in a layer of guano at one end while the other is growing not just algae and moss but is on stage three with circles of lichen.
Eventually you would get small shrubs I expect but the car won't last that long.
PostPosted: 18:05 - 29 Jan 2024    Post subject: Reply with quote
I'd put this down to local humidity. My mum's car was terrible for green algae, having spent all its life till recently in Cornwall whereas my car that never gets washed and hardly has any.
Islander
PostPosted: 20:05 - 29 Jan 2024    Post subject: Reply with quote
It's possible, I do live in a maritime environment after all. The Cashcow is the worst of all of the cars I've owned for this though, The Passat I had before this wasn't affected at all.
The last post was made 2 years, 24 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.22 - MySQL Queries: 13 - Page Size: 131.72 Kb
